Recording multiple tracks simultaneously
Discussion in 'The Tone Zone' started by Kim Lucky Day, Nov 20, 2019.
  1. Kim Lucky Day
    Kim Lucky Day Well-Known Member
    Aug 22, 2018
    124
    257
    I'm looking to live record my band. Currently we use a Behringer XR18 mixer, which has the capability to connect to a computer using a USB-A to USB-B cable and record to my DAW. The problem I'm running into is I cannot arm more than 2 tracks simultaneously in my DAW. My DAW is Samplitude Music Studio 2016. I've done forum searches on their website without any results that are reliable.
    Do any of you record your bands in a similar manner and if so, how do you have your DAW set up? Is this a matter of my sound card not being compatible (this was suggested on the forum)? My computer is a brand new "gaming" laptop that is loaded with RAM and processor speed. Thanks in advance for any help you can offer.
  2. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    1,860
    1,701
    Calgary, Canada
  3. Kim Lucky Day
    Aug 22, 2018
    124
    257
    I've watched these videos. I found it interesting that they arm each track first, then select the inputs. No matter what I've tried so far, I can only arm tracks 1 and 2 at the most. When trying to arm any more, tracks 1 and 2 turn off.
    Granted I only have had 30 minutes or so to tinker with this but I hit this wall right away...
  4. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,364
    3,279
    Springfield, Ohio
    Is your DAW actually seeing and connecting to your audio interface? maybe you need a driver? or the current driver?
    Your mixer isn't exactly a typical audio interface. It's a mixer as well so you may need special software or another piece of software to make it work.
    I don't use either things that you have but I use a Presonus interface with Studio One DAW. On my setup, I have a program just for the audio interface and then a separate for my DAW. Mine is very compatible being made by the same company. You may have to have your Behringer mixer program up and loaded before you start your DAW program.
    Also, your operating system could not be setup correctly to work.
  5. Filipe Soares
    Mar 8, 2019
    546
    808
    why don't you try a different DAW, like reaper?
  6. Kim Lucky Day
    Aug 22, 2018
    124
    257
    I've considered it. If I do, Reaper is certainly near the top of my list. I just need some more time to figure this out I guess.
  7. Dogs of Doom
    19,511
    19,329
  8. Dogs of Doom
    19,511
    19,329
    what do you have the settings for, for your sound device?
