Use Guitar Fretboard Cleaning? What Do You Use
Discussion in 'Guitars' started by BowerR64, Mar 20, 2017 at 4:04 AM.
  1. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    2,554
    1,057
    Found 2 acoustic, a bass, a cheap electric and a SE355 hallow body clone on CL for $100. dirty as heck. One of the acoustics is an older yamaha thats seen some play time, and the hallow body has some time on it also.
    Both of the well played guitars has major ginger oils caked on the fretboard. I was curious what you guys use to get that grime off?
    Ive tried goo gone, rubbing alcohol i even used a blade once to scrape the crap off. I think it might also be smoke tar.
  2. Reel Tape
    Reel Tape Member
    Dec 12, 2016
    51
    69
    Ray Ray`s Juke Joint
    Lighter fluid (also known as Naphtha) steel wool.
    Then finish with Howard Butcher Block Conditioner.
    If is real bad Lestoil, that stuff cleans anything.
    royslead likes this.
  3. jensvonbustenskjol
    Feb 5, 2012
    471
    152
    Norway
    Dunlop fretboard cleaner. A bit with cleaner and oil.
    Works for me
  4. Biddlin
    Biddlin Well-Known Member
    Aug 21, 2013
    2,994
    3,134
    Carella Gardens, Alta Elk Grove Califusa
    Yes, a world of uses, that!
    This also works well.
    A little goes a long way.
    I usually use and recommend this:
    I haven't tried to remove cotton candy or gummy worms, but for once a year clean and shine, it's very good stuff.
    Reel Tape likes this.
  5. axe4me
    axe4me Well-Known Member
    Feb 28, 2013
    1,001
    982
  6. Kutt
    Kutt Active Member
    May 27, 2010
    213
    92
    Massachusetts, USA
    Rosewood and/or ebony and not maple, right? Do not perform the following on maple.
    Dampen a small ball of 0000 steel wool with lukewarm water. Gently clean in the direction of the wood grain (you can carefully clean the frets too while you're there). Pat dry immediately and let air dry. Then rub in some boiled linseed oil. Wipe away any excess and let dry. Dispose of any oily rags properly (I leave them outside for a few days first). They can be combustible.
    Been doing it for years with great success. Learned from one of the best luthiers this side of the Mississippi.
  7. Biddlin
    Aug 21, 2013
    2,994
    3,134
    An old and tried method, I'm sure!
  8. ricksconnected
    Sep 29, 2015
    7,672
    2,282
    Flying in a Blue Dream.
    will not will not WILL NOT use water anywhere near my fretboards.
    Biddlin likes this.
  9. Dogs of Doom
    14,184
    11,330
  10. custom53
    custom53 Well-Known Member
    Sep 29, 2009
    1,725
    663
    Ohio
    Fret Doctor... The only thing I use...
  11. ricksconnected
    Sep 29, 2015
    7,672
    2,282
    they make some of the most beautiful guitars ever.
    Dogs of Doom likes this.
  12. Coronado
    Coronado Well-Known Member
    Jan 2, 2013
    3,302
    2,634
    Dallas
    This may sound kinda nuts, but I love to clean my fretboards. I don't know why - therapeutic I guess? I have to keep a log of when I do it (once to twice a year, depending on how much play they get). I'd frickin' clean and polish my fretboard each week if I could!
    I have to admit to being a habitual guitar polishing nut as well. :noplease:
  13. El Gringo
    El Gringo Active Member
    Jul 24, 2015
    284
    111
    Shakedown Street
  14. BowerR64
    Nov 23, 2014
    2,554
    1,057
    I have balistol i may try it. That stuff stinks but it worked great for blackpowder guns i know that. Never thought of lighter fluid either, the rubbing alcohol i tried is the strongest and it didnt seem to even phase the goo.
    I havnt noticed alot of my maple neck guitars with alot of finger goo on the fretboard mostly the darker fretboard woods ive noticed mainly rosewood.
    I just recently cleaned an older 77-81 yamaha acoustic that looked like it has had a few fret jobs done on it. The frets are pretty low and you could really see and feel the goo.
    I just like cleaning a used guitar thats seen alot of use before new strings and a setup.
  15. ricksconnected
    Sep 29, 2015
    7,672
    2,282
    naptha will walk all over alcohol R64.
    Biddlin likes this.
  16. Solid State
    Solid State Member
    Jan 2, 2016
    59
    42
    I use windex and a washrag to get the crud from around the frets and then pledge and a washrag to make it all lemony fresh.
  17. ricksconnected
    Sep 29, 2015
    7,672
    2,282
    don't use water based products.
  18. Evil Z06
    Evil Z06 Member
    Dec 6, 2011
    58
    29
    Pembroke Pines,FL
    Gorgomyte cleans the fretboard and frets.I use it and it works great.
    lordquilton likes this.
  19. lordquilton
    lordquilton Well-Known Member
    Nov 14, 2013
    448
    336
    +1 for the Gorgomyte, I got it to clean maple fretboards but obviously it works just as well on rosewood or ebony.
    Goes a long way too.
  20. matttornado
    matttornado Active Member
    Mar 14, 2012
    508
    129
    I use lemon oil on both maple & rosewood necks. I use Pledge furniture polish for cleaning the guitars.
