The dsl joey mod thread
Discussion in 'The Workbench' started by TwinACStacks, Apr 5, 2010.
  1. Cascadem
    Cascadem New Member
    Aug 4, 2016
    29
  2. guitardude57
    guitardude57 New Member
    Nov 29, 2016
    23
    5
    I have a DSL 40C here, with the board DSL 100-60-00 Series one. Has the single large board. Have you a schemo and mod list for this creature? All my schemos for the DSL stuff does not really match up.
  3. 6StringMoFo
    6StringMoFo Well-Known Member
    Feb 6, 2010
    1,521
    561
    Halifax, NS. Canada
    Someone has the resources to translate?
    My Main board is a JCM2-60-00 ISS20
    My front board is a JCM2-61-00 ISS345
    Looking to translate this components.
    JCM2 60-02 iss5 (Tube) AND JCM2 61-00 iss1 (Front)
    Front Board:
    NOTE: THESE MODS AFFECT THE RED LEAD 2 MODE ONLY (removing C12 will also darken Lead 1)
    1M Resistor from Wiper to Ground on Vr3 **** (DONE)
    C12 Lower to 150pf or REMOVE (I removed it) (DONE)
    C10 replace with .0022 uf
    R20 Remove and JUMPER
    **** These can be bridged on the other side of the Board. Find the 4 Pins that are the Actual Pot terminals, (Not the Two Board mounting pins), follow the Traces. The inner one that has R19 on it is the WIPER, the outside one that connects to Con 5 pin 2 is the Ground. ( Using your meter set to continuity works well here) Solder your 1M across these 2 pins leaving the legs long, then bend flat to board using a piece of electrical tape attached to the board to insulate the leads from accidentally shorting out to any other exposed solder connections. Electrical splicing tape works quite well here as it adheres to the board better than vinyl electric tape.
    Mainboard:
    NOTE: THESE MODS AFFECT ALL CHANNELS/MODES
    C9 replace with 1000pf (.001uf) 500V
    C12 replace with 1uf 63V
  4. 6StringMoFo
    Feb 6, 2010
    1,521
    561
    Halifax, NS. Canada
    Aye, Marshall sent me all their schematics hah. I'm doing the mods now.
  5. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,582
    1,669
    Södertälje, Sweden
    Another thing you can do is increase r21 (referring to old schematics) on the pot board to 470k-1M. It's originally 150k and it cuts low end in od1 to keep things focused. But it's too much and makes the bass eq knob ineffective and the channel thin compared to green channel. Increasing it restores the low end and makes the bass knob effective again. You can cut it out all together, but bass will be very compressed and fuzzy. .some might like that though. ..choosing value is a balancing act and some compromise will have to be accepted, but it's about restoring the low end that was lost where as the c12 mod is compensating by cutting the high end too..i preferred it this way, but someone else will have to try and say what they think.
    j
  6. Stamminen
    Stamminen New Member
    Aug 17, 2016
    13
    Quick question guys, I'm planning on doing the C12 mod on my 2003 DSL50 once I decide to open her up. Finding the red channel to be to brittle like everyone else.
    Instead of clipping it completely I'd like to replace it with a different value. I don't know much about caps, but is this what I should be buying? Link is to an eBay seller. If I need a different kind of cap let me know.
    I'm planning on possibly trying a 68pF, 100pF or 150pF
    Thanks!
    http://www.ebay.com/itm/322359203629?_trksid=p2060353.m1438.l2649&var=511281869560&ssPageName=STRK:MEBIDX:IT
  7. dslman
    dslman Well-Known Member
    Apr 15, 2012
    2,525
    974
    Sorry you didn't get an answer, I don't get to this thread much any more, and looks like I'm not the only one.
    The answer to your question is yes. I went with a 331pf cap in mine. Tried several values as well as clipping it--which sucked the sting and gain out of the amp.
    Mine is a DSL50 also.
  8. dslman
    Apr 15, 2012
    2,525
    974
    Here's a added safety touch for the ohm selector switch on the 2K DSLs,
    I saw a video where the tech. had a problem with the switch , since it is only connected by the solder pins.
    After he repaired the amp he put some hot glue around the outside of the switch and the chassis, for more stability. This may be splitting hairs, but I did the same.
    Should be a bit more sturdy when using the switch.
    RickyLee likes this.
  9. Razvan S.
    Razvan S. New Member
    Jan 31, 2017
    5
    2
    Hello
    I have been lurking for some time on this thread. I would like to thank Joey for his work, it is priceless!
    I want to add here, the 60-00 version transcription from the thread version with the Notation changes.
    Note the modifications in bold with yellow.
