Silver Jubilee - Vintage Vs Reissue
Discussion in 'Marshall Amps' started by dslman, May 2, 2016.
  1. dslman
    dslman Well-Known Member
    Apr 15, 2012
    2,638
    1,158
  2. chucke
    chucke Member
    Jul 16, 2009
    90
    57
    Campbell, CA
    oh my. He did a good job at making those Jubes sound like ass.
  3. thegaindeli
    thegaindeli Well-Known Member
    Oct 22, 2008
    1,881
    723
    USA
    I made a non-alcohol Mint Julep today... Very tasty! :)
  4. marshalled
    marshalled Active Member
    May 21, 2014
    91
    149
    Italy
    Is an old video ...the first video on tube when 2555X arrived on the scenes.
    Here there's a video played in october 2015 by us (me and my friend):
    dslman likes this.
  5. marshalled
    May 21, 2014
    91
    149
    Italy
  6. marshalled
    May 21, 2014
    91
    149
    Italy
  7. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,322
    811
    Adelaide, South Australia
    Marshalled, we get it, no need to multiple post my friend, cheers.
  8. marshalled
    May 21, 2014
    91
    149
    Italy
    Sure but i push button reply 1 time !!!
    I substitute the multiple answer whit a DOT !
  9. JacksonCharvelAddict
    Mar 4, 2016
    1,685
    1,698
    My experience is that you have to check the bias on the 2555x. They shipped mine completely out of wack. One side way too cold and the other way too hot. I have seen numerous posts from other people with similar findings. Marshalled's vid is way better than the first one.
  10. paulorr8179
    paulorr8179 Active Member
    Oct 1, 2013
    360
    147
    Syracuse, NY USA
    Some demos I have watched on YouTube sounded fantastic.
    I have a 1988 black jubilee 50 watt. It sounds to die for.
    I was at Sam Ash in Hollywood a few weeks ago and tried out a 100 watt reissue and it sounded terrible.
    I'm thinking the bias was cocked up as CharvelFan said above.
  11. thegaindeli
    Oct 22, 2008
    1,881
    723
    USA
    I wouldn't even consider selling my '87 SJ.
  12. marshalled
    May 21, 2014
    91
    149
    Italy
    The 50w version have more Gain than 100w ...at minute 4:48 of my video you can listen a black tolex 2553.
  13. pedecamp
    14,102
    10,732
    If the prices were the same I'd go reissue every time. Lower maintenance, possible improvements, possible warranty.
    ssolo8 and JacksonCharvelAddict like this.
  14. marshallmellowed
    Jun 26, 2009
    3,447
    3,891
    I have both, a 2555x and an older 2555SL (Slash), not much difference tonally.
  15. jack daniels
    Aug 23, 2010
    6,697
    2,427
    OKC, OK
  16. dslman
    Apr 15, 2012
    2,638
    1,158
    The reissue seems a little more bright ,stringent than the vintage. Similar to the difference on a 2203 and 2203x.
  17. JacksonCharvelAddict
    Mar 4, 2016
    1,685
    1,698
    This is exactly why I got the reissue. The used prices were insane for the condition I was finding. I got a good deal on my halfstack.
    pedecamp likes this.
  18. JacksonCharvelAddict
    Mar 4, 2016
    1,685
    1,698
    Interesting. I have heard other people say the same thing. Maybe the modern components cause them to be slightly brighter. I wouldn't describe mine as being bright. I suspect my speakers have some breaking in to do.
  19. thegaindeli
    Oct 22, 2008
    1,881
    723
    USA
    All components being equal, the only remaining difference is the solder. My experience is, that lead-free solder imparts a certain "sizzle" to the top-end compared to tin/lead solder. I asked Trace at Voodoo what he thought? His experience was the same as mine. No amount of eq adjustments will quell the differences between the two. I completely rebuilt three hand-wired amplifiers using components of identical size and composition, but used tin/lead solder in place of lead-free RoHS solder. In every case, the tin/lead rebuilds were warmer overall, with none of the bristly sounding top-end. Every test was done using the same 2x12 and 4x12 cabinets. It was definitely more noticeable when using HG vs clean tones.
  20. marshallmellowed
    Jun 26, 2009
    3,447
    3,891
    Both sound good, but there is a very slight difference.
