Discussion in 'Marshall Amps' started by Michael Roe, Jan 26, 2019.
  1. Sacalait
    Sacalait Well-Known Member
    Oct 15, 2012
    153
    430
    South Louisiana
    My SV20H does "hiss", especially with the presence knob turned up. It's not a show stopper by any stretch for me. If you want to eliminate it you can put a gate in the effects loop. The noise doesn't really increase with the volume- or not much anyway. Aside from that, I consider the amp a tone beast.
  2. assaf110
    assaf110 Well-Known Member
    Feb 3, 2017
    164
    273
    +1
    T.J. and tce63 like this.
  3. assaf110
    Feb 3, 2017
    164
    273
    With (your) attenuator, set at about -21db , i can't even hear the noise.
  4. Nkyrental
    Nkyrental Well-Known Member
    Oct 31, 2012
    350
    287
    Near Cincinnati
    First used SV20H showed up on local craigslist last week. $1,100. Looked to be in good condition. I think my GAS over this has faded, sorry Marshall.
    tce63 likes this.
  5. Kid_Awesome1
    Kid_Awesome1 Active Member
    Jun 26, 2019
    57
    125
    Jersey
    So it took a while but I finally have my amp and Weber mini mass and I think it works great. I’ve tried it on the 5 watt mode, and I dimed it in 5w, played for a while, then slowly added attenuation and unless tone comes from bleeding ears, this thing does a great job. Highly recommend.
  6. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    921
    1,070
    Why?
    johan.b and tce63 like this.
  7. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,193
    4,772
    Yeah I ended up getting one, I love it. It works great,...with virtually no degradation in tone! I'm getting some great cooking EL34 tones with this little baby!
    These units are hand made, one by one in Kokomo Indiana, USA,....and all for just $136.00!
  8. Mitchell Pearrow
    8,804
    13,439
    :shrug:
    Took to long to try one out, or now has gas for something else ?
    Cheers
    MarshallDog, scozz and tce63 like this.
  9. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,739
    1,665
    Wilton NSW
    With those minimass attenuators, its clear from a number of posts that they are well made and well liked, doing a useful job at a good price.
    But I'm curious about their tone when you attenuate more than few db. The circuit, in common with other Weber models, is essentially a wire-wound pot with the speaker motor partly bypassing it from input to output. From the circuit design, it looks like the tone should lose treble and bass significantly when you turn down to low volume. I was wondering if this effect is noticed in use?
    tce63 likes this.
  10. scozz
    Jul 20, 2008
    2,193
    4,772
    I’ve not noticed a drop in bottom end at low volumes but yes, the high end is affected. There’s a slight loss of high end at low volume. But there are two treble boost toggle switches on the MiniMass to restore that high end,....a 3db boost and a 6db boost.
    I’m using my Weber MiniMass with my Jcm800 Studio, keep in mind, these are bright amps to begin with. So the treble is set very low.
    If I’m playing at very low volumes, I’ll either just increase the treble on the amp or, use the 3 dB treble boost to restore the lost high end.
    JohnH, Kid_Awesome1 and tce63 like this.
  11. Kid_Awesome1
    Jun 26, 2019
    57
    125
    Jersey
    I second this. There's some change as you lower the DB's, but nothing that can't be tweaked out using the amp controls.
  12. Nkyrental
    Oct 31, 2012
    350
    287
    Near Cincinnati
    Not sure, I had one ordered for a couple of months, then they asked if I wanted to stay on the list, I said no. Sort of like the Honda system, make something really good but only sell a few at first, then bring them out in force. It has been months and I have lost my desire for now to get one.
    Why?
    tce63 likes this.
  13. JohnH
    May 31, 2008
    3,739
    1,665
    Wilton NSW
    Makes sense! I reckon if you have a good piece of gear but it has a few quirks, you can usually work around them if they are understood.
    So in similar vien, based on the circuit, its looks like the Weber is best set up for use at 16 Ohms. Its options for 8 and 4 ohms are just by splicing fixed resistors across the input. So you might expect a further flattening of tone, and some overall further db reduction.
  14. WellBurnTheSky
    Mar 23, 2019
    489
    1,142
    As a follow-up to previous discussions regarding a cab to match the SV20H with (and I feel the cab and speakers are a HUGE part of the equation, no matter what the amp, and always should be included in any discussion regarding tone): I just got an EVH 212 cab to use with my SV20H. It has G12H-30 Anniversary speakers.
    And from the hour or so I spent with it so far, it sounds very good. Like, exactly what I wanted.
    I didn't like the high end and midrange grind of the RI G12M (which works great with my DSL100, though), and wanted something as clean and clear as my mid-80s G12T75s, but fuller in the mids (which I liked in the G12Ms), smoother in the top end and equally tight in the bottom end. Also, I never gelled with the honkiness (and weirdness) in the mids of the Vintage 30 (I've played countless cabs that have them), so I knew I didn't want that.
    Well, so far, the cab still sounds pretty bright, as speakers aren't broken in yet, but it's already very balanced and smooth, big bold warm bottom end that's still tight enough for my needs. Also, the amp feels "gainier" than with either of my other cabs, while still retaining its dynamic response.
    It'll see some action next week, as I have 4 gigs in as many days, including some on bigger stages where I'll be able to open up the amp quite a bit. But so far, so good. Super happy with the purchase, and I definitely can recommend it as a good match for the SV. Especially since it's not crazy expensive and seems to be pretty well built (I also like the removable casters). And, notwithstanding the differences in cab construction obviously, I can see why other cabs with Anni. G12H30s would work equally well with the amp.
    tce63, Biff Maloy and Kid_Awesome1 like this.
  15. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    318
    816
    That's good info to know. I have a 2061CX with anniversary g12h speakers. I have thought the same that they should be a good match.
  16. soma1975
    soma1975 New Member
    Mar 3, 2018
    26
    24
    Hi All,
    Just took delivery of my SV20H head and a quick question.
    What is the 'standard' config for jumping channels?
    I play with a Les Paul and a Strat but would like to sort of 'set it and forget it'.
    Thanks.
    K2JLX likes this.
  17. Buzzard
    Sep 14, 2016
    921
    1,070
    Upper right to lower left
  18. soma1975
    soma1975 New Member
    Mar 3, 2018
    26
    24
    Many thanks. Just waiting on a cab to arrive but in the meantime trying it through the WGS G12Q in my 5E3 (with an Iron Man II Mini attentuator). Sounds amazing!
  19. soma1975
    soma1975 New Member
    Mar 3, 2018
    26
    24
    Had a proper play today and I couldn't be happier. The Iron Man 2 Mini Attenuator is a perfect fit for it - to the point where I'm probably going to offload my overdrives and just keep my boosts.
    T.J. and ken361 like this.
  20. Kid_Awesome1
    Jun 26, 2019
    57
    125
    Jersey
    This is correct, though I find I prefer to jumper top left to lower right and plug in top right. Very minor difference but I’m picky. I’m also a fan of just the normal channel (no jumpers) on about 8 with the high channel volume on 10 (again, minor difference but it does have a noticeable effect to me. Will get you a fuzzier bass especially on the neck that sounds glorious on my LPstd
