Really Struggling With The Cost Of Dsl40c Head Chassis
Discussion in 'Marshall Amps' started by bobpick68, Feb 10, 2019.
  1. bobpick68
    bobpick68 Well-Known Member
    Sep 4, 2018
    309
    572
    It's not that I "can't" afford one it's that they are 250-300 bucks and you gotta wait a month. Someone please tell me these ship out much faster than a month and they just say a month because it's the whole "under promise, over deliver" thing going on?
    I mean that's more than half of what I paid for the whole amp. I guess it comes down to how bad do I want it to be a head. Just not there yet I guess.
    If anyone reading this is selling one hit me up. I'd love to get my hands on a used one for 150-175 bucks or so.
    stringtree and Mitchell Pearrow like this.
  2. pedecamp
    12,606
    8,028
    If you gotta have a box that fast and that bad, build a temporary box and put it in while you wait for the factory to make you the permanent box. Take you an hour or two to cut some wood and screw it together.
    bobpick68 likes this.
  3. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,113
    2,681
  4. bobpick68
    Sep 4, 2018
    309
    572
    I can't hang a curtain rod straight. I purposely have no wood working tools or skills whatsoever because I am so bad at it.
    Jethro Rocker, stringtree and NateSLC like this.
  5. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,623
    4,996
    Midwest, USA
    How wide is the chassis?..almost looks like an MG headbox. My point being can another box be repurposed? I have an empty MG box, measure the chassis.
    ricksconnected and stringtree like this.
  6. pedecamp
    12,606
    8,028
    I guess then youre at the mercy of the factory and gonna have to be patient. :shrug:
  7. Len
    Len Well-Known Member
    Sep 13, 2009
    985
    748
    Price is driven by demand. I paid that price for my DSL40 head cab, as did many others, so it’s probably not going down any time soon. That’s a lot of manual labor to cut, screw and glue the parts.
    As far as turn around time, I waited 2+ months for mine (it was the first that Stage Craft built), so 1 month seems quick to me.
    bobpick68, stringtree and steveb63 like this.
  8. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,093
    1,810
    Wa State
    How about a skilled finish carpenter friend in your area ?
    I did a Head Crop Chop on mine
    Skill Level … Intermediate
    Tools … Table Saw, Drill and Various Bits , Staple Gun, Tape Maesure
    Supplies … Blue Masking Tape , Wood Glue
    Fear Factor … Extreme
  9. Exojam
    Exojam Well-Known Member
    May 31, 2017
    463
    308
    And I still have not seen the steps to do thi s like we discussed a few months ago :fever:
  10. Gunner64
    Nov 16, 2013
    4,623
    4,996
    Midwest, USA
    Or not.
  11. Jon C
    May 29, 2017
    1,093
    1,810
    Wa State
    It's subjective as to how high the quality of workmanship needs to be for your own personal preference ..
    Not to disparage anyone's abilities or work…
    Before I chopped mine up, I spent a considerable amount of time measuring , staring, thinking, rethinking …
    I thought a lot about esthetics ( where would the Logo end up when I was done )
    Could I roll tubes without a pull ( enough space )
    The bottom horizontal stop to brace the back cover
    Support for the Tolex where it would flyover the remaining speaker cutout
    One can just pull the amp and jigsaw the whole thing and it will still work
    OR
    One can dig deep on every detail
    If that was TLDR ,
    Step #1 …… Cut the bottom of the cab off
    stringtree likes this.
  12. BftGibson
    May 28, 2018
    1,113
    2,681
    Take amp out
    measure from top down to the desired height on sides
    cut combo on sides
    take left over sides on the bottom off
    reattach bottom to new cut side
    measure and cut speaker baffle with logo centered how you want
    put cut baffle back in
    put amp guts back in
    cut rear metal screen to appropriate size
    attach metal screen
    its a very logical progression
    only tools i needed
    blue painters tape
    utility knife
    tape measure
    phillips screwdrivr
    strait edge
    circular saw
    construction glue
    stringtree and Jon C like this.
  13. Jon C
    May 29, 2017
    1,093
    1,810
    Wa State
    I did mine the same way with the following exceptions :
    I used a table saw to remove a segment out of the entire cabinet
    I left enough of the base to include the bottom stop
    I also ripped the back with the table saw to fit
    In my case I omitted the screened area all together
    I used a small piece of the scrap to fill in the speaker arch before pulling the grill cloth back over the bottom edge
    stringtree and BftGibson like this.
  14. Mitchell Pearrow
    6,931
    9,487
    You may not find one so easily, but they do fit in the lead 100 mosfet head shells, the mg head shells are a bit wider I do believe, I can’t remember, but the easiest way would be grab a buddy that owns a table saw, remove everything from the 40c’s cabinet and set the rip fence to the height you need to house all the chassis components, and run it through, the table saw will ensure you have square, even cuts all four sides, then it’s just a matter of putting it all back together, I have done this procedure on a fender m80 bass combo, I ran the stock cabinet through to get the head size, then the bottom of the cab to make the bottom, once the rip fence was set for the second dimension, I think it took longer to pull the chassis than to do everything else, probably took me longer to type this response, than it took me to do all that is mentioned above! Cheers Mitch
    Jon C, stringtree and BftGibson like this.
  15. BftGibson
    May 28, 2018
    1,113
    2,681
  16. BftGibson
    May 28, 2018
    1,113
    2,681
    this was actually fun !!took a chance and left everything intact and scored tolex & cut baffle cloth with utility knife and the painters tape kept it all from fraying. Nice & SLOWWWW with the circular saw..lol..me of no patience had to coach my self that over and over ...def have hacked a few up in the past...[/QUOTE]
  17. stringtree
    stringtree Well-Known Member
    May 21, 2016
    708
    1,164
    I've done something like this too! :dude:
    Not me..:shock:
    Just a video I found showing how it could be done.
    bobpick68, Mitchell Pearrow and Jon C like this.
  18. Mitchell Pearrow
    6,931
    9,487
    [/QUOTE]
    I did forget to say anything about the grill cloth, when I did it on the m80 the grill was absent an it had no tolex just that stupid fur, or whatever they call it, and Bft I have to hand it to ya for just grabbing the ole skilsaw , I happened to have the little dewalt table saw so that was what I used
    Jon C likes this.
  19. Jon C
    May 29, 2017
    1,093
    1,810
    Wa State
    bobpick68, tce63 and Mitchell Pearrow like this.
  20. Jon C
    May 29, 2017
    1,093
    1,810
    Wa State
    That is very cool !!
    I love the way you thought about leaving the bottom stop on !!
    In my case I did leave it ……
