poppy new caps? boil boil toil and trouble ?
Discussion in 'The Workbench' started by Exotic, Jan 19, 2020.
  1. Exotic
    Exotic Active Member
    Sep 3, 2018
    346
    158
    IMG_2058 (Mobile).JPG ok this is about new jj caps after having them installed after the original ones went bad .
    1.does it take some time for them to settle in or form or whatever?
    2.is it normal for there to be some new sounds when the guitar is switched off ? you hear some popping sounds like pit pit ,pop ,pit pop ,like popping or crackling . like tar blowing up in a couldron or something .
    will it go away or is there something wrong?
    this is a 1989 or 90 jcm 800 2210 100 watt head .
  2. mickeydg5
    23,604
    10,656
    No, new capacitors are good to go. The amplifier should have been checked for any abnormalities before leaving the bench.
    Take it back to whomever installed and complain.
    And if it pit pit ,pop ,pit pop before the capacitors were changed out then you got jacked for capacitors.
  3. ampmadscientist
    15,500
    9,386
    No it's not normal noise.
    It could be a noisy tube so check before thinking it's capacitors....
    It is possible for a filter cap or a decoupling cap to make that noise, but more likely usually a preamp tube.
    Take out the Phase Inverter. Do you know which tube that is?
    Now run the amp and see if the noise is still there.
  4. mickeydg5
    23,604
    10,656
    Wait a minute. If he brought it to a technician do you not think the first thing to do is bring it back and shove it up his arse?
  5. ampmadscientist
    15,500
    9,386
    Do you think that most "techs" know how to get noise out of a Marshall?
    Or if they even listen to it?
    Maybe.
    Peter McAteer likes this.
  6. mickeydg5
    23,604
    10,656
    You just proved my point, Marshall or any other amplifier. :yesway::)
  7. Vinsanitizer
    Vinsanitizer 1st new member 2020 VIP Member
    Oct 19, 2012
    25,544
    17,810
    If it's one of the ones I used to own, you're screwed.
  8. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    677
    393
    lets hope the tech didn't nick his preamp tubes.
    mickeydg5 likes this.
  9. mickeydg5
    23,604
    10,656
    Anything is possible but we need more details.
  10. mickeydg5
    23,604
    10,656
    Dude, those are good amplifiers if taken care of as should be done with any amplifier. :)
  11. Seanxk
    Seanxk Active Member
    May 14, 2018
    189
    126
    Did the originals really go bad?, or was there another problem.
  12. Vinsanitizer
    Oct 19, 2012
    25,544
    17,810
    It went over your head. :D It was a joke.
  13. mickeydg5
    23,604
    10,656
    Teh. I get it. You do not take care of anything.
    Understood. :thumbs:
    Vinsanitizer likes this.
  14. Vinsanitizer
    Oct 19, 2012
    25,544
    17,810
    I do, especially these days when I'm meticulous to the point of feather dusting gear that I use at home and never take outside my house. In the 90's I used two JCM 800's for lots of shows: a 2210 and a 2205. I was young and ignorant, and had decided to hack my 2210. I'll just leave it at that. But for that reason, I pity the poor b@stard who bought that thing after I had my way with it. :D
  15. mickeydg5
    23,604
    10,656
    Ok. We all learn from our mistakes. I can forgive you. I hope the new(er) owners of those amplifiers can as well.
  16. Vinsanitizer
    Oct 19, 2012
    25,544
    17,810
    But I still want my 2205 back. Go ahead, wish me luck. LOL! :D
  17. mickeydg5
    23,604
    10,656
    There is no such thing as luck. But there is something that resembles what some call karma.
    I hope in some light hack can be considered a good thing for your sake Vinsan.
    I mean, inanimate objects themselves do not matter.
  18. South Park
    1,441
    1,081
    Check the solder joints. Run the ground of the new cap to the center tap .
  19. mickeydg5
    23,604
    10,656
    @Vinsanitizer, you liked this.
    Hopefully you did not screw someone over with an inanimate object because the female dog called karma may bite you in the rear.
    Tell me you did no such thing.
  20. Exotic
    Sep 3, 2018
    346
    158
    he saved all the original parts for me as per my request ,he said the noise should go away eventually ,just caps discharging ?
    ps go check out my post about roth vegas marshalls etc in the marshall amps section !
