Tried El34's In The Afd 100
Discussion in 'Marshall Amps' started by lespaul6, Apr 26, 2019.
  1. lespaul6
    lespaul6 Member
    Dec 13, 2007
    71
    56
    Florida
    It sounded ok? I guess.. seemed to be just as loud as 6550's but the bottom was "lifting" up differently when muting etc. I like the 6550's better in this amp.
    The factory setting on the 6550's was in the 40's does this seem too underbiased and stressful to the power transformer?
    When backed off to around 38 it sounded weaker with less high end cut... didn't make any sense to me, it should be brighter at that setting.
  2. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,677
    4,552
    Whats your plate voltage ?
    Bias is set in relation to PV.
    That amp has an auto-bias feature i believe.
    MarshallDog likes this.
  3. lespaul6
    lespaul6 Member
    Dec 13, 2007
    71
    56
    Florida
    About 470-480
  4. charveldan
    Jan 31, 2010
    7,677
    4,552
    Bias for 6550 per tube should be around 52ma @ 470 plate volts.
    EL-34's should be around 37ma @ 470 plate volts per tube.
    Thats 70% dissapation.
  5. anitoli
    anitoli Well-Known Member
    5,728
    5,859
    You don't have to bias at 70%. You can bias much lower. Let your ears decide. The colder the longer the tube life and more headroom in the power amp.
  6. mickeydg5
    20,036
    7,913
    At those plate voltages biasing in the middle 40's mA range is preferred.
    The recommended bias current settings are right there in your manual, at 120VAC wall supply anywhere from 32mA - 47mA is good.
    It gets a bit more clarity and top end with higher settings so turn it up enough to get that. It is not stressing your amplifier.
    DO NOT USE THE 6550 35/42 WATT PLATE DISSIPATION FOR CALCULATIONS. THIS AMPLIFIER IS DESIGNED AROUND A 25W DISSIPATION.
    :metal:
  7. lespaul6
    lespaul6 Member
    Dec 13, 2007
    71
    56
    Florida
    There is definitely a point where that clarity you are talking about "pops" and its always in the same place. I wish I had a manual but I bought it used. Looks like the bias control was never touched- based on some photos Ive seen online. I will leave it there (around 41ma). The original tubes are now 8yrs old so they probably need to be changed out anyway. thanks for all the recommendations gentleman
    Mitchell Pearrow and charveldan like this.
  8. mickeydg5
    20,036
    7,913
  9. ampmadscientist
    11,614
    5,658
    Left Coast
    "...seemed to be just as loud as 6550's but the bottom was "lifting" up differently ..."
    How did you bias it?
    "The factory setting on the 6550's was in the 40's does this seem too underbiased and stressful to the power transformer...?"
    How do you know it was the factory setting?
    The factory will bias it cold, to make the tubes last longer. They don't need to replace any tubes under warrantee. :lol:
    If the bias is cold, it's less stressful to the PT.
  10. lespaul6
    lespaul6 Member
    Dec 13, 2007
    71
    56
    Florida
    I figured most folks crank the master and attenuate it down so the tubes were getting worked for the last 8yrs... but I could be wrong of course. Here it is with power on ten and master at minimal tv volumes:
  11. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,214
    8,102
    Taintville
    Nice tone and playing Bro!?
  12. solarburnDSL50
    Aug 8, 2008
    15,178
    8,055
    Wetville
    I know Mickey is being accurate. It matters how much much mileage is on them.
    If it was me? Put some new 6550's in. You can't say the mileage yet you know they are 8 yrs old? Id replace them. That's me.
    6550's kick ass. I like 34's too but I'd be right at home with the 6550's feeling I have the amp right in its sweet spot. To each their own.
  13. mickeydg5
    20,036
    7,913
    If they have the bottom through top end and still sound good then do not trash them. If sounding good you cannot tell if worn unless tested on a good tube tester. They may test just as good or better than other new power tubes. Buy another set and compare. Keep a set for backup.
    That is all I am getting at, common sense.
  14. solarburnDSL50
    Aug 8, 2008
    15,178
    8,055
    Wetville
    Always great advice that I'd take. 8 yrs of use and only ears to measure with? I'd replace and keep the 8 yr old as spares. However 6550's are not cheap at a quad.
  15. Mitchell Pearrow
    5,706
    7,156
    Your tone is kicking ass, playing is doing the same, what my brother’s before me said is great advice and they know what there talking about! Cheers Mitch
    lespaul6 likes this.
  16. Chris-in-LA
    Chris-in-LA Active Member
    Jul 19, 2018
    476
    219
    Sounds great to my ear. But, I usually crank the pre-amp, not the master at living room volume. I was under the impression that was more common than the way you described.
  17. MarshallDog
    Nov 28, 2010
    10,214
    8,102
    Taintville
    Thats exactly what Id do!!
  18. Squidhunter
    Squidhunter Active Member
    Feb 5, 2015
    317
    181
    Brisbane
    6550's all the way...I experimented with KT66's and EL34's a few years back, the 6550's were just right, from memory they were just made for the amp it seems.
    Back when the amp was released I couldnt believe some negative posts on what people described as a disappointing amp.
    After owning and playing a shit load of marshals the AFD just kicks ass.
    Its a monster amp!
  19. lespaul6
    lespaul6 Member
    Dec 13, 2007
    71
    56
    Florida
    +100 there is a lot of jubilee in this thing so anyone who loves a good 2555 would love these amps- plus you dont have to have any outboard boost or EQ to get you there- its perfect.
    Squidhunter and Mitchell Pearrow like this.
