Question....
Discussion in 'Marshall Amps' started by slash38, Sep 29, 2012.
  1. slash38
    slash38 Active Member
    Aug 25, 2010
    672
    109
    Brooklyn NY
    I have the MXR 10-band EQ and the jubilee. And i need a boost for some songs like November rain, Estranged, and a little of Knockin' on heavens door. Would that be the best to boost solos or i have been looking at the MXR mc401. I like the 10 band eq for the stuff i need it for, but i feel like the mc401 gives it a little bit more volume boost while the 10 band eq gives it a little bit of a gain boost IMO. What's a good verdict on this one?
  2. Username2
    Username2 New Member
    Feb 15, 2011
    4,415
    4,695
    Treble booster in the loop.
    Marival likes this.
  3. MonstersOfTheMidway
    May 1, 2008
    5,033
    2,663
    get a JVM and use Master Volume 2 as your "boost"
  4. guitargoalie
    guitargoalie Well-Known Member
    Jun 23, 2010
    1,469
    795
    Ontario, Canada
    volume or gain boost? Im not sure how the slides work on the mxr but put the level above normal volume in front for gain, in the loop for volume boost
  5. SwampThing
    SwampThing New Member
    May 21, 2011
    2,669
    1,827
    Beaufort, SC
    If you have the Jube you're halfway there. Just me but if you're looking for a boost for solo's only A good clean boost pedal will probably get you there. I wouldnt even mess with the eq.
  6. slash38
    Aug 25, 2010
    672
    109
    Brooklyn NY
    Ten band EQ is great for the songs i named, but then there are sometimes when i just want a clean boost.
  7. SwampThing
    May 21, 2011
    2,669
    1,827
    Beaufort, SC
    Try this. Ive had it since it came out and like Rob Burgundy its the BALLS..
    MXR MC402 CAE Boost / Overdrive
  8. slash38
    Aug 25, 2010
    672
    109
    Brooklyn NY
    i've seen that, but the mc401 is just one knob for the db level. Have you ever tried that, because i heard that's a clean boost but i never played one in person.
  9. mickeydg5
    mickeydg5 Well-Known Member
    24,644
    11,590
    The MC402 has the same clean boost as the MC401 but offers the addition of an overdrive.
  10. mariosoldano
    mariosoldano Active Member
    Aug 27, 2011
    307
    109
    Germany
    when all band sliders are on +- 0 the volume slider works as a booster when yoe put him up:slash:
  11. Neylus
    Neylus Active Member
    Apr 24, 2011
    468
    128
    When I play with my Jube, I put the MXR MC-401 as a solo (volume) boost for solos, works really well in the loop actually.
    SwampThing likes this.
  12. kam4ff
    kam4ff Active Member
    May 21, 2010
    223
    36
    Have your same thing. I have a Jube and the 10 band and use an ep boost for solos.
  13. SwampThing
    May 21, 2011
    2,669
    1,827
    Beaufort, SC
    This. Best of both worlds.
  14. slash38
    Aug 25, 2010
    672
    109
    Brooklyn NY
    I was just thinking of putting all the sliders on 0 and just raise the volume an gain sliders a little bit.
