UK Marshall Powered off US AC?
Discussion in 'Marshall Amps' started by Len, Dec 30, 2013.
  1. Len
    Len Well-Known Member
    Sep 13, 2009
    986
    750
    I just got a Marshall JCM1H, but the seller didn't both to advertise that it was designed for UK power.
    The plug supplied wight he amp is a 2 prong UK type, the amp has the UK flag next to the power input, but the power input says 120V - 60Hz, which sound US?
    Any suggestions on what I have to do to be able to power the amp off US power?
  2. damienbeale
    damienbeale Well-Known Member
    Mar 1, 2013
    3,798
    1,752
    Oxford ish sorta...
    There is no such thing as a 2 prong UK type, and never has been.
    That's not a UK amp.
  3. Redstone
    Redstone Well-Known Member
    Jun 21, 2012
    3,385
    2,291
    Ireland
    120V is USA Voltage. My JCM1C is designed for USA voltages and has a British Flag next to it. It is there because it is made in the UK. I had to get a step-up transformer to use it here in Ireland. we have the same voltage as the UK. I stupidly used just a regular plug converter without a transformer and nearly fried my amp. Luckily the main fuse took the extra voltage and saved the amp. The amp has a spare fuse. Its in a little compartment next to where to power cable plugs in. You just got to pull it to get it open. It is the little thing with the rectangle with a line though it in the photo below. Sorry for the bad photo.
    If it says 120V you should be ready to go. Do you have a cab for it? Make sure it is plugged in to one. Enjoy your amp! They sound great, especially the Boost/Jubilee mode.
  4. Len
    Sep 13, 2009
    986
    750
    Thanks for the feedback. I'm checking with Marshall too, but like you said, it sounds like the amp is made for US power. I think the non-US plug (photo added above) threw me off.
  5. damienbeale
    Mar 1, 2013
    3,798
    1,752
    Oxford ish sorta...
    Checking the fuse in the IEC socket at the back of the amp should give you another clue.
  6. keennay
    keennay Well-Known Member
    Oct 21, 2012
    3,453
    2,247
    Have you contacted the seller? If that's a 120V amp, then there's a chance the seller happened to throw in the wrong cable by mistake.
    That's the plug used in France (and most of mainland Europe), but specifically French.
    crossroadsnyc likes this.
  7. Len
    Sep 13, 2009
    986
    750
    Yeah, I'm trying to get a response from the seller. The fuse is a standard 250V one, which I think is used in US appliances, so all roads (except the plug) lead to US 120V power right now...
  8. Adwex
    Adwex New Member
    Sep 12, 2006
    9,021
    4,080
    I'm not sure.
    This is what you need:
    A standard US power cable for computers and other similar electronic equipment.
    You should be able to get one for about $5.
    Redstone likes this.
  9. Len
    Sep 13, 2009
    986
    750
    Yeah, the amp works off 120V. Thanks for everyone's help.
  10. damienbeale
    Mar 1, 2013
    3,798
    1,752
    Oxford ish sorta...
    It's the current rating will give you a clue. All mains fuses should be 250V rated.
  11. crossroadsnyc
    Feb 5, 2009
    20,196
    18,275
    Lol, Denmark looks happy.
    Chrisuk, keennay and Redstone like this.
  12. Redstone
    Jun 21, 2012
    3,385
    2,291
    Ireland
    North America looks shocked :lol:
    keennay, Chrisuk and crossroadsnyc like this.
  13. damienbeale
    Mar 1, 2013
    3,798
    1,752
    Oxford ish sorta...
    I think Denmark got N.A's share.
  14. Ghostman
    Ghostman Well-Known Member
    Jan 29, 2012
    10,321
    10,001
    Hopehouse, Selkirk, UK
    keennay, crossroadsnyc and Redstone like this.
  15. Len
    Sep 13, 2009
    986
    750
    This thread has taken a disturbing turn :).
  16. sinner 13
    sinner 13 Well-Known Member
    Sep 11, 2011
    1,870
    1,641
    Cradle Of Liberty.
    you would think with all the strides we have made as a society in the last 100 years we could at least pull it together long enough to standardize Freaking appliance cords and wall output voltages......:scratch:
    Redstone and crossroadsnyc like this.
  17. crossroadsnyc
    Feb 5, 2009
    20,196
    18,275
    While juvenile, I'm tempted to do the same w/one of my outlets :lol:
