Preamp tubes, best place to buy
Discussion in 'The Workbench' started by Crikey, Oct 28, 2019.
  1. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    727
    1,173
    Doug’s Tubes is great
    SteelLucky likes this.
  2. Crikey
    Crikey Well-Known Member
    Feb 16, 2019
    320
    461
    Thanks for the great info. I ordered tubes from Eurotubes. Great customer service. Tubes in route
    pedecamp likes this.
  3. pedecamp
    13,629
    9,928
    Wow 5 that's alot of preamp tubes, I'm used to seeing 3 or 4.
  4. MarshallDog
    Nov 28, 2010
    12,566
    12,215
    Taintville
    Buy a Fender...My new 68 Custom Deluxe Reverb has (6) but one is for the reverb circuit I am told.
  5. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,137
    3,361
    C-137
    That amp calls for all 12ax7's...even for the Reverb Driver.
    If you put a 12at7 in the reverb slot, you'll loose some gain.
    V2 is your heavy hitter for the Boost Channel.
    Crikey likes this.
  6. mAx___
    mAx___ Active Member
    Apr 3, 2012
    452
    171
    Tubemonger.com
  7. ampmadscientist
    14,862
    8,724
    Maybe you hear rumors, but I have had no problems with JJ tubes and I buy them all the time.
    I don't believe there is anything wrong with them. Not only this I will keep buying them.
  8. Filipe Soares
    Mar 8, 2019
    624
    963
    yes just rumors, but I´ll still be buying them untill something bad happens. Two months ago I´ve bought a KT88 quad for my major and I couldn't be happier.
  9. Crikey
    Feb 16, 2019
    320
    461
    5. But it has glorious overdrive so no complaints here. Also got some for my budda twinmaster.
    wakjob and pedecamp like this.
  10. pedecamp
    13,629
    9,928
    That amp has tube reverb right, so that explains it.
  11. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    4,912
    2,979
    Bay Area, CA
    You can mix preamp tubes to see which tubes sound best for you...
    I dont have an 800, but for my Plexi clone, I use JJ ecc803 in v1, 7025 on V2 and PI... It added that extra girth and cleaner gain tone (not fuzzy or ear piercing high frequency) when it the amp is dimed...
    Tungsol is the gainest current production 12ax7 out there...
  12. Crikey
    Feb 16, 2019
    320
    461
    Update: received and installed the preamp tubes from Eurotubes for the 4211/2210 Jcm 800 . Wow. what a difference in the Marshall. Its not saggy sounding any more, crisp and chimy. love it. Didn't mess with the power tubes yet and have not detected any issues so will keep them for a while longer.
    The Budda Twinmaster had highend tubes from Svetlana ( Russia), Ei ( yugoslavia) with the gold tips. The JJ tubes that I installed sound good but there is a slight difference in the tone which was bright and matchless sounding which is a great sound. The new sound is tight and sounds like a Marshall and hits you in the chest. Not bad for 18 watts.
    Questions:
    1. I wonder if the tone change is from the ECC83 S replacing the 12AX7s or the 54UG being replaced by a 54UGB?
    2. would the tone change be more impacted by the el84s?
    Thoughts?
    Great experience with Eurotubes. recommend them.
  13. dragonvalve
    dragonvalve Active Member
    Jan 16, 2010
    280
    193
    if you're serious about tubes, try Brendan at TubeWorld Express.
    https://tubeworldexpress.com
    He has lots of well preserved, tested and in original boxes vintage tubes.
    Some are pricey but he has some that are affordable.
    Tubes made today are not made the same way when America, UK, France, Germany made them. Mainly they don't spend enough time in the "hard vacuuming process" as it takes a while and when the majors closed shop in the US they destroyed those vacuuming machines.
    Crikey and Nik Henville like this.
