Split shaft pots adapter?
Discussion in 'The Workbench' started by Andries, Dec 9, 2019.
  1. Andries
    Andries New Member
    Aug 9, 2019
    24
    8
    Hi
    i bought an 1982 5210 combo
    The pots were worn.
    It had solid shaft pots ,problem was that the solid pots werent available anymore.
    so i replaced them with split shaft pots,now i wonder if there,s an adapter so i can use the original pointer knobs with screws on the split shaft pots.
    I want to keep it as original as possible
  2. MarshallDog
    Nov 28, 2010
    12,873
    12,599
    Taintville
    Ive never seen adaptors! Maybe wrap the shafts with aluminum foil tape and then slip the knobs on??
  3. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    612
    464
    https://guitarelectronics.com/split...ObRLhy_XFc2x3MKX7SSBHlGHniqRz-YcaAiDHEALw_wcB
    No experience with vendor and have seen them at other places.
    But what I do is cut rectangles out of old credit cards to fill the slots. Some cards are thicker than others so you can stack 2 or 3 tabs to come up with a perfect fit.
    Anything hard will work. I've used scrap maple.
    It should be snug but doesn't need to be a tight press fit -- the knob will keep the shim(s) in place.
  4. MarshallDog
    Nov 28, 2010
    12,873
    12,599
    Taintville
    Thats good to know. I will remember this if I ever need some of these.
  5. headcrash
    headcrash Active Member
    Jun 19, 2015
    107
    157
    Has anyone ever come across an adapter for D-shape pot shafts to make them a solid shaft?
  6. RLW59
    Nov 30, 2017
    612
    464
    Haven't seen D adapters, but I've made them. Just take a rod (plastic, brass, whatever you've got sitting around) and saw it down the middle (or file a flat on it). Put it on the shaft and drop the knob on.
    When converting pot shafts, the holes in the knobs are often bigger than the shafts. So the set screw pushes the knob off center, and it sort of "orbits" the shaft as you turn it (instead of being centered).
    Doesn't matter if you put Tele knobs on a Strat. But on an amp where all the knobs are in a straight line, when you turn the knobs some of them may be above the line, others below the line, and/or the spacing between the knobs may vary.
    If the eccentricity is enough to bother you, put the shims/D spacer in place and wrap the shaft with masking tape to bring it up closer to the diameter of the knob hole.
    headcrash and MarshallDog like this.
