Using a Lead 100 Mosfet w/o Speakers?
Discussion in 'The Workbench' started by Mark Diehl, Aug 13, 2013.
  1. Mark Diehl
    Mark Diehl New Member
    Aug 13, 2013
    2
    New Paris, PA
    I recently purchased a Lead 100 Mosfet. I would like to use this in an electric/acoustic duo I am part of WITHOUT speakers, running it straight into our PA mixing board out of the DI.
    I know this is a big No-No in the tube amp world, but would this be okay with this head?
    Thanks!
    Mark
  2. MKB
    MKB Well-Known Member
    Jul 15, 2008
    1,268
    310
    Probably it is OK. In general, with amps that have no output transformer, they simply do not care if there is no load. Such an amp will then only swing voltage, no load = no current and thus no power from the amp.
    I would suggest you check the manual for the amp. If there is no minimum recommended load, and no warning about having a speaker connected, it should be safe to operate it with no speaker.
  3. mott555
    mott555 Well-Known Member
    Mar 25, 2013
    3,466
    2,639
    Omaha
    Running without a load ought to be okay on solid-state amps.
  4. chuckharmonjr
    Mar 26, 2010
    8,817
    4,290
    No speaker "load" on a solid state output section is no problem at all. Since it is an open circuit, that represents infinite load and therefore no current flow at all.
  5. MKB
    Jul 15, 2008
    1,268
    310
    There are some solid state amps (such as very early ones and current McIntosh stereo amps) with output transformers, and those may not react well to running without a load. So it is best to check to be 100% sure. However I am almost 100% sure that the Mosfet 100 does not have an OT and is safe to use without a load.
  6. plec-2
    plec-2 New Member
    Jan 5, 2010
    81
    7
    Scotland (Glasgow)
    Yes it's ok to run mosfet/transistor amp with out load..plus that model has a line feed out that switches the pre-amp form main power amp via the jack socket and floats the signal from the amp.
  7. MoreZazz
    MoreZazz New Member
    Sep 25, 2014
    11
    ATX!
    Thank y'all for this thread! It's my solution to fix my 5213 MOSFET twins problems! Tytytyty!
  8. RickyLee
    May 22, 2010
    9,341
    2,816
    Riverside CA U.S.A.
    Very odd thread.
    I am repairing an AVT50 that blew the output IC after the previous owner had the speaker cable yanked out while playing it. Smoked the IC chip as well as a 10 ohm resistor on the PCB that is part of the output section as well.
    :hmm:
  9. hazmat7719
    hazmat7719 Active Member
    May 26, 2013
    609
    237
    Maryland
    RickyLee,
    The amp could have been diving a direct short when the cable was yanked out. The connector could have shorted both contacts for a brief time.
    Ken likes this.
  10. Ken
    Ken Well-Known Member
    Feb 24, 2009
    9,944
    3,137
    Arlington Heights, IL
    Exactly. There was a momentary short and with a SS amp that's all it takes.
    Ken
    hazmat7719 likes this.
  11. RickyLee
    May 22, 2010
    9,341
    2,816
    Riverside CA U.S.A.
    Interesting for sure. I just can't get myself to trust running even my solid state amps without a load. I was thinking of running FX out of the MOSFET into another amp as well. But then I was going to have a speaker load on the MOSFET regardless.
    I thought of another situation that was similar to the damaged AVT50. Many years ago my vocalist' Carvin PA blew one of the power amp IC's on one channel. That one was from an OPEN on the 1/4" jacks on the PA speaker cab. That scenario is similar to what you guys are stating except there was no momentary direct short as the speaker cable came out on the speaker side not the amp side. I see how you guys are stating that the scenario on my AVT50 was a momentary short from the action of the speaker cable coming out of the amps speaker out jack while powered on. But the Carvin scenario was a load to no load action, no direct short.
  12. dsn716
    dsn716 Active Member
    Aug 2, 2013
    241
    239
    Virginia
  13. Masteresgt
    Masteresgt Active Member
    Apr 13, 2013
    398
    130
    Quebec, Canada
    I blew my 2 IC with speakers cables retracted from the socket of the cab (a modified Yamaha B212 amp with speaker socket added to use the amp as cab only)... I think that tip of cable touch the ground of the socket when retracted so cable was short.
    Wanged unplugged cables must not "short" the output unless they touch a ground somewhere...
  14. anitoli
    anitoli Well-Known Member
    6,210
    6,646
    The manual states to never power up the head without a speaker, so do so at your own risk. Besides as was already posted the head has a DI out put.
