Transformer Change Vs. External Transformer
Discussion in 'The Workbench' started by Robert Hanlon, Feb 18, 2019.
  1. Robert Hanlon
    Robert Hanlon New Member
    Sep 16, 2016
    18
    I have a JVM1H that I brought back from the UK to the US. The stock transformer doesnt have a switch, so I etcher. Ed to replace it or use an external one. Is there a merit to either one? Heard here that it might not be a good idea to use the external
  2. Micky
    Apr 29, 2010
    19,691
    15,563
    Vermont
    It is generally preferable to have the amp modified for use in the area where you use it. That way you won't have to remember to bring along the external voltage converter.
    Don't let that keep you from using it, go ahead and use the converter with the amp until you can get the power transformer modified or replaced.
    Dogs of Doom and Ufoscorpion like this.
  3. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,480
    1,078
    It's not a difficult job to fit a new transformer , x2 bolts and a few spade connectors .
  4. ampmadscientist
    10,738
    4,926
    Whereabouts Unknown
    Check inside to see if the existing has voltage taps.
    Call Marshall service and get the right transformer.
    E mail K Dog and ask him if the service center can change it for you.
    kevin.drury@USMusicCorp.com
    The external voltage converters are not made for audio equipment, these are made for hair dryers and shavers. These are made for temporary usage.
    A real step down transformer needs to be made for continuous use.
