Speaker Y Cable Advice
Discussion in 'Cabinets & Speakers' started by Sickriverlespaul, Jul 11, 2017.
  1. Sickriverlespaul
    Sickriverlespaul Active Member
    Dec 14, 2015
    222
    68
    l am looking to have a Y cable from my amp. One speaker output jack and need to run 2 cabs. Any ideas ?
  2. SG~GUY
    SG~GUY Well-Known Member
    Jan 27, 2010
    3,451
    1,813
    -I've done it, still do sometimes,
    good quality 1/4" jacks, 1 male & 2 female, couple feet of 14 AWG copper lamp cord-(the see through, so its easily identified)-solder connection's, poof!! Good to go!
    -(hook up both cabs to the "Y" connector and test the ohm's on the male jack tip & sleeve before plugging in to the amp)-
  3. ampmadscientist
    5,749
    2,124
    Y cables
    Speaker load is critical, can damage the amplifier.
    Calculate the load to avoid burning up the transformer. You have been warned. You cannot just hook up any speaker load to any amplifier.
    Usually, do not use a Y cable...this is not a professional method.
    Speaker cabinets should have in /out jacks instead.
  4. Dogs of Doom
    15,351
    12,642
  5. Sickriverlespaul
    Dec 14, 2015
    222
    68
    Thanks for the ideas, the humbucker music Y cable I feel will fit the bill. My 1987 had a ppimv installed with the volume knob run out the back speaker out put jack. So to run a stack of 16 ohm cabs I plug in and set the load on 8ohms. Ordered one today!
    SG~GUY likes this.
  6. Dogs of Doom
    15,351
    12,642
    it looks like a decent solution. Dr Z amps...
    Here's what I did...
    I made a parallel splitter box. I wired it like this:
    & use it like this:
    ISO box (2- 1912 cab's)
    GIBSON67, Sickriverlespaul and SG~GUY like this.
  7. mickeydg5
    16,714
    5,801
    I have a distribution box that can parallel and series cabinets with two inputs and four cabinet connections all switchable.
    Should I market it?
    SG~GUY and Dogs of Doom like this.
  8. Dogs of Doom
    15,351
    12,642
    pro cables makes a series & parallel box. On my box, I did parallel, so I used an aluminum case, so the case adds more negative connection. On their series box, I think they use plastic, or have an insulator between the jacks & case, so you can do the loop.
    Probably the thing, if you market it, would be all the caveats & disclaimers. Using it w/ tube amp & ohm ratings, etc. If you unplug a speaker on series, will it still make a complete circuit?
    Seems anymore, user manuals are so vague, you are left to figure things out for yourself. If you do that w/ a speaker load on a tube amp, you'll probably get a lot of upset customers.
  9. mickeydg5
    16,714
    5,801
    There would always be a load connected. The advantage to my design is that you can have both parallel and series at the same time if desired within the intended design use.
    The thing is I built prototypes for my use which is not designed for a high amperage rating yet is usable. I would only market a high amperage unit but it will cost; 6 high amp jacks and four toggles is one setup or the other is all jack connected with a total of 12 high amperage jacks. Any more than that for a power fan out and it is counter productive in design.
    I mentioned it somehow to Dunlop once but never got a response. So I guess it would be up to me providing and marketing the things.
