SL5 "pop" when channel switching
Discussion in 'Marshall Amps' started by MK333, Jun 15, 2019.
  1. MK333
    MK333 Active Member
    Jan 15, 2019
    133
    122
    I know this has been posted before but I dont see a solution or fix for it anywhere I look. My SL5 pops when switching channels. Its louder when playing but still there when the guitar is quiet. I ve also read there is no cure and happens to quite a few different amps.
    Any help would be great. Thanks
  2. Len
    Len Well-Known Member
    Sep 13, 2009
    985
    749
    If you’ve read there’s no cure then there’s likely no cure. Marshall’s recent track record with channel switching and effect loop issues isn’t impressive.
  3. scozz
    scozz Well-Known Member
    Jul 20, 2008
    1,275
    2,459
    I owned a 1980 Fender 30 all tube amp that did the same thing. A loud POP when switching channels,......
  4. rich88uk
    rich88uk Well-Known Member
    May 25, 2009
    683
    662
    Liverpool,UK
    Mine did the same. Far as I was aware there was no solution. Although once turned it up loud it wasnt that distracting from what I remember.
  5. MK333
    MK333 Active Member
    Jan 15, 2019
    133
    122
    I dropped it off at a techs house today. If he figures out the problem I will for sure share this info here. Seems common.
    Rich88uk I cant play loud enough to drown it out, not with 2 13 month olds lol..eventually I ll be able to
  6. MK333
    MK333 Active Member
    Jan 15, 2019
    133
    122
    Yes I read those posts but they re from 2013 and 14...I was hoping someone had found a fix. Its quite annoying
  7. rich88uk
    May 25, 2009
    683
    662
    Liverpool,UK
    I know how that feels. The SL5 sounds great for low volume
    MK333 likes this.
