Semi-transparent Deck Stain And Sealant.
Discussion in 'The Backstage' started by mtm105, Jul 13, 2018.
  1. mtm105
    mtm105 Well-Known Member
    Feb 11, 2014
    3,741
    3,130
    NW NJ Exit 25
    I took out some old boards and flipped over others on a very large deck. ALL OF THEM. Sun and weather beaten wood.
    I stained with Cabot Semi-Transparent stain (Australian Honey Teak). Oil based.
    Now I've got sealant ready to apply. Do I need it? Does it alter, or ruin the nature my work staining the wood?
    I'm thinking I may have to apply sealant every other year. I'm OK with that. It beats pulling nails and replacing boards. When I bought home, the deck was totally neglected for years. Rest of home beautiful. I don't see how people would let it go like that.
  2. Vinsanitizer
    Vinsanitizer Hi. I'm new here. VIP Member
    Oct 19, 2012
    25,144
    17,212
    Roca likes this.
  3. jimmyjames
    jimmyjames Well-Known Member
    Jun 15, 2014
    1,254
    1,071
    West Oz
    Or Afterhours, if you meant Semi-transparent Dick Stain...
    Vinsanitizer likes this.
  4. mtm105
    Feb 11, 2014
    3,741
    3,130
    NW NJ Exit 25
    I called stain company and told Thompson seal is opposite of their stain.
  5. Micky
    Apr 29, 2010
    19,638
    15,471
    Vermont
    Yes, you still need something to protect the wood.
    Thomsons is OK, I use boiled linseed oil every few years.
  6. RLW59
    RLW59 Active Member
    Nov 30, 2017
    419
    217
    So, the stain company said Thompson is not compatible?
    Did they say whether their stain needs any sealer? Some stains contain their own sealer, and every few years you reapply the stain/sealer. An oil-based stain like you used would likely provide some measure of sealing.
    Or did they recommend some other brand of sealer?
    Just like finishing a guitar, you can often mix brands/types with good results. But you can also mix stuff that seems like it should be compatible and end up ruining all your hard work.
    So in general, it's safest to follow the manufacturer's recommendations. If they have a full "system" of products, use their sealer that's designed to work with their stain.
    Decks are kinda like pools. Some people imagine how wonderful it would be to have one, get it installed, then they never use it much as they thought they would. And then discover the upkeep is more than they expected and just neglect it.
  7. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    9,416
    6,630
    Taintville
    If its in the budget, rip off the top deck and replace it with the manufactured plastic wood. You’ll never touch it again.
  8. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    Sounds more like a strain than a stain.
    The ideal sealer is urethane.
  9. mcblink
    mcblink Well-Known Member
    Feb 25, 2013
    3,023
    2,652
  10. Micky
    Apr 29, 2010
    19,638
    15,471
    Vermont
    I have a deck next to my pool. I used Trex for walking surface, it needs nothing after it is installed.
    I use boiled linseed oil on everything else, no stain. Natural looks best to me, and the oil darkens it a bit.
    My pool pump is a different story... It needs TLC all the time. But it all sure is nice on 90 degree days like today...
  11. LRT#1
    LRT#1 Well-Known Member
    567
    642
    Sorry buddy but urithain is not for outdoor use it is for indoor furnishings outside it will flake and peel from the suns uv and moisture or rain
    Trex is the way to go just make sure you get the good stuff because I have seen it crumble then again I live in a desert and the heat was probably the issue
    Micky likes this.
