PowerBrake feet...?
Discussion in 'The Workbench' started by myersbw, May 17, 2019.
  1. myersbw
    myersbw Well-Known Member
    Oct 22, 2015
    1,025
    473
    SW Ohio
    Hey Folks,
    I've got a PowerBrake that came with velcro and no feet. But, I need to get the cab solid. The problem - I can't find anywhere a photo or detail as to the type of feet those shipped with. There don't seem to be threaded holes unless they were huge. I also will be lucky to have a 1/4" of play inside the chassis under the board hosting the jacks. The other three holes have plenty of room. I may be able to use the nylon push rivets through some new rubber feet. Anyone have a photo detail of a foot so I can see what to go after? Oddly enough, I can't turn anything up from a search and really need to get it resolved in a day.
    Yes, I could JBWeld a few nuts to the inside...that's the last recourse, but a simpler fix would be great.
    Thanks!
    Brad
  2. mickeydg5
    mickeydg5 Well-Known Member
    24,643
    11,588
  3. myersbw
    Oct 22, 2015
    1,025
    473
    SW Ohio
    Thanks, MDG...what I'm looking for is a photo of a foot...and to see how that's mounted. Maybe they used a coarse thread in the holes drilled? Doesn't look like anyone pushed out some threaded inserts. I'm likely just going to take the whole thing in disassembled to a local HomeDepot and find a threaded screw that will fit the hole...then drive on over to PartsExpress and grab some feet and cut the threads to length. Three holes...tons of room...one only gives me about a 1/4" at best before I het the jack board.
  4. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
    On mine they are them push lock kind of things..like a plastic expandable rivet. It is stock I believe..I'm Not home right now or I would take a pic.
  5. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
  6. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
  7. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
    Actually a plastic screw with an expandable insert that spreads out as the screw is pushed in. They don't actually screw tighten but do screw out when the foot is pulled up on, and the screw is turned.
  8. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    900
    820
    house arrest
    Before you put the feet back on, take chassis cover off and
    mod it.
  9. myersbw
    Oct 22, 2015
    1,025
    473
    SW Ohio
    Thanks, Gunner! I've already modded it and swapped it off. I ended up using low profile, wide feet and some self-drilling sheet metal screws. Here's the result. And, yeah, since those holes were the same size, I figured it was something like what you have. Thanks for sharing!!! Mine didn't have the extra chassis screws. But, it does now! ;)
    So, that rejuvenated...that and an OCD 1.7 was swapped for this...
    ...might gut it an do point-to-point build...undecided.
    Gunner64 likes this.
  10. Trapland
    Trapland Well-Known Member
    Dec 5, 2013
    1,271
    1,127
    Minneapolis
    What mods did you do?
  11. myersbw
    Oct 22, 2015
    1,025
    473
    SW Ohio
    Bahahahaha...I didn't! I did what any smart tone-seeking guitar player would do! I swapped it for an Orange Jim Root #4! :O :) (Lol, you can see my swap fodder in the 'Other Amps' forum!)
  12. junk notes
    Dec 10, 2018
    900
    820
    house arrest
    ha
  13. pietronet
    pietronet New Member
    Feb 1, 2014
    19
    2
    Hi guys, I broke one of the plastic screws that fits inside the foot. Do you know where I can get some spare ones ?
    thx
  14. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,707
    1,657
    Sounds like an automotive fastener?
  15. SkyMonkey
    1,964
    2,413
    Indoors
    I would use any short bolt and a matching nut(s) that fit. Nobody is ever going to see that they are not original. I doubt the exact insert you are looking for is made anymore.
    Open up the housing and install the foot with the bolt. Attach the nut (or preferably 2 to lock together), and maybe file off anything proud of the nut to prevent internal fouling/shorting.
  16. pietronet
    Feb 1, 2014
    19
    2
    But it is not needed to remove the foot to open the enclosure. I do not have it with me right now. Because if it is the case I can add screw and bolt
  17. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
    Yes you do have to remove the feet to open the case. And you can't use a nut and bolt because the case is closed up when its back together. The foot mount holes and the case screws go through both halves of the case.
    SkyMonkey likes this.
  18. pietronet
    Feb 1, 2014
    19
    2
    Ok thx, so it confirms I need the spare part.
  19. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
    Unless you use bigger self tapping screws in the existing feet holes... Or drill new holes...or stick on feet..
  20. pietronet
    Feb 1, 2014
    19
    2
    Yeah... But I would like to keep it "original"...
