Tsl 100 Footswitch Wirinh W/ Pxl Pro
Discussion in 'The Workbench' started by xcolbeyx, Jul 16, 2016.
  1. xcolbeyx
    xcolbeyx New Member
    Feb 23, 2015
    4
    los angeles
    Accidentally posted this in the wrong forum... So here we go again
    I've been using my TSL for 8 years now, and I've accumulated enough effects pedals that I'm looking into getting a looper/switching device to let me switch channels/fx on simultaneously so I can stop tap dancing as much. I've looked at the Boss ES-8 and that seems rather easy to program and get a pre-made 6 pin din to dual trs cable for. But it's $600+ and I have no use for MIDI. So I found the Joyo PXL Pro which has no MIDI, but 4 separate triggers for controlling the amp. I've found pre made cables and schematics on how to wire the TSL to the TRS cables, but for the Joyo, it seems I would need a custom 6 pin din to 4 TS breakout cables in order to control the 3 channels plus reverb and fx loop.
    Has anyone used the PXL Pro with their TSL? Does anyone know if a pre made cable for this exists?
    Or maybe someone could help me dissect the wiring of the 2 TRS cable schematic to turn those into 4 TS cables (assuming that is what I need to make) to make the TSL controllable by the PXL Pro?
    Thanks!
  2. ampmadscientist
    17,963
    11,987
    Boss ES-8
    It's much simpler to go pre made way, than to interface things a harder way. You will find use for midi eventually.
    Or you will call PXL for a solution if there is one.
    But probably nobody has done what you are talking about doing before, it's the first time I heard of it being done anyhow.
