Discussion in 'Marshall Amps' started by Michael Roe, Jan 26, 2019.
  1. Nik Henville
    Jul 18, 2018
    958
    1,457
    A square-wave is a square-wave.
  2. Guitardave
    Guitardave New Member
    Jul 10, 2013
    17
    21
    How loud is that? Are you using an attenuator?
  3. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    853
    604
    Cleveland, OH
    "Band" loud but not ear bleeding. I use a small Clear Sonic shield to deflect some sound.
    I gave up on attenuators. They only retain good tone at -3db.
    67Mopar and Mitchell Pearrow like this.
  4. K2JLX
    K2JLX Well-Known Member
    Apr 20, 2018
    295
    582
    New York
    All these complaints about popping in the loop when you turn on/off a pedal: I didn’t have that issue, mine pops with two pedals in the front of amp. My chain there is. Compressor->od/boost->vibe
    Doesn’t do it on my 2203 plugged in the same way. Any ideas ?
    Edit. It’s the bogner Lagrange and bbe soul vibe that pop. Both are true bypass: the boss compressor is silent on switch on/off.
  5. marshallmellowed
    Jun 26, 2009
    3,132
    3,072
    But Segeborn says "So, let's go", before he plays the same riffs, over and over. No one else is doing that.
  6. marshallmellowed
    Jun 26, 2009
    3,132
    3,072
    I would guess the input circuitry in the 2 amps is different in some way.
  7. Springfield Scooter
    Springfield Scooter Well-Known Member
    Apr 13, 2017
    1,143
    1,323
    2203 had no loop!
    tce63 likes this.
  8. marshallmellowed
    Jun 26, 2009
    3,132
    3,072
    I was actually referring to the 2203 reissue. When I re-read his post, I think he was actually referencing popping/no popping on pedals placed in front of the amp(s). Either way, I have no popping issues with the loop in my 2203x, so let's just say the loop in the 2203x (2203 reissue) is apparently a better designed loop than what they're using in the Studio amps.
  9. Guitardave
    Jul 10, 2013
    17
    21
    I’m wondering if it’s useable as a home amp? I guess without an attenuator I’d be having to use pedals to get any decent drive tones out of it, which kind of defeats the purpose :-/
  10. rich88uk
    rich88uk Well-Known Member
    May 25, 2009
    688
    683
    Liverpool,UK
    Depends how loud you can have it at home. Even in the 5 watt mode, cranked it will still be loud.
    Del Rei, Mitchell Pearrow and tce63 like this.
  11. SlyStrat
    Jan 7, 2011
    853
    604
    Cleveland, OH
    Defeats the purpose??? Its not made for a bedroom amp. But its way more useable than a 50 or 100 watt amp.
    Just buy a small power solid state amp for bedroom.
  12. Guitardave
    Jul 10, 2013
    17
    21
    I’ve got a Friedman Runt at the moment which has got a really good master volume so sounds great at home. I guess this new Studio Vintage isn’t really going to suit me from what’s being said. I was kind of hoping an attenuator wouldn’t alter the tone so much :-/
  13. Mystic38
    Mystic38 Active Member
    Oct 19, 2015
    209
    170
    while it is fair to say that the tone of any low gain amp relies on power tube distortion, you could at least try putting a true clean boost such as the Dunlop MC401 in front of the amp and then a volume/attenuator in the loop. You will then get the pre-amp to distort but run the power section pretty clean.
  14. Guitardave
    Jul 10, 2013
    17
    21
    Rather than running an attenuator after the power amp between the head and cab?
    Jakeboy likes this.
  15. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    807
    867
    Anyone know if the 5w setting sounds good for micing in smaller clubs?
    tce63 likes this.
  16. tce63
    Aug 6, 2018
    903
    2,171
    Sweden
    I haven´t got mine yet but i have the Mini 2525C and it works great without micing in smaller clubs in 5w mode, i run it with a Betabuddy and a Maui LD 28.
    In a band situation i think i would go with 20w mode.
    Kinkless Tetrode likes this.
  17. Mystic38
    Oct 19, 2015
    209
    170
    Sorry for the confusion, i didn't mean attenuator as in a power amp attenuator soaking away the Watts, I meant attenuator as in the case of a "volume control" .. so signal level rather than power level..
    something like..
    https://reverb.com/item/9672-carl-s...e_hiW-lmavWc0aAr9lEALw_wcB&gclsrc=aw.ds&pla=1
    or
    https://www.americanmusical.com/Ite...O2XRjU0L6yY2p9O8sL6atARKUZzdDrRsaAnnQEALw_wcB
    iirc these are both passive so if the fx loop is unbuffered, you may want a buffer in front of these to prevent tone suck
  18. Medronio
    Medronio New Member
    Apr 16, 2014
    20
    8
    Anybody compared the studio vintage to the 1987X?
    Cost the same (new vs. used), and the sound?
  19. Pageburst
    Pageburst Member
    Jun 26, 2017
    74
    85
    I too would love a lower watt plexi and had considered a 2061 or 1974
    The new Sv20h looks interesting. However, after viewing the gut shots, to me it looks cheaply made. I'm guessing the transformers are Asian sourced and not Drakes? Just based on perception, Marshall's earlier PCB amps and PCB amps from Friedman, Mesa etc., appear to be better made. But, I'm no expert so maybe someone more knowledgeable can chime in here
    The Sv20h does sound good in clips, I just wouldn't want to be busy with issues. If I don't find a good vintage 2061 or 1974 I might give the Sv20h a try. That said, I wouldn't call a 2061 or 1974 anemic by any stretch of the imagination.
    67Mopar and kustombob like this.
  20. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,626
    2,544
    I wonder if that Michael R/T mod can be done to these?
    Kris Ford and DesolationBlvd like this.
