Supro Thunderbolt Build
Discussion in 'Building the Classics' started by Timbo, Oct 6, 2018.
  1. Timbo
    Timbo Member
    Oct 29, 2009
    74
    65
    Hi guys, I've been a bit keen on these for awhile and some nice 6L6GC came my way.
    The original Thunderbolt S6420 is a simple circuit so that pleases me and the end result should see it rifting away to some awesome LED ZEP tones.
    I have modded the circuit as the original had a spare triode at the input stage.
    So looking through some of the other Supro schematics, I found the S6424 input a good fit.
    A neat mod at the input jacks will allow the original S6420 circuit to be played and the second channel S6424 circuit and a link jack to blend the two.
    Some of the component values have been changed to todays values and some are just what I have on hand.
    Jason Kennedy and Micky like this.
  2. Jason Kennedy
    Jason Kennedy New Member
    Jul 13, 2017
    16
    10
    Nice! Look forward to seeing how this turns out for you. Had a reissue supro thunderbolt for a short while, sounded great but unfortunately was faulty and had to be returned. Would be interesting in maybe tryin to build one myself someday.
  3. Timbo
    Timbo Member
    Oct 29, 2009
    74
    65
    Thanks Jason, a bit of progress...
    Jason Kennedy likes this.
  4. Timbo
    Timbo Member
    Oct 29, 2009
    74
    65
    Hi guys, Board completed.............
    I've done a VINTAGE mix with the components, just to capture some yesteryear MOJO.........
    Geeze and Rockcity like this.
  5. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    The amp is basically low gain, until it is pushed into power tube distortion.
    Very similar to Led Zep tones.
    Is a good pedal amp because the preamp input does not break up easily...
    If you notice, Jimmy Page does not play dirty. He plays on the clean side, which makes this amp very similar tone.
  6. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    957
    484
    FYI: Screen resistors should be as close to the power tube pins as possible to avoid potential oscillation in the amp.some power tubes are worse than others. Pin 5 grid stoppers should be close also.
  7. Timbo
    Timbo Member
    Oct 29, 2009
    74
    65
    Thanks for the input guys.
    All wired up and ready to rock :jam:
    Power tubes cathode resistor is not in yet, It may need tweaking.
  8. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    3,538
    5,640
    I-55 Corridor
    I had two T-bolts, a Supro and a Ward's Airline
    The interesting thing about the old ones , they had one half a 12ax7 just hanging there in space , doing nothing
    Not being one to leave well enough alone, I wired up that stray half . I put in a closed jack ,like a two hole Marshall ,to have hi and Lo inputs . The Lo was great for bass and the hi gave it a great tweed growl
    Good luck with the build, interesting idea
  9. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    6,095
    3,206
    North
    Looks real good . I like 6L6 amps.
    I am going to build one that is loosely based on the Supro 24 but the triodes are parallel. Also using Russian 6P1P's for power. They are like 6bq5's . I have a nice small batch PCB for it to. Toroidal TX also.
    I need get busy on it.
  10. Timbo
    Timbo Member
    Oct 29, 2009
    74
    65
    Guys, The THUNDERBOLT BOOOOOMs.
    Fired up well with no problems.
    I'm keen to get it into it's cab to get a better idea of sound.
    Wildeman likes this.
  11. Timbo
    Timbo Member
    Oct 29, 2009
    74
    65
    Hi guys, Had a good day in the shed and knocked up the cab.
    I'm doing a bit of a test run to make sure everything fits.......
    As I said a trial run :redfaced
    I am really wanting to use the 15" speaker but it is only 4ohm and the OT is 15ohm.
    So the DUMMY 8" speaker is to make up the extra load, even though it still is only 11ohms as per the MM.
    I hope to get a stunt guitarist to give it a whirl.
    If it sounds crap I have only cut the opening in the baffle to take a 12" and the ply mounting the 8" is only tacked in.
