Tubes for the 2525H/C and other info
Discussion in 'The Workbench' started by DonP, Sep 20, 2019.
  1. DonP
    DonP Active Member
    Jan 28, 2009
    103
    44
    Cincinnati, OH
    So I found out one reason why my 2525H was lacking balls was that it was running on one power tube.
    Looking for recommendations on what power tube would fill in the bottom end the best. Currently running JJ E34L's.
    I'm looking at:
    Marshall branded TungSol EL34B's - same that came with the amp. ~ $60
    Gold Lion KT77 - sort of pricey. ~ $100
    A Used pair Mullard XF2 for the same price as the Gold Lions that are new.
    Others?
    For the knowledge of the forum, my E34L's in 20 watt mode have 250 volts on the plates and around 55ma of current. In low power mode the plate voltage dropped in half, and I can't remember what the bias was but is was lower, in the 30's I think.
    The LED's on the circuit board are tiny compared to the old ones.
  2. Kinkless Tetrode
    Aug 17, 2017
    834
    944
    I use the EH 6CA7.
    The Shuguang EL34B I quite liked in the 2525 as well.
    The Mullard RI EL34 is warm and smooth in the 2525.
    I didn't like the Tung Sol EL34B in that amp.
  3. pedecamp
    12,888
    8,530
    I was gonna say JJ KT77, not so pricey as the gold Lion and do the job. :yesway:
  4. DonP
    DonP Active Member
    Jan 28, 2009
    103
    44
    Cincinnati, OH
    Is anyone running 6550's? Any issues?
    Thanks.
  5. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    2,499
    2,517
    Ft.WorthTX
    I like EHX and Svetlana el34’s in my Marshalls. Affordable and sound much better and last longer than JJs.
