Transformer For Jtm-30
Discussion in 'Amplified Parts' started by Mike.Welch, Mar 12, 2018.
  1. Mike.Welch
    Mike.Welch New Member
    Sep 25, 2017
    6
    2
    I just built a 25 watt hot rodded marshall using 5881 output tubes with 340 plate volts. Amplified Parts has a transformer that works perfectly in that amp. It's a Dagnall 30 watt output transformer with 6.6K primary and 8 and 16 ohm outputs. It's a great price at $42.95. Everything else that is comparable in specs is a lot more expensive.
    Mike
    amplifiedparts likes this.
