Plexi + 1x12
Discussion in 'Cabinets & Speakers' started by Chris Brough, Feb 3, 2019.
  1. Chris Brough
    Chris Brough New Member
    May 28, 2017
    7
    9
    Anyone use a single 12 with their 50w plexi? If so, do tell.
  2. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,537
    1,166
    Why would you want to ?
  3. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    726
    706
    If concerned about blowing speakers or sounding small, you want a K85 / K100 or an MC90
    stringtree and Chris Brough like this.
  4. ampmadscientist
    11,702
    5,727
    Left Coast
    You can use a speaker rated 100 watts or more.
    The speaker should be rated 2X the power of the amp.
    EVM 12L is a good choice, there are also some new high power Celestions.
  5. ampmadscientist
    11,702
    5,727
    Left Coast
    For 1 thing, to reduce the loudness.
    The_Lucek and stringtree like this.
  6. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    833
    562
    Cleveland, OH
    Yep. Celestion Redback.
    Best speaker I've tried.
    tce63, J Saw, Metroman and 4 others like this.
  7. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,473
    3,902
    Austin TX
    EVM12L in TL806 cab :yesway:
    Mitchell Pearrow and Geeze like this.
  8. stringtree
    stringtree Well-Known Member
    May 21, 2016
    708
    1,161
    Couldn't find a good clip of the Redback, but I found a Celestion Redback I.R. clip. :dude:
    Is it accurate to the real deal...?
    J Saw likes this.
  9. stringtree
    May 21, 2016
    708
    1,161
    What style of music really determines what you get from the guitar/amp/cab connection.
    My ears really perked up at the 8:22 mark..:dude:
    Mitchell Pearrow and Wooferhead1 like this.
  10. stringtree
    May 21, 2016
    708
    1,161
    Couldn't find a good K85 clip...
    :dude:
    Wooferhead1 likes this.
  11. metromutt
    metromutt Active Member
    Jul 15, 2009
    648
    241
    England
    Other than stating the obvious... 50w head into cab matched for high volume. I've found there can be benifits to using just one speaker (with a lower wattage)... when recording or lower volume playing. Using just the one speaker and a careful ear to drive the amp up in volume, can be rewarding.
    Alot of time you listen to amp distortion only, but adding the cone movement can add an extra dimention to the tone without ear splitting volume. I think it's all about a balance in performance with the amp and speaker and the way you need it for your own application.
  12. ampmadscientist
    11,702
    5,727
    Left Coast
    The new Redback is rated 150 watts and would probably make a good choice.
  13. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    10,260
    8,200
    Taintville
    I put my 74 MKII 2204 in a custom made Marshall JTM 1x12 combo cab and it works looks and sounds great! I use the Celestion G12M-65 Creamback. I use an attenuator along with the London Power Scaling mod and can get it to sound blissful at any volime.
    Mitchell Pearrow and stringtree like this.
  14. stringtree
    May 21, 2016
    708
    1,161
    Whats left to attenuate after the LPS...
    I read quickly through:
    http://www.marshallforum.com/threads/london-power-scaling-mod.98838/
    Jones for clip, but you never posted one, or did I miss it...after you got your amp back with LPS mod.....
    That Flux Tone speakers system is some pricey #$%#! I'll take a Marshall Power Brake or THD Hotplate, if ya could still find one of them..LOL
  15. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    502
    163
    One of my cabs is a DIY 1x12 20x 24x 10.5". I often run my 50w through it attenuated for low vol wanking but its for my DSL 15.
    The trick with a 1x12 is to manipulate the sound waves into thinking its a multi speaker cab. You don't want a perfectly square cab and you don't want the speaker sitting directly in the center. By placing the speaker offset in one corner all corners receive sound waves at different times creating a much bigger 3D tone.
    I could be a bit crazy though:cheers:
  16. stringtree
    May 21, 2016
    708
    1,161
    I'll take some of that craziness!! Great post :dude:
    This could be done with a 4x12 or 2x12....
    Any pics and clips....?
  17. stickyfinger
    Nov 11, 2010
    502
    163
    Ill post a photo latter but there would be no need I would think with a 2x12 or 4x12 as multi speakers have lots of different waves reacting with each speaker.
  18. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    246
    334
    This may be my speaker choice for this Studio Classic. DO you have one or did you just get a chance to play through one?
  19. SlyStrat
    Jan 7, 2011
    833
    562
    Cleveland, OH
    I've tried every Celestion.
    The Redback knocked them all out.
    Does everything good.
    The opposite of Greenbacks.
    Delete!! likes this.
  20. Adieu
    Jan 12, 2013
    726
    706
    K85 is the old British label... at some point, either when they went Chinese or before, they reclassified it to 100w and it became K100. Supposedly without recipe changes.
    stringtree likes this.
