The Official Marshall Origin 50 Thread
Discussion in 'Marshall Amps' started by MarshallDog, Apr 27, 2018.
  1. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,814
    9,082
    Taintville
    :agreed::applause:
  2. solarburnDSL50
    Aug 8, 2008
    15,449
    8,632
    Wetville
    Plate voltage gives the range. Fine tune it from there and you got it. Ears and fingerz based off the PV. The sweet spot exists.
    Fucking slaves to the PV! Or burn your glass or crystallize it. Either of these I hate.
  3. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    Yeah I thought that was an ignorant statement coming from someone at Marshall.
  4. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    So to answer part of your question, the Origin 50 head cab is about 2 ½ inches shorter than a 1987 head cab but the Origin 50 chassis fits nicely inside it.
  5. recto-robbie
    recto-robbie Member
    Jul 19, 2007
    53
    15
    Chicago
    True about the range, but with only one trim pot, then each tube can't be dialed in individually. Best have a matched pair.
    SlyStrat likes this.
  6. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    846
    583
    Cleveland, OH
    Thank you!
    It looks good in the 1987 cab.
  7. MarshallDog
    Nov 28, 2010
    10,814
    9,082
    Taintville
    What is causing this change in cabs???
  8. SlyStrat
    Jan 7, 2011
    846
    583
    Cleveland, OH
    He is showing me how the Origin fits in the cab. That tells me it will fit in a Bluesbreaker type combo cab.
  9. MarshallDog
    Nov 28, 2010
    10,814
    9,082
    Taintville
    Oh so you bought the head version and may want to convert it to the combo version, I got it. Did you not like the combo aesthetics?
  10. SlyStrat
    Jan 7, 2011
    846
    583
    Cleveland, OH
    I like the 50 combo and keeping it.
    I might buy a 50H too. I want the option of putting it in a combo cab if I need it.
    Yes, I really like the 50 Origin.
  11. MarshallDog
    Nov 28, 2010
    10,814
    9,082
    Taintville
    Cool...the Bluesbreaker combo cabs always look beautiful!
  12. sjruvolo
    sjruvolo Member
    Aug 7, 2015
    60
    35
    Why not put bias points on an amp that needs to be biased when changing power tubes. 65 mv/ma could be right with 2 tubes that are matched but why all this confusion with a new amp. I'll wait for their new and improved version that will come out eventually. I really wanted to love this amp. A simple amp with just enough drive/crunch that could be pushed a little harder with a pedal. For now the DSL is where it's at for me. Just wish that Marshall would have made the DSL in 40H or 50H watt. I have the DSL20HR (new and improved) and I'm lovin it.
  13. SlyStrat
    Jan 7, 2011
    846
    583
    Cleveland, OH
    I dont like any DSL.
  14. sjruvolo
    sjruvolo Member
    Aug 7, 2015
    60
    35
    If the DSL is not for you then I get it. In the Classic gain channel you could push the gain to a "light crunch" and boost it with a drive pedal. The DSL20HR gives me some concern that it might not have enough with a heavy handed drummer and some other like minded accompanying musicians. This is why i so wanted the Origin 50H to be "the' amp.
  15. Jerbear114 tnt
    Jerbear114 tnt Member
    Apr 20, 2018
    27
    43
    I have a origin 20h can I put a ecc83s pre-amp tube (phase inverter) tube in v1 ?
  16. MarshallDog
    Nov 28, 2010
    10,814
    9,082
    Taintville
    I believe all the pre-amp tubes in the 20H are just like the ones in the 50 which are all 12ax7/ecc83/ecc83s.
  17. Jerbear114 tnt
    Apr 20, 2018
    27
    43
    yes they are, but and this might be a dumb question but one of the pre amp tubes is phase inverter is that ok ?
  18. MarshallDog
    Nov 28, 2010
    10,814
    9,082
    Taintville
    A simple mod I did:
    I added (2) 5600 pF caps, in parallel for a total of 11200 pF, across the middle and right legs of the mid pot (when the chassis is upside down and you are looking at the back of the pot. It really makes the Tilt feature more usable and it reduces the thinness of the upper high freqs making the amp sound thicker, deeper (not dark at all)...I frickin' love it!!!!! I also have the Mullard EL 34 PTs and Mullard 12ax7/CV4004 tubes in it. I went back to the Celestion Creamback G12M-65 speaker and its tonal old school lower gain Marshall bliss...wow. Blues yes way and add a bit of OD to it and AC/DC perfectly. I strongly feel that any amp that sounds great in head form needs that cap across the mid pot when its placed in a combo due to the open back. Marshall added a 4700 pF cap across the pot on the old JCM 800 vertical input combos way back. Just my two cents.
    ColonelForbin and SlyStrat like this.
  19. MarshallDog
    Nov 28, 2010
    10,814
    9,082
    Taintville
    Yes...
  20. Jerbear114 tnt
    Apr 20, 2018
    27
    43
    thanks
