Transformer Recommendation?
Discussion in 'Marshall Amps' started by Robert Hanlon, Feb 11, 2019.
  1. Robert Hanlon
    Robert Hanlon New Member
    Sep 16, 2016
    18
    ive got an amp from the U.K. (JVM1H, 1 watt head), can anybody recommend a transformer that would be suitable? The smaller the better as I’d love to tuck it behind the amp if possible
  2. Dogs of Doom
    17,187
    15,086
    sometimes it helps to give a little more info...
    I understand that you live in the States & want a 220v/50hz - 110v/60hz transformer, for the wall.
    tce63 and MonstersOfTheMidway like this.
  3. Dogs of Doom
    17,187
    15,086
  4. ampmadscientist
    10,302
    4,543
    Whereabouts Unknown
    You want to use the correct power transformer, not an external power converter.
    Many times the transformer in the amp will have different voltage taps already built in to change the voltages.
    I recommend you do that the factory way.
  5. Robert Hanlon
    Sep 16, 2016
    18
    I know the JVM1H Doesn't have a way to change the voltage, is there a reason that it's better to use the correct internal transformer rather than an external one? It seems like many people use external, and I'm having a hard time finding someone local that will do it
  6. Robert Hanlon
    Sep 16, 2016
    18
    Bump - Any thoughts?
  7. Mitchell Pearrow
    3,987
    4,052
    I can’t help you brother, but sometimes the other guys that can, may not see it here, also try posting the thread in the work bench section, you will probably get far more responses, we are mostly players and tone junkies here! Cheers to finding your solution! Mitch
  8. ampmadscientist
    10,302
    4,543
    Whereabouts Unknown
    where are you located?
  9. Robert Hanlon
    Sep 16, 2016
    18
    Thanks guys! Located in Minneapolis
