Discussion in 'Marshall Amps' started by Michael Roe, Jan 26, 2019.
  1. Moony
    Moony Well-Known Member
    Jul 3, 2015
    532
    604
    There's nothing wrong with the volume box in the loop, if that works for you. It wouldn't damage the amp and if it sounds good, it's good! :)
  2. steveb63
    steveb63 Well-Known Member
    Feb 3, 2010
    281
    518
    Az USA
    Quick question,
    Do i need a dedicated volume box, or will the volume knob on my Fulltone Boost work?
    I would be putting it last in the loop.
    Thanks
    Steve
  3. slagg
    slagg Well-Known Member
    Apr 7, 2012
    637
    285
    Cheezeland Wi
    Why does everybody want to cut the Ballz off of this amp?? If it's too loud your buying the wrong amp for your needs.
  4. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    705
    690
    Damn I’m excited about this amp. Was wanting a suhr sl 68 but besides being much cheaper the sv also more practical.
  5. scozz
    scozz Well-Known Member
    Jul 20, 2008
    1,246
    2,400
    Sounds like you should be looking at a Jcm800 Classic instead of a Plexi Vintage!
    LPMarshall hack and tce63 like this.
  6. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    265
    385
    It's an affordable 1959SLP with genuine SLP tone. Whether I take it home, run low volume and hit it with dirt pedals or I crank it and attenuate it, I'm going to be leagues past amps that are intended for low volume use. There is actual depth to the amp's tone.
  7. DesolationBlvd
    DesolationBlvd Member
    Sep 16, 2017
    66
    99
    So actually trying the FX loop volume, it actually sounds pretty good provided I'm slamming the input with the Turbo Rat. Now it approaches the Classic, with higher preamp gain and lower PI/power distortion. Even without the Rat, it still had more gain than the Origin I tried in the store.
    Still doesn't compare to the truer Plexi tone cranked-and-attenuated.
  8. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    846
    583
    Cleveland, OH
    Oh bull. The SV sounds way better than any attenuated amp.
    Thats just ridiculous.
    Kinkless Tetrode and tce63 like this.
  9. marshallmellowed
    Jun 26, 2009
    2,930
    2,549
    I'll be answering this question myself. Once I've finished trying out the SC20, the SV20 is next. You could very well be right, and I intend to find out. I have 3 non master Marshall's and 2 good attenuators on deck, ready for comparison. Most opinions are just that, opinions, not fact. I prefer to use my own ears, they're very reliable.
  10. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,475
    1,421
    Södertälje, Sweden
    You do get a bit of drive from preamp alone on a plexi, but it's nowhere near the combined drive of preamp +power amp.
    Combined they get you 2203 level of drive(that was the design goal of the 2203, according to the mid 70s add).
    Alone, it's more like a milder crunch
    If it was enough to make people used to push a plexi happy, the I'll fated first generation 2204 wouldn't have been revised after only months in production
    J
    Edit, a mild and full sounding o.d. in the loop could compensate for the lost power amp drive, combining with the preamp drive and at the same time work as a master volume. Problem it's, most commercial o.d's cut too much bass for my liking.
  11. Kl75
    Kl75 Member
    Oct 20, 2013
    65
    53
    Good choice of Marshall they did a loop in the amp, now you can get very good tones at any volume.
    I run it with the catalinbread naga vipre treble booster, find the sweet spot on the amp and then control the volume with the volume box.
    I do have a 4104 Marshall to compare it with and I get the same drive at much more reasonable volume.
    But ofcourse it only gets better when you push the output tubes and speakers some more.
  12. Springfield Scooter
    Springfield Scooter Well-Known Member
    Apr 13, 2017
    1,143
    1,318
    Jim Marshall would roll in his grave, if he knew consumers were concerned over a 20 watt Marshall being too loud!
    Mr. Natural, DannyB, Mystic38 and 6 others like this.
  13. Guitardave
    Guitardave New Member
    Jul 10, 2013
    17
    21
    Of course in an ideal world we would all be playing 100w stacks at full volume. But times change, and people want “that tone” at lower volumes. Some people aren’t even in bands and just enjoy playing at home and want the volume even lower. Nothing wrong with that, each to their own :)
    The only real question as regards the lowering of volume with this amp is which is the best way - volume box in the loop, or attenuator between head and cab. I’d love to hear a comparison between the two different ways.
    Mitchell Pearrow, scozz and tce63 like this.
  14. johan.b
    Feb 21, 2015
    1,475
    1,421
    Södertälje, Sweden
    ... but that's why marshall developed the master volume amplifiers.
    So that you could get "that tone" at a lower level... and I for one, thinks they did a great job..
    J
  15. Kl75
    Kl75 Member
    Oct 20, 2013
    65
    53
    I tried an EHX soulfood and an eq pedal in the loop, both didn't work very well. Volume box works as a real master volume, it has a very balanced sweep, but that's just my opinion.
    Mitchell Pearrow, tce63 and steveb63 like this.
  16. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    974
    2,112
    Springfield, Ohio
    Just to clarify ( from an actual SV owner ):
    The SV is NOT a bedroom amp. Even in 5 watt mode it is LOUD as F@*K!!!!!
    This is the nature of a Non master volume amp. So, bedroom use will still require an attenuator.
    Will the SV sound identical to a real 1959? Probably not. Will two real 1959's sound identical? Probably not.
    Is the SV just a more expensive version of the Origin? Absolutely not! The SV will smoke the Origin for that authentic plexi tone! The SV has 4 holes and reacts like the real deal. The "tilt" knob and "master volume" and gain "boost" on the Origin make it another animal. No apples to apples here.
    If you want a "Plexi-ish" tone at bedroom volumes then get an Origin. They do that well. A DSL on the Classic gain Ch will get you there as well. Authentic? No, but in the ballpark.
    So, what purpose does the SV serve? An authentic designed and sounding amp that is more easily tamable to the big 1959. Attenuate 3 db off of a 5 or 20 watt amp is going to probably sound better than -8 db off of a 100 watt monster. Will they sound identical? NO!!! neither does your 1959 using an attenuator.
    Added bonus: It is smaller, lighter weight and only requires two PTs and I don't have to bias.
  17. scozz
    Jul 20, 2008
    1,246
    2,400
    I’ve got a question,....
    How do the two volumes on the Studio Vintage, (loudness 1 high treble, loudness 2 volume), work together?
    tce63 likes this.
  18. steveb63
    Feb 3, 2010
    281
    518
    Az USA
    Thanks for the reply.
    I have an empty effects box enclosure, looks like I need to source a potentiometer and get to soldering .
    Will report back on my findings .
    Steve
    Kl75, Mitchell Pearrow and tce63 like this.
  19. Michael Roe
    Mar 25, 2017
    974
    2,112
    Springfield, Ohio
    Think of it as two separate preamp chs. To use them "together" you have to jump the channels. The common way is to plug your guitar into the high input of CH 1 and then use a small cable to go from low input of ch 1 to the high input of ch 2. You are effectively plugged into both chs. This will allow you to adjust to your taste how much of ch 1 compared to ch 2 you want. Want more bass, turn up ch 2 want more treble, turn up ch 1.
  20. KelvinS1965
    KelvinS1965 Well-Known Member
    Nov 22, 2015
    182
    286
    As I understand it they are like two separate inputs. If you use a jumper cable between 1 and 2 inputs (to join them together) then you can plug your guitar in either of the other inputs and then balance the two volume controls (one sounds brighter and the other is lower gain/darker) to get the sound you want.
    I'll know for sure by Tuesday. :)
    EDIT: Mich beat me to it.
