Pots pots pots ... knowledgeable folk please help.
Discussion in 'The Workbench' started by LayLow87, Jun 22, 2019.
  1. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,372
  2. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    Should it feel 'heavier to turn' than the other knobs? just trying to figure out whats been replaced over time. all seem to be the same except the gain pot on the boost channel which is a lot slower to turn.
  3. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    618
    315
  4. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,646
    5,026
    Midwest, USA
    Mine did not. Felt just like the rest.
    LayLow87 likes this.
  5. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    thanks, guess its been replaced then! darn
  6. 67Mopar
    Jun 14, 2011
    1,917
    2,372
    I would swap that .0022 box cap in the 1987S for a .022 cap. Just sayin...
  7. Gunner64
    Nov 16, 2013
    4,646
    5,026
    Midwest, USA
    I wouldn't come to that conclusion based on how it feels. It may be just stiff, and needs lube. I would clean the pots with a lubricating cleaner..And imo replacing pots before trying to remedy scratchiness or stiffness with a cleaner/lube isn't proper proccedure. In my experience, 99% of the time cleaning the pot takes care of the problem.
    myersbw and LayLow87 like this.
  8. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    Thanks, hopefully thats it then. if it did need to be replaced (RE: this thread) what part would I use to restore it to original?
  9. Gunner64
    Nov 16, 2013
    4,646
    5,026
    Midwest, USA
    I do believe that pot, being pcb mounted is very hard to find, and I don't think you'll find a "restoration" correct one. But Not 100% certain on that as I haven't had to replace one, but I have heard of guys having to use a standard pot and run fly leads to the board.
  10. mickeydg5
    21,306
    8,965
    What year/revision 2205? It makes a difference.
  11. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    Are the pots on yours splined or solid?
  12. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    1984
  13. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    Update:
    Just whipped the knobs off, looks like an original matched set of solid shaft pots so guess the gain pot just need a lube!
  14. RickyLee
    May 22, 2010
    9,354
    2,821
    Riverside CA U.S.A.
    YES, just try cleaning them with good lubricated cleaner. Trust me, if you start replacing all those old pots, you are going to lose the MaGiK Mojo in those vintage amps!
  15. mickeydg5
    21,306
    8,965
    1984 was a transistion period. It could have a 2 gang potentiometer but it may be separates as well.
    Open it to see. Give pictures if possible.
  16. Gunner64
    Nov 16, 2013
    4,646
    5,026
    Midwest, USA
    My 87 was splined.
  17. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    Ok thanks! Unless these were all replaced at the same Time many moons ago I’m guessing these are an original set of solid shafts that came with. So
    No restoring necessary except lubricating that gain knob. Thanks for the input man.
  18. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    Thanks! It’s an early 84 too. Early February to be precise. Will crack it open hopefully soon
  19. LayLow87
    LayLow87 Member
    Jan 7, 2013
    75
    30
    The 1987 is a reissue too (albeit an early one 1988), which values would they have?
