Preamp tubes for the JVM (more bite and gain)
Discussion in 'The Workbench' started by Guitarjon, Nov 17, 2019.
  1. Guitarjon
    Guitarjon Member
    Nov 13, 2019
    25
    71
    I got my used JVM410H yesterday. It's a great amp! I love the versatility it has to offer and the high gain tones are tight!
    The previous owner had it retubed and serviced recently so the amp now has JJ tubes in all the sockets. I did however notice that the clean and crunch channel didn't have quite as much gain as I was expecting from demo's I've seen. I also feel like the crunch channel is a little dark or I would like it if there was a tad more bite.
    So are there any pre-amp tubes you guys would recommend to get a little bit more gain and bite on the clean and crunch channels? I'm not a tube expert so mixing and matching is something I'd rather not do yet. I'd prefer to buy a set of tubes from one brand to start with.
    Any suggestions would be appreciated.
    Cheers! :)
    Edit: I think if I just change the V1 to an EHX for example I should already get a little bit more bite. Not 100% sure though.
    SkyMonkey likes this.
  2. SkyMonkey
    1,024
    1,079
    Sheffield, UK
    Peter McAteer and Guitarjon like this.
  3. Guitarjon
    Guitarjon Member
    Nov 13, 2019
    25
    71
    The invoice from the amp tech just said 'JJ 12AX7 V1, 3x JJ 12AX7 etc.'
    JJ's are a bit darker sounding indeed. They worked well for my Dual Rectifier but now that I want to brighten the JVM up a bit more I want to try something else. I did read the the EHX tubes are brighter overall.
  4. Emtbreid
    Emtbreid Well-Known Member
    Oct 22, 2018
    466
    576
    East Coast, USA
    I changed 4 preamp tubes to JJ last December, and agree, darker tone. I pulled v1 and replaced it with a tung sol. Much improved. And more gain as well... You’d be better off mixing and matching. Get a few different makes and swap them around until you find a combo you like. I’ve heard tung sol don’t mix well in cathode follower positions, so be aware of that. V1 will have the biggest impact for you.
    Guitarjon likes this.
  5. Guitarjon
    Guitarjon Member
    Nov 13, 2019
    25
    71
    Great! I just ordered a couple EHX's including a V1 but I also added a Tung Sol V1 for comparing. Should be interesting! :)
  6. Emtbreid
    Oct 22, 2018
    466
    576
    East Coast, USA
    It’s all personal taste. Tung sol is the only thing I put in v1 aside from the Chinese one in there originally, and the JJ I replaced it with. I’m really digging the tung sol. You may find something different Works better, that’s the beauty of it!
  7. SkyMonkey
    1,024
    1,079
    Sheffield, UK
    I would still check the codes on the actual tubes.
    Perceived gain comes from the pickups too. The demo you watched may have been with a guitar with higher output pickups than yours.
  8. Emtbreid
    Oct 22, 2018
    466
    576
    East Coast, USA
    Or pedals. You may hear my amp and say “damn”! But what you may not see is the 10 band eq in the loop and tubescreamer out front. I see folks that do amp “reviews” all the time that use pedals.
  9. ampmadscientist
    14,271
    8,082
    Maybe you should look at this video?
    I spied about 3 preamp tubes that I liked in the video, these were crunchier crispier and had some added low end hunk.
    But comparing the JJs preamp tubes to others, the JJs were not anywhere near the bottom of the pile. They held up pretty good against the other choices.
    It seemed that the TAD preamp tubes were by far the weakest and wimpy-est.
    Not in the video: Sino tubes. I think you should try them.
    Peter McAteer likes this.
  10. pedecamp
    13,360
    9,441
    Get some Chinese tubes like Shuguang, Sino, Ruby, PM, etc.
  11. Dogs of Doom
    19,509
    19,314
    if going w/ all new tubes, I would be inclined to try JJ in V1 & Chinese in the rest...
    I was talking to Santiago & he said that the JJ is the quietest tube, so, using it in V1 helps keep the amp more quiet during high gain. The rest of the tubes, the Chinese are aggressive & the noise isn't as much a factor...
    So, whatever you find, Shuguang, Sino, etc., they are the same. I think thetubestore, sells them as Chinese... :shrug:
    The JVM, a lot of the magic comes from getting the presence dialed in right. Too hot, it can be piercing. Not hot enough, it sounds dull. Just right & it has a certain amount of excitement in the upper harmonics & just screams...
  12. Bloodrock
    Bloodrock Well-Known Member
    Aug 12, 2010
    2,524
    2,602
    Ft.WorthTX
    Try a JJ ec823 in V1. It brings the od orange and red modes down to usable gain levels.
  13. dragonvalve
    dragonvalve Active Member
    Jan 16, 2010
    280
    192
    Shuguangs will brighten things up. Also some RCA's if you can afford them.
  14. Emtbreid
    Oct 22, 2018
    466
    576
    East Coast, USA
    Really? My stock Marshall preamp tubes were shunguang and I thought they made The amp sound dark. Least at first I did. They were original (14 yrs old). I still use an Mxr 10 band eq and tubescreamer to brighten things up ... I have a tung sol in v1 of my dsl401 and JJ In the rest.
  15. dragonvalve
    Jan 16, 2010
    280
    192
    The Shuguangs don't last too long as with most of the tubes made after America and the rest of the great tube makers shut down production.
    Then yes add some pedals because the tubes can't do it all.
    After that swap out the speakers to coaxials and you'll be wearing ear muffs. Won't even need that MXR for anything but a high freq attenuator.
    EMINENCE BETA 12CX 12" Coaxial WOOFER With ASD1001 1" Titanium DRIVER
    RADIAN 5312 - COAXIAL
  16. mickeydg5
    22,722
    9,979
    Sino is China. Shuguang and Psvane are in China.
    Ruby, PM, Groove Tubes and the likes purchase, resell, distribute tubes which include those manufactured by Shuguang.
    The Ruby, Audio Classic and TAD in Segeborn's video posted above are Shuguang.
  17. mickeydg5
    22,722
    9,979
    A make/model of a tube does not mean it sounds good or exactly the same.
    The strength of the tube matters a lot. Not all tubes are equal.
    Timing with regards to batches can even make a difference.
    You cannot arbitrarily pick one tube and say all tubes such as these sound exactly like this.
  18. Peter McAteer
    Peter McAteer Member
    Sep 9, 2019
    99
    95
    The North Shore of Lake Ontario
    I tried that in my DSL15....now the red channel sounds good, instead of like a design flaw.
  19. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    4,846
    2,898
    Bay Area, CA
    You can mix different 12ax7’s to find the right balance...
    dragonvalve likes this.
  20. Emtbreid
    Oct 22, 2018
    466
    576
    East Coast, USA
    Interesting speaker.... I ditched the stock celestion gold back for an 83’ G12-65 and love it.
