Solder Station replacement tips?
Discussion in 'The Workbench' started by RickyLee, Mar 16, 2020.
  1. RickyLee
    May 22, 2010
    9,964
    3,386
    Riverside CA U.S.A.
    Any of you out there all of a sudden have the tip start disappearing? This one just seemed to happen over the last 4 sessions and it is about a third gone now.
    Funny as I was thinking awhile back if they made longer ones anyway, to get into those tight spots and such.
    Getting ready to google my model right now . . . .
  2. StingRay85
    StingRay85 Active Member
    Aug 18, 2019
    363
    153
    Always put some solder on the tip when finishing
  3. Micky
    Apr 29, 2010
    20,806
    17,274
    Vermont
    It is normal for the tip to erode.
    Once the outer metal coating is gone, the underlying material erodes even faster because it is usually much softer (to conduct heat better)
    Time to replace the tip.
  4. RickyLee
    May 22, 2010
    9,964
    3,386
    Riverside CA U.S.A.
    Yeah, I always keep it clean and keep solder on the tip. It is just a cheap unit I been working the heck out of for quite a few years now with these projects. It is a Yihua 939D. Think it was just over $30 new including shipping.
    Am I understanding correct it has an "active" tip on these station units? And then could these tips possibly be common among different manufacturers?
  5. Micky
    Apr 29, 2010
    20,806
    17,274
    Vermont
    Yeah, the 2mm and 3mm tips for that are everywhere.
    RickyLee likes this.
  6. RickyLee
    May 22, 2010
    9,964
    3,386
    Riverside CA U.S.A.
    I found some on Amazon so far, hopefully correct ones. Will look into it after i try to get some sleep. The newer model Yihua 939D actually comes with extra tips. WTF was up with my station? lol
  7. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    626
    766
    Brooklyn, Joey!
    My Hakko didn't come with tips. Then I looked thru their on line manual and realized there's literally 150 specialized tips so I guess they figure you'll source what you need separately.
  8. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    5,319
    3,526
    Bay Area, CA
    The flathead tip on mine is melted.
  9. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    907
    830
    house arrest
    Hakko for the win.
  10. Gunner64
    Nov 16, 2013
    6,040
    7,705
    Midwest, USA
    Yea, my Cheapo Zeny station came with loads of extra tips.
  11. ampmadscientist
    18,126
    12,164
    Maybe you should buy a new Weller w/ temperature adjust?
    There is a whole lotta different tips and parts for Weller.
    neoclassical likes this.
  12. ampmadscientist
    18,126
    12,164
    I used a Hakko it was pretty good.
    It had this thingee to put the solder iron in idle or auto shutoff. The solder iron stand has a switch so it knows when you're not using it.
  13. ampmadscientist
    18,126
    12,164
    I use this one but it costs about 400- $500 after buying tips ,solder, etc.
    It has 3 preset temperatures, so I hit the button and it changes over to the preset.
    [​IMG] [​IMG]
  14. RickyLee
    May 22, 2010
    9,964
    3,386
    Riverside CA U.S.A.
    This Yihua has worked great so far, so hopefully I get a few more years out of it. It has plenty of heat for sure.
