Ride the Lightning guitar tone
Discussion in 'Marshall Amps' started by tbart076, Nov 12, 2015.
  1. jlinde1973
    jlinde1973 Well-Known Member
    Dec 22, 2011
    511
    313
    Traverse City, Michigan
    Yup. Hetfeld called it the "magical marshall" jmp 2203 modded by Jose that he used. Kirt used boogies. Unfortunately hetfields magical marshall mysterious disappear after ride the lightning. Master of puppets was all boogie.
  2. pedecamp
    13,344
    9,403
    Did you ever get your hands on a Proco Rat? I had good results with it very quickly to get passable Metallica tone.
  3. tbart076
    tbart076 Member
    Oct 10, 2015
    36
    I did! The store that serviced my amp had one in stock. It's a great pedal in my opinion, more versatile than I expected. The one thing I've noticed is that at times it sounds like it's sitting on top of the amp instead of being a part of it. All in all I'm satisfied. I'm getting some good early thrash tones from it.
  4. tbart076
    tbart076 Member
    Oct 10, 2015
    36
    It sounds a lot bigger in person, which definitely helps. What would you suggest to make it closer to RTL?
  5. marshall1967
    marshall1967 Active Member
    Jan 26, 2011
    312
    119
    Tucson AZ
    RTL, to me, is heavier and deeper than what one Marshall can do on its own..you're close enough though, i think, your tone is a little ''warmer'', its a good tone.
  6. Joe Marabella
    Joe Marabella New Member
    Ride The Lightning is Dirty Fingers pickup > Tubscreamer > stock JCM800. Dirty Fingers are VERY important to the sound because they're very high output
  7. Mitchell Pearrow
    8,339
    12,411
    Welcome to the forum new MF’r
  8. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,038
    362
    Netherlands
  9. tschrama
    May 15, 2010
    1,038
    362
    Netherlands
    But I also think it sound like a proco RAT into a stock 2203
  10. WholeLottaGlove
    WholeLottaGlove Active Member
    Jul 24, 2017
    82
    166
    Using a Marshall JCM800 4210 (2205 circuit), I could nail the RTL sound pretty easily. Not so easy with my DSL50, 2204 or JMP 1987.
  11. 6StringStewie
    6StringStewie Active Member Premium Member
    Jun 10, 2017
    287
    218
    Springfield, Ohio
    It's all in the scoop. Bass 10, Mids 0, Treble 10. They used this setting through ...ajfa if I remember correctly.
