Power tubes matched?
Discussion in 'The Workbench' started by Emtbreid, Aug 31, 2019.
  1. Dogs of Doom
    19,846
    20,056
    Micky should have a thread about fine-tuning that amp. On the DSL, Marshall's recommended biases were hot. Many people have found that running them lower bias, helped the amp breathe a bit & opened it up.
    I'm not sure about the EL84s though. Marshall recommended 90mv on the 100 watters (45mv/tube) Many people like the bias in the 30s better. So, running around 37mv is more ideal. I think I've even seen a few people say that they like it at 32mv...
    Both are pretty far from the Marshall recommendation.
    Also, the tubes should last longer.
    I'm not sure at the .55mv you're getting, or what EL84 tubes are supposed to run at, but, maybe look around Micky's thread...
  2. Dogs of Doom
    19,846
    20,056
  3. Emtbreid
    Emtbreid Well-Known Member
    Oct 22, 2018
    583
    608
    East Coast, USA
    Yeah, the pre 2003 models were supposed to be biased at 1.375v, way too hot. Mine is a 2004 (confirmed that my board has the resistor changes that they made), and a paper I got from Marshall recommended between 540 and 560mv. Believe 560mv gives 14ma per valve, so I set in between. I’ll check out his thread. Setting at 550 sounds good for now.
    Dogs of Doom likes this.
  4. Dogs of Doom
    19,846
    20,056
  5. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    Thank you! I’d seen John H stating he biased up to .700mv, but I also thought I’d seen someone state that was pretty hot? I checked the bias a week or two ago before I got new tubes and it was at .410 and sounded horrible. I’ll let these settle and try to bump it up to .700 and see how it sounds .... I don’t fancy building internal fans etc to keep cool, but i do keep a fan behind it to turn on when it starts to get a bit warm...I noticed soon as I raised the bias it started getting hotter.
  6. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    I am very proud that I was able to do this on my own more or less with advice from the forum instead Of taking it in and paying someone to do it for me. My local amp ship wanted to charge me $65 just for the power tubes and another $75 for retube, bias, and “checkup”.... I paid $36 for the tubes shipped. And $10 for a multimeter and set of alligator clips ...
  7. Dogs of Doom
    19,846
    20,056
  8. Dogs of Doom
    19,846
    20,056
    the probe clips I find work best for the Marshall bias pins, are the spring loaded J-clips:
    mickeydg5 likes this.
  9. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    Ah, I see... that would’ve made things a bit easier. I used alligator clips to hit one of the side pins and the middle ground. Seemed to work ok but this Looks a lot easier..
  10. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    Thanks for posting that. I know I’d seen that before. I definitely didn’t let the amp stabilize and sit for half an hour last night before setting that bias (5 mins maybe), so, I took the chassis out again and lo and behold, the bias was all out of whack. So, following his instructions, I set the bias pot low as it could go, and waited 30 minutes. I decided to go a bit above what Marshall states on that bulletin (that I’ve heard may be too cold) and I set it at .650mv (.65mv or 16.25 per el84) to see what that sounds like for a bit.
  11. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
  12. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    472
    242
    Agreed.
    I prefer the sound of a mismatch. If you mismatch too much, it can cause problems. Matched tubes exhibit less noise. But don't sound as nice to me.
    At the end of the day, my amps all have individual bias per tube. So I really don't need to buy matched tubes anyway.
  13. JackPlug
    JackPlug New Member
    Sep 1, 2019
    13
    16
    back in the old days we never cared about matching and amps didn't break. We simply plugged whatver we had on hand and rarely biased the amps.
    I do like to have them checked and tidied but tube amps seem to be quite forgiving!
  14. mickeydg5
    23,283
    10,371
    Yes in the old days they did care.
    I have a stereo amplifier from the 1960's and it tells you to replace with matched tubes that can meet at a specific idle bias within adjustment range of the amplifier.
    Now back then matching tubes may not have been as big a deal and anything under 20% out was considered matching.
    However, I do not agree with the 20% tolerance.
  15. john hammond
    Mar 5, 2019
    952
    442
    ironballs, they were most likely cathode biased he's referring to, cathode biased amps you chuck anything in there.
    5e3 tweed deluxe, chuck any 6v6 in there, 250 ohm cathode resistor.
  16. mickeydg5
    23,283
    10,371
    But not all tube amplifier's are cathode bias.
  17. john hammond
    Mar 5, 2019
    952
    442
    he may be referring to those fender silverface things whereby you just turn a pot to ' balance hum'...did they have fixed adjustable or what? I can of course simply check but its more fun asking
  18. mickeydg5
    23,283
    10,371
    What amplifier(s) are you refering to in this post?
  19. JackPlug
    JackPlug New Member
    Sep 1, 2019
    13
    16
    50W Marshalls, 2204. When a tube went, we simply plugged another one. Little we knew !!
  20. mickeydg5
    23,283
    10,371
    Exactly, little you knew.
    It does however make a difference and to a professional or trained ear that is more than too much sometimes.
    A 2204 is served best with matched power tubes.
    JackPlug likes this.
