Some Sort Of Marshall Clone Build...
Discussion in 'Building the Classics' started by SpHj, Nov 12, 2018.
  1. SpHj
    SpHj Well-Known Member
    Nov 8, 2013
    476
    465
    Ontario, Canada
    So I happened into a bunch of parts last week for real cheap (Smallbox Headshell, Steel chassis, 800 Plexi faceplate, & a set of Classic Tone 800 transformers). I've got most of the small parts on hand as I repair amps locally so there's really not much more to pick up and have a great clone of some sorts. I'm still on the fence about what circuit I'm gonna go with but we'll see how it ends up!
    This'll be a slow build over the next couple months in my spare time, but I'll document here along the way for all to see.
    Enjoy!
    Sockets installed
    Transformer set
    Transformers Installed
    Lets get to work!
  2. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    The Board is mostly populated...missing some parts...good thing they’re already in the mail!
  3. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    557
    1,134
    I'm in ! Take me on a Marshall build journey ! thanks
    SpHj likes this.
  4. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    Installed the Preamp filter cap as I had a 32+32uF cap on hand.
    Cleaned up the transformer wires as well.
    Also installed most of the pots as I had them on hand & figured out my grounding scheme. I’m going with a 5k presence control.
    That’s it for tonight. Gotta wait for parts now.
  5. neikeel
    2,820
    1,308
    Is that an old 50w Master PA chassis? Will it fit in a small box cab?
    Looking good so far:agreed:
  6. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    I doubt it is although it may be based on one...looks too new. And yes it does fit in a Smallbox! It came with it:band:
  7. Yugedrums
    Yugedrums Well-Known Member
    May 7, 2015
    342
    263
    South Carolina
    I want to build a kit so bad and I can't get enough of this kind of thing. Definitely subscribing to this. This forum doesn't get enough activity!
  8. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    *Minor Update*
    So while I anxiously await delivery of parts (it could be a while as Canada Post is currently on strike) I fitted and grounded the remaining filter caps and dry fitted the output jacks. I’m not going to install a loop as I don’t use them.
    I’ll utilize every hole in this chassis for 1x4ohm 2x8ohm and 2x16ohm hookups. Save $$ on a selector switch. As you can see the OT wires are attached to a terminal strip. Nice and tidy.
  9. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    I’m also going to utilize a hole already drilled on the front panel & chassis for an “input” value switch.
    It’ll switch from the 800 470k/470p to my favourite 68k ohm on the input for an 800 front end.
    And it’ll also utilize the spot on the board where 2 of the 68k resistors go for a 4-holer
    That’s it for now...hopefully parts come in soon!
    jensvonbustenskjol likes this.
  10. Dean Swindell
    Dean Swindell Member
    Mar 12, 2017
    60
    58
    Way cool, thanks for posting this. I'm new here and can't find the threads for my specific questions or how to start a new one. But............have you built a Weber kit? I hear they just throw you the parts and you're on your own. That would be okay if they didn't do some things so uniquely like the physical construction of the power supply (electronically I like it because I've worked on a hundred black&silver Fenders) it's mounted in a dopey way. Any experience with these guys?
  11. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    *Update*
    Parts are finally in!
    Well, the wire isn’t what I was hoping it would be aesthetically but it’s rated super high and won’t melt so that’s good.
    Heater & OT wires installed,
    Board is now fully populated,
    Front Panel is on with Jacks and switches dry fit...she’s starting to look like an amp now!
    That’s it for tonight, in the next few days it’s all the small wiring...hopefully by the weekend she’ll be ready to burn in!
    CoyotesGator, jmp45 and Yugedrums like this.
  12. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    385
    164
    You might run into some problems using a carbon comp resistor from your PT HT secondary to the bias section. I would recommend changing that to a metal oxide or metal film (1W+ 500v). CC are ok for certain spots where you want their reactance to influence the sound of the amp. But you want the bias section to be rock solid and steady. You don't want your bias dropper to drift in value as the amp heats up.
    Also those black silver mica caps have been to known to leak DC. Make sure you test them once you fire the amp up.
    SpHj likes this.
  13. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    Whew! Gotta love that wire...
    Preamp tubes are all wired up. What a chore...this wire is NOT easy to work with....lesson learned for next time...
    Power and standby switches getting some wires
    Filter caps, fuse holders, indicator light & ground wires installed...just the pot wires and IEC plug to go!
  14. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    All wired and ready to fire up!
    Some pot shots:
    Finally, time for a test run!
    Yugedrums likes this.
  15. Chris-in-LA
    Chris-in-LA Active Member
    Jul 19, 2018
    405
    166
    I did a Weber 5e4 tweed Super. They sent all the resistors in one bag, the caps were kinda cheap looking and the power transformer was made in China. The PT looked cheap and the amp made some funny noises so I replaced it with a Mercury Mag PT. You can see the difference in construction quality for yourself. The Weber kits seem like a good buy but you get what you pay for. I prefer the Mojotone tweed kits but, ironically, I use Weber speakers in my Mojotone builds.
    Dean Swindell likes this.
  16. pedecamp
    11,745
    6,690
    How does it sound? What circuit did you finally decide on?
  17. SpHj
    Nov 8, 2013
    476
    465
    Ontario, Canada
    Sounding great so far. I’m still tweaking it, it’s not far off a 2204. Just a few tweaks to the tone stack...and a 4-joker Presence pot setup. Settled on 6550’s, still working on the final preamp specs.
  18. Dean Swindell
    Mar 12, 2017
    60
    58
    I got their California 15 (JBL D-130 sound). After two years it got a voice coil rub. They recone their own speakers for $25 but after shipping both ways ($$$) it would be less expensive to get a new one.
