poppy new caps? boil boil toil and trouble ?
Discussion in 'The Workbench' started by Exotic, Jan 19, 2020.
  1. ampmadscientist
    16,516
    10,424
    "the noise should go away eventually..."
    Yeah right...
    I find that idea goofy as hell. There is no reason why a capacitor should need to be "broken in," and it puzzles me why anybody would believe that.
    The idea is ridiculous to start with IMHO.
    MickeyJ likes this.
  2. Exotic
    Exotic Active Member
    Sep 3, 2018
    354
    170
    popping sounds in marshalls when idle ,is that contagious? because my jcm 900 is doing it too ! coincidence?
    do they(jcm 800 too) have something in common ? i have been trying different cabs ,which one is the phase inverter? and what else could make both amps make popping noises?
  3. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    1,062
    574
    standby switch.
  4. MickeyJ
    Nov 11, 2019
    1,062
    574
    in your case, it's maybe the power in your house, refrigerators turning on and off, fluoro lights, there could be a bad transformer hanging on the streetpost providing power to your house, could be plenty of things to do with the power coming out of your wall
  5. MickeyJ
    Nov 11, 2019
    1,062
    574
    and people read this shit online and just keep circulating it.
    What i don't like about it is that it makes guitar players/techs out to be brain dead idiots, what a load of utter crap.
    In relation to caps ' breaking in' and the sound changing to smoother or whatever the fool is typing out, what's happening is that listeners ear is changing, not the caps.
  6. Exotic
    Sep 3, 2018
    354
    170
    well i do have a powerline networking device that has a plug thru outlet on it and it hogs up the whole outlet which then goes to a power strip or surge protector ? lets say that's it ,u think it's safe for the amps or could it cause damage at some point? i should try to plug straight into the outlet with nothing else on it huh?
  7. South Park
    1,714
    1,336
    If you can put scope on amp you would see square blocks in the signal it is called boxcars . Some how a tube is unstable try rolling some tubes to start with
  8. MickeyJ
    Nov 11, 2019
    1,062
    574
    I think there are pro ( $$ ) power conditioners that work, and budget type ones that most definitely do not work, but do protect from things like big surges and lightning strikes, i dont trust them either i unplug everything during lightning
  9. South Park
    1,714
    1,336
    It could be tube socket arcing or arcing in the power tube.
  10. Exotic
    Sep 3, 2018
    354
    170
    It was the powerline networking device I removed it .plugged the amp straight in and both the JCM 800 and the Jcm 900 were really quiet with the guitar switched off
