SPEAKER WIRING
Discussion in 'Cabinets & Speakers' started by Guv'nor, Nov 2, 2006.
  1. ampmadscientist
    14,958
    8,785
    Yes it's OK.
    Is the amp set to 16 ohms?
    SkyMonkey likes this.
  2. mickeydg5
    23,316
    10,402
    Its solid state with minimum 8 ohms, 65W.
    A single 16 ohm speaker will drop power output level lower and maybe be less bright and full.
  3. SkyMonkey
    1,409
    1,570
    England
    The VS65R has no speaker settings as such, only a single 8 Ohm speaker connected by wires coming from inside the "Head" portion of the combo. It is one of the Valvestate II line and has "Output 65 watts RMS - 8 Ohms" printed on the back. There are no extension speaker jacks, which is why I am attempting to wire in a speaker cable extension lead from the built-in speaker tabs for a separate cab connection.
    I know this amp probably does not deserve this kind of attention, but I've got the cab and speakers so I thought I'd have a go. Projects keep me out of trouble!
  4. mickeydg5
    23,316
    10,402
    The VS265R is kind of a similar amplifier with extension jack. It has the same "Output 65 watts RMS - 8 Ohms" with the difference being that the extension cabinet is placed in series with the internal speaker.
    So 8 + whaterver 4 to 16 ohm cabinet is total impedance. Yes it drops the power output of the amplifier but the additional speaker(s) add acoustic power.
  5. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,628
    2,549
    If i were you ide be careful dinking around with speakers and wiring with those amps they will blow up if the wind blows in the wrong direction.
    Ide keep the ohms at 16 and DO NOT EVER go below 8 with those amps they will fry quick as shit. They have very poor cooling and those output chips are super fragile. They sound good and look kickass ive had 2 of the 50 watt heads, one of the 150 watt 4 channel and one of the 50 watt combos all of them had blown at least once the 50 watt combo blew i fixed it and the stock right angle speaker cord was shorted and before i figured out what it was it blew a second time. Those molded speaker cable are junk also get rid of it also before it fails.
    The reason why i say run the amp at 16 ohms is because it runs cooler at 16 so you have less of a chance of nuking it.
  6. SkyMonkey
    1,409
    1,570
    England
    My VS65R has no moulded speaker cord, just the type of wiring you would expect to find inside a speaker cab. Single red and black wires, spaded.
    I have two 16 Ohm speakers ready to use in parallel, but do also have two 8 Ohm speakers I could run in series.
    It is good to know that running the amp at 16 Ohms with one internal speaker might actually extend the life of the amp.
    It's 22 years old already!
  7. Georgiatec
    Apr 23, 2010
    5,234
    4,132
    You will need to use the two 16 ohm speakers you have. one in the combo and one in the extension cab. Run the + and - from the amp speaker to a jack socket and fix it into the back panel of the combo. You now have an extension output for another 16 ohm load. You will be running at 8 ohms with the extension connected and 16 without.
  8. ampmadscientist
    14,958
    8,785
    16 ohms is a good load on an 8 ohm solid state amp.
    It's OK.
  9. SkyMonkey
    1,409
    1,570
    England
    Made the mods and tested it. All is good. A 1912 cab underneath is the perfect match for the VS65R.
    Changed the tube for a JJ ECC83 and now this amp rocks.
    Cheers for the help guys.
    mickeydg5 likes this.
  10. Lukas
    Lukas Well-Known Member
    Apr 21, 2013
    280
    335
    Canada
    Funny I was questioning my connections today after years. Seems like such an easy thing but it’s not really explained well anywhere I don’t think. Maybe it’s the way the jacks are labeled that makes it this way. Anyway, this is the back of my JVM and it is connected to 2 1960 A&B cabs to equal a full stack. I hope this is correct? Nothing has made smoke yet in about 8 years. D4DB8797-787D-4817-B01D-51CF5615A37E.jpeg
  11. Matthews Guitars
    893
    1,193
    As it says, use those jacks for 1 8 ohm cabinet or two 16 ohm cabinets. Since your 1960A/B cabinets are both 16 ohm cabinets, you're plugged into the right jacks.
  12. mickeydg5
    23,316
    10,402
    Hopefully they are set for 16 ohms. :fingersx:
    Oh, of course they are. :)
  13. Lukas
    Apr 21, 2013
    280
    335
    Canada
    So if I have a buddy come over with a Mesa head and I wanna split this full stack into two half stacks so he can play through one he can’t? I believe Mesa cabs are all 8ohm and the back of Mesa heads only have 8 ohm options not 16? Or it will power it at 8 but not to it’s full potential?
  14. mickeydg5
    23,316
    10,402
    Which year and model Mesa head?
    A lot of Mesa Boogie have 8 and 4 ohm impedance out so in that case he could use the 4 ohm mono option.
  15. Lukas
    Apr 21, 2013
    280
    335
    Canada
    Mark V... around 5 years old. Dont think the impedance at the back have changed in the last 10 years.