    PLEASE correct me if I am wrong, but I have already rechecked and everything looks right(LE: rechecked now, I can assure that everything is OK :) ):
    I did a simple comparison, and here is transcription for the 100W 60-00 version (from the one in the thread, the 60-02 version), for the Tube (main) board.
    The FRONT board, is the same. So no changes there.
    I want to mention that I did no mods to my amp, and I honestly think it sounds great as is, even at low volumes; however I see that on the 60-00 version, there are some changes and this would suggest why it is sounding better “stock”. The 10K being stock (recommended 5k6 by the guys here) instead of the 220K stock on the schematic. Also, C46 is missing entirely.
    Maybe in the future I will try out some stuff, and jumper everything.
    I have a 2009 Model.
    In brackets I have mentioned with "was'' the notation which is for the 60-02 version, and in the front for the 60-00 version.
    Frontboard(no changes)
    Mainboard:
    NOTE: THESE MODS AFFECT ALL CHANNELS/MODES for 60-00 version:
    C4 (was C9) replace with 1000pf (.001uf) 500V
    C7 (was C12) replace with 1uf 63V
    Now if You find that the overall texture of the amp is, or has become too dark:
    Mainboard:
    Replace R18 (was R30) (470k)with 68k to 220k resistor this will Decrease the Fizziness and the OVERALL GAIN as well and also brighten the Amp. I personally Piggybacked, (using a pair of test leads), a range of resistors across the Legs of R18 (was R30) from 82k to 1M and decided I liked 1M the Best. This brought the Value of R18 (was R30) to 320k. I then soldered it in place across the legs of R18 (was R30). This way it is easily changed if I decide on a different value without pulling the PIA Mainboard!!! This particular Mod is pretty much season to taste. One of the Techs or Myself can figure out what value you need for "Piggybacking", or you can try and figure it out yourself:
    R1XR2 Divided By R1+R2= the Total resistance of Both Resistors combined. Use the Value of R18 (was R30) (470)k for Resistor1 and the resistor You want to try as the value for Rresistor2. (Try: 82k, 120k, 220k, 330k, 470k and 1m)
    Also if You find that the Green CRUNCH Mode is too boomy especially with the deep switch engaged:
    Frontboard(NO changes here for notations, because they are the same!)
    C8 replace with .001uf to .0022uf (I used .0015uf)
    Here's a link: http://www.mouser.com/ProductDetail...EpiMZZMsh%2b1woXyUXjyBw8LYChpgf%2bpPFAhHPmAM=
    THESE ARE THE EXTENT OF THE ORIGINAL MODS.
    Now THIS is the "while You are in there" section of the Mods that SHOULD be performed.
    C46 if You have one (this does not exist in the 60-00 Version!!). This is an underspeced Cap that apparently is to prevent parasitic oscillations. It can short out and Take out the board it's on, as well as your OT. Either CUT it OUT or replace it with a +1000V version of the same value (22pf). I say "apparently" because I have heard nothing about anyone experiencing oscillations after removing this cap completely.
    Change out the Grid Blockers on the Mainboard. Most versions have 220K in place, replace with a more normal "Marshall" value 5k6 resistor. I'm of the understanding Alan Bradley Carbon Comps are suited quite well for this, I used regular +/- 5% carbon films from Radio Shack that I had on hand.
    The locations for these are: R55 (was R7), R70 (was R10), R58 (was R66), R62 (was R70)
    (ironically, mine were all 10K (??weird) on the 60-00 version, which is close to 5k6 and I wouldn’t bother changing these, if you have the same on the 60-00 version)
    Also because of frequent run-away biasing problems That appear to be temperature related, Upgrade the Bias resistors. I suggest a more temperature-stable precision metal film 1/4 to 1W, PRP or Vishay Dale.
    Here is a link for the PRPs: Sonic Craft High-End DIY Audio Parts
    The locations and Values of the Bias resistors are: on the Mainboard
    R60 (was R68) 33K
    R71 (was R77) 10K
    R59 (was R67) 220K
    R61 (was R69) 220K
    One last preventive measure, On the rear of the chassis the speaker output jacks should have separate grounds installed. the 4&8 ohm jacks are grounded through the 16 ohm jack, (which Bypasses via an open/close contact), the 4&8 Ohm jacks when the 16 Ohm is used. Sometimes this contact doesn't close because of Dirt etc. so when You are plugged into the 4, 8, or Both, the Amp is actually seeing No load at all and: Bye-Bye OT and Maybe more. If You use only the 16 Ohm jack this is not a concern. This can be accomplished by soldering a short piece of wire to the shoulder of W6 Ground connection and to one of the metal bands on either the 4 or 8 ohm jack that is closest to the inside rear surface of the Chassis. When this is done however there will be no auto disconnect. ALL 3 jacks will be active ALL the time. Please DO NOT try and run 3 Cabs at the same time!!!
