Understanding DSL40CR speaker outs
Discussion in 'Marshall Amps' started by Dave J, Nov 22, 2019.
  1. Dave J
    Dave J New Member
    Mar 13, 2019
    16
    21
    I have DSL40CR and am trying to nail down what I want to use for speakers. I actually like the V type in the combo. I tried a Gold and it didn't do it for me. I have had 2x 8 ohm V30's wired series in a cab which I believe gives me 16 ohms out. I liked it okay but again actually prefer the V type. I was going to get 2 8 ohm V types for the cab, but I might end up selling the 2x12 cab, and using the combo and getting a 2nd 16 ohm V type or maybe a E-65 WGS and running a 1x12 ext cab instead. Background info aside:
    The speaker inputs on the DSL40CR are
    1 jack = 1x16 - 2 jacks = 1x8 or 2x16 and 2 jacks = 1x4 or 2x8
    If I use 2 16 ohm speakers in the 1x8 / 2x16 jacks they would have to be in series, right?
    I have read some stuff about 8 ohm speakers have a different sound than a 16 ohm, most say no diff as long as impedances are matched, but a couple things I have read say 8 ohms sounds more mid aggressive and 16 ohms sounds more vintage.
    So does series or parallel change the sound? If a 16 ohm speaker has a " certain " sound does two wired in parallel make it sound like the more mid aggression, or does it keep its supposedly "more vintage" sound. Does it really matter?
    I play clean to fairly heavy gain, but not metal and like the way the V Type sounds compared to the more modern V30's mid hump.
    The V30 was supposed to be a high watt version of a greenback I believe but the V type is more like a Greenback to my ears.
    Thanks for any input.
  2. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,372
    2,373
    Wa State
    Tone change is negligible …
    2 16 ohm in Parallel is 8 ohm…
    All of 2x jack sets on the CR are Parallel …
    Wire the 2/12 cab with 2 8ohm In Series for 16ohm…
    If you run the 16ohm in Cab simultaneously with the 16ohm cab , plug into 2x16 …… Just stock 16ohm in Combo should be in 1x16
  3. Mitchell Pearrow
    9,643
    15,509
    Welcome to the forum.
    More knowledgeable members here will come along with answers to your questions.
    Cheers Mitch
    Jon C likes this.
  4. MaskingApathy
    MaskingApathy Well-Known Member
    Jan 17, 2017
    237
    282
    I've never heard of any tone difference between 8 ohms and 16 ohms. I doubt you would be able to hear much of a difference anyway. It sounds like you really like the V Type so I would suggest just using that in the 1x12 or 2x12 cabs. Or you could try a creamback.
  5. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,183
    929
    Saginaw MI
    Plug a single 16 ohm load into the 1x16 jack
    Plug 2 -16 ohm load cabs into each of the 1x8/2x16 jacks (or) 1 cab connected to the other and a single cord to the 1x8...depending on your cab configurations
    Plug a single 8ohm load into the 1x8 jack
    Plug 2 -8 ohm load cabs into the 1x4/2x8 jacks (or) 1 cab connected to the other and a single cord to the 1x4...depending on your cab configurations
    Plug a single 4 ohm load into 1x4 jack
    Series vs parallel wiring for speakers won't by itself change or alter the tone.
    Under or over powering the speakers due to impedance mis-matching may have a difference in tone.
    Being 1 impedance mis-match isn't a damaging strain to the gear (4-8 or 8-16), but being at the extreme ends or further will.
  6. Dave J
    Dave J New Member
    Mar 13, 2019
    16
    21
    Thanks for the posts ! I'll check out a Creamback for sure. One of my 1x12's is a Mesa 3/4 closed oversized that sounds pretty huge for a 1x12, and a Stage Craft Black Jack studio that is closed with the option to make it 3/4 closed. It just hit me that I never did try the Celestion Gold in either cab, just the combo. I liked it in the combo but not as much as I like the V type. Maybe in the bigger cab I'll like it more.
    Thanks for clearing up the electronic stuff !!
