Proper Method to Connect Separate 8 and 16 Ohm cabinets to a Marshall?
Discussion in 'Marshall Amps' started by Sacalait, Aug 22, 2019.
  1. Sacalait
    Sacalait Active Member
    Oct 15, 2012
    89
    246
    South Louisiana
    I did a quick Google but didn't really find anything. Both my JVM205 and SV20 have three "sets" of speaker jacks- 1-16 ohm, 2- 16 ohm (8 ohm load), and 2- 8 ohm (4 ohm load) speaker outs. I get that I plug two 16 ohm cabs into the 2- 16 ohm outputs to have a safe 8 ohm load on the amp. But what's the proper method of plugging an 8 ohm and a 16 ohm cab?
  2. Sacalait
    Oct 15, 2012
    89
    246
    South Louisiana
    I'm guessing one cab into one of the two 16 Ohm sets and one cab into one of the two 8 ohm sets. But I don't wanna guess!!
  3. mickeydg5
    21,751
    9,312
    Do you mean connecting both a 16 ohm and a 8 ohm cabinet at the same time?
    If so, the 16 ohm cabinet gets plugged into an 8 ohm output jack and the 8 ohm cabinet gets plugged into a 4 ohm output jack.
    Sacalait and Jethro Rocker like this.
  4. ampmadscientist
    13,031
    6,902
    Start the reactor. free Mars!
    If you use 16 ohm + 8 ohm, the total is 5.3 ohms.
    The amp must be set 4 ohm out to run that load.
    Speakers formula
    Speaker 1 X speaker 2
    -------------------------- = total load
    Speaker 1 + speaker 2
  5. Micky
    Apr 29, 2010
    20,172
    16,218
    Vermont
    Not with a JVM...
  6. mickeydg5
    21,751
    9,312
    did not catch on to this yet
    short attention span
    :shrug: :D
    Or with an SV20 as well. :yesway:
    Jethro Rocker likes this.
  7. Jethro Rocker
    6,995
    6,755
    Any amp with multiple outputs including SJ Reissues can be used in this way. Amps with an impedance switch cannot.
  8. Sacalait
    Oct 15, 2012
    89
    246
    South Louisiana
    All agree?
    tce63 likes this.
  9. Jethro Rocker
    6,995
    6,755
    Yes. We don't all have to ahree, really. It's a fact.
    Sacalait likes this.
  10. mickeydg5
    21,751
    9,312
    Well you know I make shit up and I also state that I do not know anything. :D
  11. LPMarshall hack
    Nov 18, 2009
    9,782
    7,820
    San Diego, CA
    Wait, so on those modern Marshalls with all those cabinet configuration jacks, you can use speakers of different ohms?
    I always thought that was a no no.
    Good to know I can plug my 16ohm 4x12 and my 8ohm 2x12 cabs into my JMD. Is this right?
    Edit: looks like the JMD does nit have a 4ohm out.:mad:
  12. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,556
    1,474
    Wilton NSW
    its cool, and was confirmed for us years ago by Santiago (JVM desgner) on this forum
    Each speaker goes to an amp tap of half its ohm rating, and hence each provides half the load that the amp needs, and each gets half the power. All perfectly good and logical.
    Its not put in the manuals though, too hard to reliably explain to the average Joe Rocker.
    LPMarshall hack likes this.
  13. mickeydg5
    21,751
    9,312
    You can always use a 32 ohm cabinet and a 16 ohm cabinet with your JMD:1. :D