    Now for the FUN Stuff:
    Replace the OT and Add a Choke.
    Add a 3H Choke at the R63 (was R71) Resistor (270R 7Watt) on the Mainboard. Remove R63 (was R71) and connect the two wires for the choke in its place. You can mount it behind the power Trans at the Rear of the Chassis. You will need to swing the Powerboard out of the way for drilling. TIP: Because this resistor is mounted with a LOT of solder, (and I was a little afraid of overheating and lifting the traces), I simply snipped the body off the Legs and soldered my wires directly to the leg remnants. Very un-professional and very effective.
    A MAJOR sound Modification is the replacement of the puny Stock Dagnall OT. JCMJMP has drop in replacements on: Marshall DSL
    Also they are available from Mercury Magnetics, I believe Jon deals in these. Because I had a deal fall into my lap, I used a replacement for a 100 Watt Plexi: a Dagnall C1998 or the Later version C2668. These you can find on Ebay or VERY good Clones from Marstrans or Metro Amp.
    dslman likes this.
  10. Razvan S.
    Jan 31, 2017
    5
    2
    BTW guys, wouldn't the 3H Choke make the amp kind of loose? Wouldn't a 5H or even a 7H be better?
    Thanks!
  11. DonP
    DonP Active Member
    Jan 28, 2009
    116
    55
    Cincinnati, OH
    There is magic in 1998 or there is not?
    The reason I ask is that I have a 1998 Orange Crush which I bought new. No modifications yet. Original Wing =C= Tubes biased at 35ma each. I'm a bedroom player so this half stack has never been abused.
    I have always been happy with the sound. Had many people on craigslist come over and say it sounded great.
    I don't have any issues, but I'm tempted to do some reliability mod (C46, 5K6 for the grids, output jack grounds even though I only use 16ohms).
    I'm curious if you still like your '98, and if you think the choke was a good addition.
    Thanks.
  12. RickyLee
    May 22, 2010
    9,623
    3,106
    Riverside CA U.S.A.
    Hmmmm. I am confused by myself on that first quote from me above LOL. Was I talking about my 1998 DSL100? As for the '98 DSL100 compared to my 2005 (I think that is the correct year LOL) DSL100 with both of them being in stock from the factory form, the '98 was quite a bit different tonally, in a much better way all around. The '98 does not have as much disparity EQ wise going from the Green to Red channels. The Red channel on that amp is actually the highlight, mainly Lead 1. When I first got it, took it to my friends for a jam and my singer from my then cover band and quite a few musician buddies were blown away by how great it was sounding. And quite a few of them have no idea about the DSL amp history.
    I know I had swapped all transformers in the 2005 DSL100 and installed a 3H choke as well. But I am not remembering installing a choke on my latest '98 DSL100. I have way too many amps to keep track of and my memory must be getting worse too LOL. Would have to check that but the DSL is somewhat buried away right now.
    Did I mention somewhere in this thread about adding a choke to the '98 sometime in the last two years?
  13. DonP
    DonP Active Member
    Jan 28, 2009
    116
    55
    Cincinnati, OH
    I thought you said you did on a prior post in this thread.
    After thinking it over, I've decided to leave my 1998 stock. It's been a great amp for 20 years, so why mess with a good thing.
    Thanks.
  14. RickyLee
    May 22, 2010
    9,623
    3,106
    Riverside CA U.S.A.
    Yes, I did put a 3H choke in that '98 DSL100. Had to refresh my own memory.
    I have some clips of that amp in action from a few gigs, before the choke was installed. That is to this point the only mods that amp has. Oh yes, I think I also upgraded all the components in the bias circuit, which is not really mods in my book. And did the speaker jack ground fix as well. But otherwise, that amp is awesome in stock form. My 2005 was another story for sure.
    Are you inquiring about a 1998 Orange amp? Or is it a 1998 DSL 100 that you also have?
  15. dslman
    Apr 15, 2012
    2,525
    974
    Did your 98 have Drake trannies? I imagine that along with a choke means a lot.
    The few 2K 100's I went through all had Dagnal's and I felt they were always a bit sluggish.
  16. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,699
    2,257
    Oregon
    I have a 2000 DSL100, and it always sounded great. Played it live for years.
    I have had four different TSL heads (sold years ago) and three out of four sounded quite good.
    Just a guess, but it could be tranformer inconsistancy that causes some to sound "not great"??
