So, Did We Ever Figure Out Why The Dsl20hr Has Only 3 Preamp Tubes?
Discussion in 'Marshall Amps' started by _ripper_, Nov 4, 2018.
  1. Dogs of Doom
    17,937
    16,607
    the point is the 5 watter uses a s/s staging, rather than all tube, like the 1 watt.
    5 stages & cathode = 6 tube functions. 3 tubes using each ½ per function = 6 functions.
    The lower watt amps are a hybrid. Apparently, they are using the s/s PI in both...
  2. _ripper_
    _ripper_ Well-Known Member
    Oct 1, 2013
    410
    338
    Forgive me if I'm not understanding something, but I'm asking about the 20 watter, which has one extra preamp tube compared to the 1 and 5 watt amps.
  3. Dogs of Doom
    17,937
    16,607
    from above:
    5 gain stages & cathode = 6 tube functions. 3 tubes using each ½ per function = 6 functions
    _ripper_ likes this.
  4. _ripper_
    Oct 1, 2013
    410
    338
    OK, I got it now :D Thanks for patiently explaining!
    So, taking that reasoning a step further and since the 1 and 5 watt amps have two preamp tubes vs three in the 20 watter, that means that the DSL1HR and DSL5CR amps also have SS gain stages, in addition to a solid state PI.
    Dogs of Doom likes this.
  5. Dogs of Doom
    17,937
    16,607
    correct...
  6. guitarman3001
    guitarman3001 Active Member
    Oct 7, 2013
    239
    127
    Here's the info I got directly from Marshall for the DSL20's tube layout.
    V1A input driver
    V1B OD gain stage
    V2A OD gain stage
    V2B Clean and OD gain stage, tone stack driver
    V3 Phase inverter
  7. _ripper_
    Oct 1, 2013
    410
    338
    That makes sense, but it seems then that Marshall is telling you and @Delete!! two different things.
  8. guitarman3001
    Oct 7, 2013
    239
    127
    When it comes to Marshall I would go with common sense over what a Marshall rep says.
    A rep on the my Marshall forum told someone the broken emulated out on his dsl20 is working as intended.
    Delete!! likes this.
  9. Dogs of Doom
    17,937
    16,607
    who from Marshall?
    all depends on who you are talking about...
  10. guitarman3001
    Oct 7, 2013
    239
    127
    Not sure if I should post the name in public.
  11. Delete!!
    Delete!! Active Member
    Jun 29, 2018
    195
    235
    San Joaquin Valley, Ca
    I agree, and to be honest I expected the responses in this thread to go this way (discrepancy’s between what Marshall is telling customers). That’s why I stand by my earlier statement, I base my likes/dislikes on tone alone. I like the tone of my 5CR, despite the solid state bits. It’s fun to try and figure out what’s going on design-wise in these amps, but at the end of the day all that matters is this - does it sound good to your ears?
  12. ampmadscientist
    11,624
    5,675
    Left Coast
    I guess 1 schematic is worth a thousand words.
    Anybody got a schematic?
    Until then...
    What I see is a tube phase inverter...and a SS effects loop.
    Most Marshall amps I have seen (including this one) are based on a certain form-factor which is:
    Plexi
    Preamp stage V1a
    Preamp stage V1b > mixer > saturation stage (V2)> Phase Inverter V3 > Power amp
    2203 / 04
    Preamp Stage V1a> Preamp Stage V1b > Saturation Stage (V2) > Phase Inverter V3> Power Amp
  13. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    502
    163
    Deleted for misinformation
  14. stickyfinger
    Nov 11, 2010
    502
    163
    As far as I know the 2018 DSL series, 1R, 5R and 20R series are using a SS PI as told from Marshall. The 40/100 are using tube PI.
    The 2012 reissue series were all tube.
    The 5 and 15 had a different circuit ( no cathode follower TS ect) than the 40/100.
  15. Antmax
    Antmax Well-Known Member
    Aug 7, 2015
    811
    576
    Brit in California
    That photo with DSL15M2 printed on the board is actually the DSL20 internals. Taken from the DSL20h gut shots thread of these forums.
    Here's the only pic I could find of the board reference number for the old DSL15.
    Unfortunately no one seems to have taken a zoomed out photo of the 15.
    OOH! Just did, and it's quite different. You can tell the other one is the 20 because there are no Bias Trim pots which are clearly visible in the 15 shot below.
    Trim pots
    The DSL20 gutshot photo Ampmadscientist posted earlier doesn't have these since it is self biasing.
    stickyfinger likes this.
  16. stickyfinger
    Nov 11, 2010
    502
    163
    Hmm guess Marshall was wrong or the person spreading the news was misinformed.
    I initially figured the new 20 1 and 5 watts were based off of the 2012 RI 5/1 watt amps.
    I new Marshall wouldn't go Blackstar on us Lol!!
    Thanks for the clarity
  17. guitarman3001
    Oct 7, 2013
    239
    127
    I wish they would have gone Blackstar on us..... I might not have had to return 4 of them before finally getting one that worked right!!! :sad:
  18. Dogs of Doom
    17,937
    16,607
    I was making the assumption that all the PI's were s/s because I've read it in the forum here, so, I just figured what was said about the 5 & 1 watters applied to the 20 as well...
  19. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    6,323
    3,586
    North
    That is the way it should be !
  20. stickyfinger
    Nov 11, 2010
    502
    163
    Ive heard the 20 had a SS PI for months as well.
    I think I might get a 15h and mod the clean and od channels to clean red and OD green.
    My 40 is just to big and I hate combos. No tone suck no Reverb or a SS loop. How can I go wrong LOL
