Seeking Marshall 4140 speaker, verb tank & foot pedal!
Discussion in 'Building the Classics' started by MustRemaneNameless, Aug 12, 2019.
  1. MustRemaneNameless
    MustRemaneNameless New Member
    Aug 8, 2019
    11
    Hello All,
    I am looking for a few parts to finish up my Marshall 4140.
    I need to find an original McKenzie speaker (red framed that was produced for Jim Marshall ltd...)
    Also need an original verb tank for the Marshall 4140
    And an original foot pedal for this unit!
    Any other parts like plastic handles on the side or top I would consider as well.
  2. ampmadscientist
    13,319
    7,196
    Welcome to the forum Nameless.:cheers:
    Those parts are going to be hard to find, and I wish you luck. Good Luck.
    MustRemaneNameless likes this.
  3. MustRemaneNameless
    Aug 8, 2019
    11
    I know they are harder to find but I'm still hopeful :)
  4. MustRemaneNameless
    Aug 8, 2019
    11
    Alright I have officially sourced 2 of the McKenzie 12 inch speakers!!! Hot damn!!! This will actually leave me a spare!
    Now just need the original verb tank and footswitch!!!
  5. MustRemaneNameless
    Aug 8, 2019
    11
    Speakers arrived in L.A. from Denmark in fantastic condition!
    One step closer!
  6. Sonikhood
    Sonikhood New Member
    Aug 28, 2019
    Hi I’m in the same situation, need a foot pedal and a 4 spring hammond reverb tank for a 4140
  7. DonP
    DonP Active Member
    Jan 28, 2009
    103
    44
    Cincinnati, OH
    I have a 4140 not in use. I'm going to use the Transformers for a 1959 head project and make the 4140 a 6V6 stereo combo.
    What is so special about the reverb tank?
    I went to the basement to take a look. Mine says Accutronics, made in USA.
    It is 4 springs.
  8. ampmadscientist
    13,319
    7,196
    'need a foot pedal and a 4 spring Hammond reverb tank for a 4140'
    good luck and may God speed with the both of you.
  9. MustRemaneNameless
    Aug 8, 2019
    11
    I'm just trying to restore mine to be as original as the factory made it. I know its possible!
  10. DonP
    DonP Active Member
    Jan 28, 2009
    103
    44
    Cincinnati, OH
    Ok. More power to you guys who love the 4140.
    FWIW, the 4140 was my third amp on a (horrible) quest for a heavy metal tone in the late 80s.
    My first amp was a Gorilla (guitar was a strat with really clean pickups). Fail #1.
    My next amp was a Peavey Classic VTX. Checked the back - TUBES! Then I found out the front end was SS. Not bad, but Fail #2.
    My third amp was the 4140 found at a pawn shop in Santa Ana, CA. It's a MARSHALL so it must be good for metal, right? Found out it was the "Town and Country". Fail #3.
    My 4140 came with 6L6's in it, and they were sweating! I ended up gutting it, making it into a TSL back in 1990 (no internet, just Groove Tube books). Fender clean, Marshall Crunch and Mesa Lead. It sounded very good, and very loud (re-tubed with 6550's for 120w clean). I decided I could rebuild it better (I used a lot of relays, thought I could do better switching), but it never happened.
    I've bought a new JMP chassis for the transformers, and plan on using the chassis and cab for a 15 watt per channel stereo combo using 6V6 tubes.
  11. MustRemaneNameless
    Aug 8, 2019
    11
    Yeah the 4140 is most definitely not the heavy metal sound. :)
  12. MustRemaneNameless
    Aug 8, 2019
    11
    Foot pedal found!!! Just missing the original verb tank and speaker jack / wiring! :)
  13. South Park
    South Park Active Member
    270
    163
    Try a fender revered tank it might be easer to find
  14. MustRemaneNameless
    Aug 8, 2019
    11
    The end goal is to get this rig back to all original shape.
    I'll be using a new replacement unit from Accutronics for the time being.
    So far I've been extremely lucky when searching!!!
  15. StingRay85
    StingRay85 New Member
    Aug 18, 2019
    28
    8
    What type of Accutronics tank do you need? I have a spare (large) one in a donor chassis of a 1980 Acoustic model 165 (100W 6L6 tube combo).
  16. MustRemaneNameless
    Aug 8, 2019
    11
    I believe the correct model to be 4FB2A1C
  17. StingRay85
    Aug 18, 2019
    28
    8
    Ok, this already appears to be the same model as I have in my two Acoustic 270 heads (obviously I can't sacrifice those). I will check tonight if the one in my donor chassis is the same.
  18. StingRay85
    Aug 18, 2019
    28
    8
    It's a different model I'm afraid, has three springs
  19. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    629
    420
    NJ
    I have an old accutronics 3-spring reverb tank you can have for free if you're interested in using it. It's probably not the exact model tank.
    I'll look up the part number when I get home.
  20. Gutch220
    Feb 19, 2018
    629
    420
    NJ