    I swapped power trannies in the best sounding one, and the worst sounding one, and they switched around.
    By bad, I mean kinda harsh/lifeless no matter what tubes or bias.
    My DSL100 has a Mercury output tranny and choke, and I removed the bright caps from both channels.
    I did no other mods, other than swapping out the bias resistors to high heat metal film, and lowering the grid block resistors
    from the 220K (yuck) to carbon comp 5.6K.
    It sounds KILLER through every cab I have plugged in to...especially vintage cabs :)
    IMHO, those amps are plenty bright...no need for any bright cap, even a lower value, will still boost the fizz on top.
    If your speaker cab is healthy, a bright cap shouldn't be required, IME.
    Without one, you can then turn down the gain to 5 or 6, and get more vintage bluesy crunch tones, without the thin brightness.
    Unbelievable that Marshall put a 470pf bright cap in those amps. OUCH.
    I recently discovered that the JJ 6CA7 made my DSL sound incredible. Balanced and crunchy and alive, without too much bass.
    I have used E34L and EL34II in it before, and liked the EL34II the least.
    I also bias mine way lower than the 90mv per side recommended. More like 82mv or so. Much better tone and definition.
    My two cents
  17. RickyLee
    May 22, 2010
    9,623
    3,106
    Riverside CA U.S.A.
    I am thinking only 50W DSL50 amps had the Drakes, and then that was not for long. Maybe first year or two? 1997 only? Then they all went to Dagnalls.
    I am not knowing of the old JMP's, but with the JCM800, the 100W amps had Dagnall and the 50W amps had Drakes. The Dagnalls were high quality up until around 1990. At least that is my opinion. Even the Drakes changed during the JCM900 era as they went to those laydown output xfmrs which seemed to be a bit smaller. Maybe I am wrong on the latter and they did not get smaller? Sure seems that way when I look at my JCM800 50W amps compared to my JCM900 MK3 and JCM900 SL-X 50W amps.
    dslman likes this.
  18. RickyLee
    May 22, 2010
    9,623
    3,106
    Riverside CA U.S.A.
    I agree about the possibility of the JCM 2000 transformers being a bit inconsistent. Could be partly why my '98 sounds so amazing. I know Adrian is the biggest advocate here for upgrading the DSL iron and adding a choke. But I have never been 100% on that side of the fence. My reason is my first TSL100 which is a 1998. That amp has the first Classic Tone DSL100/TSL100 power transformer made. I sent them my TSL100's power transformer to reverse engineer and they gave me the PT for my effort. I then later upgraded the output transformer to either the Clasic Tone . . . . or was it it the Lydian? Dam my memory is getting bad man LOL. Anyway, I did notice some increase in bandwidth slightly. But I ended up thinking the original output xfmr had a sweeter tone, almost like it would go into early saturation and give up sweet harmonic blooming and overtones. Then to where the upgraded OT had more headroom and did not have the same sweet character. My thing with these amps is opposite of what everybody preaches they are designed for . . . . I do not care for a clean power stage. I want some breakup and saturation in my power amp stage.
    Interesting you bring up those JJ 6CA7's. I have been thing about the sets I have stashed away from many many years ago. I did some testing with them all those years ago and I was blown away how they responded in a few different amp heads. The big shocker was my 2500 SL-X. Wow. I need to revisit those and try them in my JVM410H and my hot rodded 2204 build.
    Lately, I have been getting this urge to go back inside my 2nd TSL100 which is the 2005 model. I did a few minor things to it already, but I am considering doing a major hacking to that thing. What keeps me from digging in is the pain in the ass they are to work on . . . .
    :D
  19. dslman
    Apr 15, 2012
    2,525
    974
    I did the Classictone O/T and Choke on my 2004 DSL50. It did change the tone a bit, but I am pleased with the change , and the tightness that was added.
    I can only imagine the 100 would be similar, and should also quiet down those noisey Dagnall's.
  20. RickyLee
    May 22, 2010
    9,623
    3,106
    Riverside CA U.S.A.
    You just reminded me that my 2005 DSL100 did have some slight vibration type buzz noise on its stock power transformer.
    The Classic Tone PT upgrade is supposed to have a 10% reduction in the power supply voltage, which is good for these amps and the power tube life in general. Plus it would help to reduce the high voltage that these amps see on the V3 12AX7 cathode follower position. I think the latter is why people see certain 12AX7 brands fail in that location.
    The power transformer Classic Tone made for me did not have 10% lower secondary HT, but it lowered my B+ about 10V -15V. I would liked to have about 30V - 40V reduction as my wall voltage here where I live runs about 125VAC.
    dslman likes this.
