The Official Marshall Origin 50 Thread
Discussion in 'Marshall Amps' started by MarshallDog, Apr 27, 2018.
  1. solarburnDSL50
    Aug 8, 2008
    15,443
    8,619
    Wetville
    too cool! I'll be trying one out then.
  2. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,774
    9,032
    Taintville
    It really delivered last night for my playing style!
    solarburnDSL50 likes this.
  3. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    I opened up the Origin 50 head today for the first time wanting to roll some tubes. I have been happily playing the amp in it's stock form up until now but I wanted to mix things up a bit to see what other tubes will bring to the table. For the life of me. though, I cannot finds the bias points for the power tube swap (I see the trim pot btw).
    I am including images of the board. Can someone please point them out?
    I am going to try some mallards and a pair of EHX 6CA7s in the power section and just roll though my collection of preamp tubes.
    Also I am going to swap out the speakers in my 4x12 from 2xVintage 30s / 2x WGS ET65s to 4x G12K-85s to check out a different flavor.
  4. solarburnDSL50
    Aug 8, 2008
    15,443
    8,619
    Wetville
    These aren't cathode biased? I can't see a trim pot...it's early and my eyes are still not focussed
  5. sjruvolo
    sjruvolo Member
    Aug 7, 2015
    60
    35
    No Bias trim pots. Just swap the power tubes and play.
  6. J Saw
    J Saw Well-Known Member
    Apr 26, 2017
    320
    440
    VA
    3rd pic top left. That's a trim pot. Don't know what its for but it's there
  7. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    So just like the Origin 20, the Origin 50 needs no bias adjustment when swapping power tubes?
  8. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    Ok. So I tried the Mullards... they sounded nice but smoothed everything out too much for me. I then put in the EHX 6CA7s and WOW what a difference. The thing fuckin' growls hard now.... no pedals in front of the amp. I haven't even done anything with the preamp tubes yet. Also, the combo of WGS ET65s and Celestion G12K-85s definitely add more tight bass response.
  9. MarshallDog
    Nov 28, 2010
    10,774
    9,032
    Taintville
    Its that little black pot in the lower picture. Its the one in the upper left corner next to the little black chip..
    J Saw likes this.
  10. MarshallDog
    Nov 28, 2010
    10,774
    9,032
    Taintville
    Wrong, the 50 needs to be biased.
  11. MarshallDog
    Nov 28, 2010
    10,774
    9,032
    Taintville
    I would like to know what resistor(s) is the choke resistor in this amp??? I would like to replace it with a real ClassicTone 3 Henry choke I have. Anyone have any idea???
  12. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    Ok. That's what I thought I had heard. I will need to bias the tubes that I just put in. So I see the trim pot but where are the actual bias points to connect my multi-meter?
  13. MarshallDog
    Nov 28, 2010
    10,774
    9,032
    Taintville
    Not sure about that, I use the Weber BiasRite meter.
  14. solarburnDSL50
    Aug 8, 2008
    15,443
    8,619
    Wetville
    One trimmer for both tubes. That's cool. I prefer 2 trimmers so I don't need matched tubes but one works fine when matching.
  15. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    Ok. I guess I will bias it old school like my 2204.
  16. Snowdogyyz
    Snowdogyyz Member
    Feb 19, 2018
    64
    66
    Using some recommendations from here, I installed the eminence swamp thing and also installed a Tung sol in V1 and V3 (paid a little extra from tubestore for higher gain/low microphonics for V1) and a Mullard in V2. The amp sounds even better now. “Fuller” with a little more bottom and tamed highs. Still dialing it in and breaking the speaker in, but I’m very pleased with it already!
    MarshallDog likes this.
  17. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    846
    583
    Cleveland, OH
    Is the 50w head the same size as a Marshall 1987X or JTM45 RI?
    I want to know if it will fit in a Marshall "Bluesbreaker" style combo cab.
  18. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    That’s a good question. I have an empty 1987 Marshall Head shell. I will test it out and get back to you.
    SlyStrat likes this.
  19. masahs
    masahs Member
    Dec 23, 2009
    29
    34
    Princeton, NJ
    IMG_4608.jpg I just reached out to Marshall about the bias points. Marshall did not add the bias points but they did show me where the solder pads are. These can be used with your multimeter to bias your tubes. Look for CN32 on the board (See attached pic). They also recommended to bias to 65mV... take it or leave it.
    6StringStewie likes this.
  20. SlyStrat
    Jan 7, 2011
    846
    583
    Cleveland, OH
    You cant just set the bias at 65. Thats stupid. Every tube needs to be dialed in based on plate voltage.
    And to add: most Marshall amps I've biased are more in the 30-40 range.
    masahs and MarshallDog like this.
