Radiospares JTM45 indicator - changing bulb?
Discussion in 'The Workbench' started by shakti, Jul 23, 2019.
  1. shakti
    shakti Member
    Jul 14, 2016
    50
    23
    I have two of these which annoyingly have died on me recently. One is Radiospares labeled and has the solder tags on the end, the other is the type that looks identical but isn't Radiospares labeled (no label) and has hardwired leads. There is some debate about whether the latter was ever originally used by Marshall, but my clone doesn't care about that...only that it looks right and it wants the indicator bulb to work!
    Is there any way to change the bulb in these? They are becoming hard to find.
  2. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    566
    204
    I haven't changed the bulb yet but they do come apart and I have one dismantled here. Looking to complete the project.
    EDIT- I dismantled a leaded version so don't know.
  3. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    646
    335
    Valvestorm sells a 120 volt version with solder tabs and a 6 volt one with hard wires. Do you know which one you need?
  4. junk notes
    junk notes Active Member
    Dec 10, 2018
    137
    127
    Thinking that they were the same, I did not realize that the 6v replacement bulb I happened to get was one of those LED's. My mistake I did not get it from a legit amp site that sells vintage spec amp parts like ValveStorm.
    The LED version was so luminous that you needed sunglasses.
    Did not mind doing the job twice to get it right. All good now. :)
  5. shakti
    shakti Member
    Jul 14, 2016
    50
    23
    The lamps shown above are the square indicator type that was introduced in late 66. The one I'm using is the type that was used prior to that, and is round. Looks like I can still get a replacement on Ebay, but somehwhat expensive:
    https://www.ebay.co.uk/itm/MARSHALL...rentrq:225659fc16c0ac3c2b023ae7ff5bbfd8|iid:1
    Has anyone succesfully changed the bulb in these, and with what?
    (For the record, I am aware that Marshall used the amber coloured ones, but those are very rare and stupid expensive, so red will have to do).
  6. Chris-in-LA
    Jul 19, 2018
    646
    335
    I thought you said that your clone didn’t care.
  7. fifteenohms
    fifteenohms Well-Known Member
    Sep 30, 2010
    1,071
    537
    Los Angeles, CA
    Jerry Blaha once told me the 6V originals affected the tube operation and gave a sag to the sound, which if changed to 120v somehow ruins the tone.
    If you had a 6v only use that to replace per that reference.
  8. shakti
    shakti Member
    Jul 14, 2016
    50
    23
    I can't see how a bulb wired to the heaters would affect sag in any way. But feel free to educate me.
    My clone doesn't care if the lamp is Radiospares or similar non-RS, and whether it's red or amber. But it cares that it looks correct for a mid-60s clone and that it works.
    So the question remains; is there anywhere to get a replacement bulb (240V or 6,3V) and is it possible to put that into the existing lamp?
  9. neikeel
    3,410
    1,851
    I have never had one fail (unlike the red square ones!). If you are stuck I have both amber and red, solder lug and red wire versions knocking around.
    I looked at the design and can only see that it will come apart by cutting the white body off because undoing the crimp will almost certainly destroy the chrome part.
  10. shakti
    shakti Member
    Jul 14, 2016
    50
    23
    I'll PM you Neil. :)
  11. Guitar-Rocker
    Mar 5, 2012
    2,731
    2,315
    Indianapolis, Indiana
    I find it rich that there is an idea that filament indicator lights affects tone
    Changes in B+ / charging and discharge pulses of reservoir caps affect sag.
  12. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    1,761
    1,150
    Las Vegas, NV
    Yes, but, well, ya know, but, but, maybe, seeing as how the color or the wire insulation can affect tone, well, ya know...... :run: :rofl: :rolleyes:
    Who Loves Ya baby! :cheers:
    Gene
  13. ampmadscientist
    13,453
    7,313
    Normally there is no way to change the original bulb.
    But with certain modifications, there might be a way to change the bulb.
    In the meantime, there is replacements which approximate the original appearance.
