Return My Origin 20h For A Studio Vintage?
Discussion in 'Marshall Amps' started by shades of blue, Feb 7, 2019.
  1. Sailindawg
    Sailindawg Active Member
    Feb 27, 2016
    182
    159
    @OP
    From my own experiences, if you are only a home player, go with the amp that's easiest to deal with volume management wise and still gets the tones your after.
    If your gigging, well, whatever works for the music and venues your playing at. Since the Origin is new to you and you got such a great deal, lived with that for a while & learn that amp. And you did get a great deal on it!
  2. DesolationBlvd
    DesolationBlvd Member
    Sep 16, 2017
    66
    99
    Funnily enough, that's actually accurate for how a JTM45 or Plexi-era 1987 would sit on a regular 1960 cabinet.
  3. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    4,031
    3,233
    Montreal
    If longevity of the amp and it's components are your main concern then may I suggest that you should have no concern. I am of the opinion that just because the Studio Series is put together in GB does not mean that it will have a maintenance free or longer shelf life than the Origin line put together in Vietnam.
    The Origin cab you have loaded with the GB's will be outstanding.
    BP
  4. BanditPanda
    Oct 19, 2015
    4,031
    3,233
    Montreal
    MDF is an engineered wood composite that is similar to particle board, but is much denser and stronger than particle board. Imagine if all of the sawdust was swept up from other wood product manufacturing processes, and then that sawdust was mixed with binders and pressed into large sheets the size of plywood.
    And because it’s pressed so hard at such high temperatures, there are no voids in MDF like you find in particle board.
  5. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    977
    2,119
    Springfield, Ohio
    I have noticed that on those MDF cabs there is a potential problem. If you change out speakers you better be extra special careful. Those T-nuts can come loose much easier on MDF than birch plywood.
    steveb63, ken361 and Mitchell Pearrow like this.
  6. ricksconnected
    Sep 29, 2015
    13,388
    6,613
    everywhere you wanna be.
    from the demos ive heard, these are 2 different animals.
  7. ricksconnected
    Sep 29, 2015
    13,388
    6,613
    of course and the price difference reflects
    Michael Roe likes this.
  8. shades of blue
    shades of blue Active Member
    Dec 19, 2010
    217
    95
    Middle of nowhere SC
    I honestly don't have an issue with MDF. Over on TGP, MDF gets a bad rep, but to me if it is sturdy and saves some money, I'm ok with it. I just can't get over how good the cab looks in person though. Makes the entire stack look legit!
  9. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,113
    2,682
    smart move...origin & dsl got a lot of marshall covered..peeps will lead you to think you need this or that,,but those 2 as your heads will be a a lot of marshall goodness.........
  10. Mitchell Pearrow
    6,940
    9,504
    I agree 100%!
  11. BftGibson
    May 28, 2018
    1,113
    2,682
    You are one of the ones who absolutely proves it !! real life vids..no bs..just playin !!
  12. Mitchell Pearrow
    6,940
    9,504
    That looks the way they had always, prior to the JCM lineup !
  13. Mitchell Pearrow
    6,940
    9,504
    I thank you brother, that’s a hell of a compliment! Cheers my brother’s
  14. marshallmellowed
    Jun 26, 2009
    2,931
    2,554
    From a technical point of view, if you're using, or would be using, the amp primarily as a clean pedal platform, the change probably wouldn't justify the added expense. However, if your looking for something you don't currently have (ie. different distortion character, 4 hole design...), and you have the bug to buy one, you should return the Origin and get the SV. If the bug has bitten you, it most likely won't go away, and you'll be faced with selling the Origin at a loss to fund the SV down the road. If you were outside the return period on the Origin, things would be different. My 2 cents.
  15. pedecamp
    12,610
    8,029
    Correct, but you can always rotate the speaker a bit and reset the t-nut in fresh MDF. Been there done that. :yesway:
    steveb63, tce63 and Mitchell Pearrow like this.
  16. pedecamp
    12,610
    8,029
    Nice rig! You gotta get the SV20 and test them side by side and send back the one you don't want. That's the only way!
    I did exactly that with the ORI20H and DSL20HR, and sent them both back LOL.
    Sailindawg and tce63 like this.
  17. marshallmellowed
    Jun 26, 2009
    2,931
    2,554
    If that's doable, I agree, A/B comparisons leave no question.
  18. Michael Roe
    Mar 25, 2017
    977
    2,119
    Springfield, Ohio
    And that there is exactly the problem :) Those T-nuts don't set very well in MDF. You get what you pay for!
    tce63 likes this.
  19. ricksconnected
    Sep 29, 2015
    13,388
    6,613
    yes you do but in this case its not a deal breaker imho.
    tce63 likes this.
  20. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    4,781
    2,833
    Bay Area, CA
    Yes. dump it for the Studio Vintage....
