Thoughts On The Dsl1 And Dsl20 Heads
Discussion in 'Marshall Amps' started by Shreddy Krueger, Jan 9, 2019.
  1. Antmax
    Antmax Well-Known Member
    Aug 7, 2015
    755
    484
    Brit in California
    That looks sweet. I never tried one in person, and the DSL20 videos I saw weren't that impressive either. I might not have gotten the 20 if I hadn't heard good things from a couple of trusted acquaintances. I bought it new so I could send it back if it was a dud, just in case.
    I mostly use the clean channel with OD, distortion and reverb pedals most of the time and don't use a lot of gain in the ultra channel sometimes with a bit of boost from the overdrive pedal. So not a lot of high gain, sounds great through a 2x12.
    I have a DSL5c I kept and wanted something a bit bigger and usable in a band, otherwise I probably would have looked at the 1 more closely.
  2. scozz
    scozz Well-Known Member
    Jul 20, 2008
    371
    465
    I am so impressed with the Dsl1 they now I want something with a bit more umph! I’m leaning toward the DSL20 combo but I haven’t ruled out the 5 combo.
    The reason I’m leaning towards the 20 is the 12” speaker and the EL34 power tubes.
    I’ve been playing my 1 head thru a 1-12 cab with a G12M-65 Creamback....it sounds great! Some of my favorite settings are....
    ...on the green channel,....volume dimed and the bass and middle at about 12:00, treble around 2:00.
    And the red channel.....volume dimed with the same eq settings as the green channel, and the gain on anywhere from 9:00 to 3:00.
    It sounds phenomenal!
  3. Shreddy Krueger
    Shreddy Krueger Member
    Apr 15, 2018
    47
    48
    Made a decision: I'm keeping the 1w for now. The voicing works for me, and while I love the 20 gain channel for how the depth and the harmonic content, the overall voicing is just slightly different. So -- it's the 1w head!
  4. Jon C
    Jon C Well-Known Member
    May 29, 2017
    360
    487
    Glad you found the one !!! Out of curiosity , did you find the input from the (two) threads that I'm aware of helpful …… and your impression of how the feedback here differed from the feedback 'there' ?
  5. Shreddy Krueger
    Apr 15, 2018
    47
    48
    Thanks Jon -- appreciate it!
    I did indeed, but in the end I kind of just had to ignore the idea that the 20 is the bigger, better amp (which it is!), and I went with which one SOUNDED the best to me, for my purposes. I've gotta say, though, it was close!! Part of me still wants to keep 'em both, but I can't justify it right now without one of the two having a good, chewy clean channel. Both are great on the gain channel, but slightly different voicings.
    Mitchell Pearrow, tce63 and Jon C like this.
  6. Jon C
    May 29, 2017
    360
    487
    How about the feedback from this forum vs 'that' one ?
  7. Shreddy Krueger
    Apr 15, 2018
    47
    48
    To be honest, similar in most respects, but maybe 'kinder' here ;-)
  8. Jon C
    May 29, 2017
    360
    487
    Thanks …… I know you, like most, probably just 'take what you can use' …… I find that the need over there to 'criticize the comments of others in the thread' too often trumps the 'I may be able to help the OP' demeanor of so many ……
  9. Shreddy Krueger
    Apr 15, 2018
    47
    48
    Exactly, man -- exactly that. To be honest, I became so disillusioned with the Internet that I just use it as a resource these days for information (present company accepted, of course!).
  10. scozz
    Jul 20, 2008
    371
    465
    Maybe I missed it,....but what cabinet and speaker/speakers are you playing the 1 thru @Shreddy Krueger?
  11. Shreddy Krueger
    Apr 15, 2018
    47
    48
    Victory vertical 2x12 with celestion v30s -- although, someone is currently twisting my arm over keeping the 20, too. It's probably going to happen!
  12. tce63
    tce63 Well-Known Member
    Aug 6, 2018
    196
    382
    Sweden
    Keep the 20 also if you can afford it, it is a great amp :cheers:
  13. scozz
    Jul 20, 2008
    371
    465
    For what it’s worth I agree with @tce63,...keep the 20 if you can afford it. A couple weeks from now I’ll be buying a 20cr,....I think It’ll compliment my 1hr nicely
    For sure I’ll be swapping out the Seventy/80 speaker that comes stock with the 20cr to either a G12M-65 or a WGS ET65.
  14. Shreddy Krueger
    Apr 15, 2018
    47
    48
    Thanks -- price isn't the issue so much as space at the minute. Definitely want to keep the 20!
  15. Jon C
    May 29, 2017
    360
    487
    @Shreddy Krueger .. I see you decided to keep the 20 as well !!! Good Move Man !!!
  16. scozz
    Jul 20, 2008
    371
    465
    Where’d you see that? I must’ve missed it! :rolleyes: :D
  17. Mitchell Pearrow
    3,423
    3,007
    OP is still on the fence, it’s a space thing, but I told myself not to help twist his arm. :naughty: :dude: :h5: Cheers Mitch
    Shreddy Krueger and scozz like this.
  18. Shreddy Krueger
    Apr 15, 2018
    47
    48
    I went with the 20 after all!
    Mitchell Pearrow, scozz and tce63 like this.
  19. scozz
    Jul 20, 2008
    371
    465
    So you’re keeping them both? Or you’ve decided to return the 1?
    tce63 likes this.
  20. Shreddy Krueger
    Apr 15, 2018
    47
    48
    After a lot of deliberation I've done a complete turn around, and I've decided to keep the 20 and return the 1. The 1w is great, but I don't have the space for an extra head at the minute, so sadly it had to go. I landed on the 20 for flexibility, and the fact that I can take it into the ballpark tone of the 1w with a compressor/EP boost.
