Power conditioner
Discussion in 'The Workbench' started by slash38, Jun 30, 2014.
  1. slash38
    slash38 Active Member
    Aug 25, 2010
    672
    109
    Brooklyn NY
    Since i'm running my JCM and my SL5 through the same outlet..i was thinking about getting a power conditioner. Anyone ever use the monster one? Do ireally need it?
  2. LAARS
    LAARS Well-Known Member
    May 1, 2008
    509
    450
    I personally use a Furman voltage regulator, not just a power conditioner. The AR-1215
    FurmanSound.com - Pro A/V Product - AR-1215
    If you play in clubs, its a MUST have. It gives 110V no matter if you have 97V or 140V coming in. Protects your gear, and your tone as well. I hear the one from Monster is real good too.
  3. slash38
    Aug 25, 2010
    672
    109
    Brooklyn NY
    I was looking into those Furman conditioners. Look pretty cool, and i'm pretty sure thats in Slashs rig to:naughty::slash:
  4. erikthered76
    erikthered76 Member
    Feb 17, 2012
    84
    57
    new orleans USA
    I use a monster pro 2600. cant say anything but good about it.
  5. C-4
    C-4 Member
    May 12, 2011
    37
    39
    There is a difference between a power conditioner and a power regulator.
    The former cleans up dirty electricity coming from the wall outlet and protects against surges and spikes in wall voltage.
    A power regulator, such as the Furman 1215 additionally keeps the voltage coming from the wall between safe levels, incase the wall voltage drops or rises significantly.
    Some power regulators are not as expensive as the Furman, and not rack mounted. Look into ACP and Tripp Lite for similar gear that is not rack mountable, but does the same thing the Furman does.
  6. SirArcsAlot
    SirArcsAlot Active Member
    May 22, 2014
    450
    128
    I'd recommend getting just a power conditioner. I have the Furman m-8x2. I posted a thread about still getting some wall hum from it, even though it advertises it cuts out RFI, etc etc. What makes it convenient for me is that it's rack mountable and has plenty of outlets, so I can run all my heads through it. What it WONT do is make your rig quieter.
    Mine is basically just a rackmount wall strip, and most power conditioners are.
  7. slash38
    Aug 25, 2010
    672
    109
    Brooklyn NY
    Thanks for the advice! i will look into it! thanks guys
