Removing the top handle
Discussion in 'The Workbench' started by stargazer76, Sep 26, 2015.
  1. stargazer76
    stargazer76 Active Member
    Mar 17, 2008
    287
    44
    Dallas, Texas
    How do you remove the carry handle from a jcm 800 4104 combo? It's the all black version, I want to replace it with a gold vintage one.
    Do you just pry up the end covers with something? Very hesitant to force anything with out knowing.
  2. stargazer76
    Mar 17, 2008
    287
    44
    Dallas, Texas
    Accompanied photo.
  3. mickeydg5
    22,684
    9,965
    It is something like this. Remove the end caps and you will see the machine screws.
    JAC likes this.
  4. stargazer76
    Mar 17, 2008
    287
    44
    Dallas, Texas
    The problem remains....getting the end caps off. I pry them a reasonable amount without success. They don't just pop off. I get to the point where it seems I will break something.
    Do I ignore the instinct to stop prying?
  5. mickeydg5
    22,684
    9,965
  6. mickeydg5
    22,684
    9,965
    I had a look at mine and honestly you have more of a chance or breaking them off then removing them intact. It is like they were never meant to be removed from outside.
  7. CaptainZero
    CaptainZero Well-Known Member
    Dec 18, 2010
    7,649
    5,547
    Minneapolis, MN
    Maybe they slide off? I have no idea, it's just a guess from the picture of the parts, so take that with a grain of salt.
  8. Guitar-Rocker
    Mar 5, 2012
    2,742
    2,325
    Indianapolis, Indiana
    A fine tip screwdriver inserted from the center of the strap going towards the end of the cover, pry the cover up and off. The covers that don't have the through bolts are snap fit type.
  9. mickeydg5
    22,684
    9,965
    I tried that a little while watching the cap. It looked as if the plastic would crack before it might pop off.
  10. Micky
    Apr 29, 2010
    20,379
    16,560
    Vermont
    So why all the concern if you have a new handle?
    Rip it off...
  11. mickeydg5
    22,684
    9,965
    Conservationism.
  12. stargazer76
    Mar 17, 2008
    287
    44
    Dallas, Texas
    Somebody wishes to buy the old one....
  13. ampmadscientist
    14,251
    8,071
    Oh, that's easy.
    Compared to removing the tube sockets.
  14. Micky
    Apr 29, 2010
    20,379
    16,560
    Vermont
    Then have THEM remove it.
  15. MarshallDog
    Nov 28, 2010
    12,122
    11,326
    Taintville
    I did the same thing on a JCM 800 head last year or so. These black caps are tough to get off and there is a good chance it will crack, one of mine did. You can see in the pick posted below that there is one small clip on the end of the bracket BUT there is also one notch on each side of the bracket. This is what makes it tough. There are little prongs on the black cap that snap into those little slots. I learned to slide a putty knife up under the plastic cap to protect the tolex in that area. Then using a small screwdriver, try to pry away one side and at the same time with another screwdriver, pry up the end and it will usually pop off. IF it breaks, so what, your replacing it with the gold one. Good luck.
  16. stargazer76
    Mar 17, 2008
    287
    44
    Dallas, Texas
    Thanks everyone for the ideas and suggestions. I didn't realize it would be such a challenge to get this thing off. For now the handle change goes onto the back burner....
  17. MarshallDog
    Nov 28, 2010
    12,122
    11,326
    Taintville
    If you have the new handle and really want to change it, just rip off the black caps, the gold handle will,fit right on, look better and make you happy. Just do it!
  18. a2dconverter
    a2dconverter New Member
    May 21, 2009
    11
    6
    Canada
    Hey StarGazer
    Here is a pic of the handle without the caps...
    you need to get 2 small screwdrivers to get between the metal and the plastic on each side of the cap and then it will lift straight up
    (PS the Gold caps do not fit the 4104 handle parts... you need to replace all of the old 4104 handle parts with all of the vintage parts)
    I hope this helps
    seeya
    Joe
  19. DmZ
    DmZ New Member
    May 5, 2015
    Push each cap in toward each other slightly. Each will move about 4-6mm, give or take, at which point the plastic cap tabs are no longer in the handle clamp slots, and they lift off with very little effort.
  20. KraftyBob
    KraftyBob Well-Known Member
    Sep 5, 2017
    1,108
    1,289
    Chicago Suburbs - USA
    I know this is an older thread but I figured I'd update with a little more info in case some else needs to remove the handle. This is for an MG amp but might work for others too. I think what DmZ mentioned above is for a different amp as the metal bracket fits tight inside the cover so there is no room to push it forward and release.
    I tried sliding a small screwdriver in there to separate the cover from the bracket but it wasn't budging. Then I realized I was between the bracket and the strap and not the bracket and the cover. The edge of the bracket sits behind a flange at the end of the plastic cap. See pic below - the white line represents the metal bracket.
    I slide a small screw driver on an angle over the top of the handle and down toward the slot, then took small needle nose pliers and gently pulled on the flange (making sure I didn't also grab the bracket) and the cap popped right off.
    Hope this helps
