Removing Paint Pen From Tolex
Discussion in 'The Workbench' started by thunderstruck507, Jul 27, 2017.
  1. thunderstruck507
    thunderstruck507 Well-Known Member
    Apr 20, 2017
    314
    353
    The TSL100 head I purchased has 2 large music note symbols painted on the ends. Appears to have been done with a silver paint pen, at first I thought it might just be Sharpie permanent marker but alcohol wipes didn't even begin to touch it so now I'm thinking it's actual enamel or acrylic paint.
    Before I start experimenting with solvents I thought it wouldn't hurt to ask what might remove the paint but not harm the color of the tolex?
  2. tbonesullivan
    tbonesullivan Member
    Jun 22, 2017
    77
    24
    The problem is that the solvents will most likely start messing with the tolex/vinyl before the paint comes off.
    That said, have you tried using physical methods? Like duct tape or packing tape? That may simply pull the paint right off.
  3. Kiko
    Kiko Active Member
    Jul 16, 2015
    341
    225
    Try acetone, test in a in a small/inconspicuous area first.
    ricksconnected likes this.
  4. twothemax
    twothemax Active Member
    Aug 9, 2010
    597
    103
    Oh Canada
    wd-40
  5. Micky
    Apr 29, 2010
    20,499
    16,794
    Vermont
    Fantastic or 409
  6. Gunner64
    Nov 16, 2013
    5,557
    6,741
    Midwest, USA
    Goo gone.
  7. thunderstruck507
    Apr 20, 2017
    314
    353
    Thanks guys, think I may try those in order of least abrasive.
    Duct tape
    Goo Gone
    Wd40
    409
    and then test acetone on the back and see if it hurts the tolex or not
  8. ricksconnected
    Sep 29, 2015
    13,388
    6,633
    everywhere you wanna be.
    WD will pull it off no problem.
  9. Hawkesman
    Hawkesman Active Member
    Jan 22, 2014
    166
    34
    UK
    And if all else fails, scrape/pick it off/out with a curved scalpel blade. Laborious, and you have to be very light-handed and careful not to damage the tolex, but it does work! Any tiny bits that you just can't get off then touch up with a good quality black permanent marker, and rub over hard and vigorously with a finger or thumb. Works wonders!
  10. GT08
    GT08 Active Member
    May 31, 2016
    290
    185
    Acetone (Nail Varnish remover) works on a lot of stuff.
    White Spirit.
    Solvent Electrical/Contact cleaner.
