pickup output: ceramic vs. alnico
Discussion in 'The Tone Zone' started by paul hancher, May 31, 2019.
  1. paul hancher
    paul hancher Well-Known Member
    Jan 25, 2019
    272
    476
    with all else being equal will a switch from ceramic to alnico magnets affect pickup output?
  2. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,556
    3,655
    Springfield, Ohio
    From what I understand, ceramic will be hotter than alnico. Alnico V being hotter than Alnico II. Tone will be different as well. Do a search on youtube. I have seen some vids which guys show the difference. It is quite considerable.
    paul hancher likes this.
  3. mickeydg5
    23,705
    10,736
    Which ceramic pickup?
  4. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,365
    1,320
    "Ceramic" is pretty vague, but USUALLY the consensus is:
    Ceramic > A8 > A5 > A2
    (possibly: A8 > Ceramic > A5 > A2, because the really hot Ceramic buckers use oversize magnets)
  5. paul hancher
    Jan 25, 2019
    272
    476
    thanks for the responses. there is no particular pick up in question. it is just that i have noticed that in general high output pickups have ceramic magnets and i was wondering if this was a general characteristic of ceramic material in regards to magnetism. just like higher wattage speakers tend to have ceramic magnets. i understand that a factor in this is economics, that ceramic materials are usually less expensive but was wondering if there were other factors that go into the decision on what to use.
  6. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,402
    My favorite HB pickup, is the 8O's era SD Distortion. I believe these were/are ceramic. I play alnico now... Why, I have no earthly idea?
  7. Delete!!
    Delete!! Well-Known Member
    Jun 29, 2018
    233
    288
    San Joaquin Valley, Ca
    To my ears the ceramic magnets impart a hard crunch into the tone. Depending on how well the pickup is designed this can be interpreted as “aggressive” or even “harsh” or “stiff”, or “compressed” to some people. Personally, I don’t care for them - although I have liked some vintage DiMarzio Super Distortions. Not sure how the new models sound.
  8. SkyMonkey
    1,613
    1,823
    England
    Seen this YT vid on Ceramic vs Alnico?
    BftGibson and Micky like this.
  9. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    313
    468
    In general, ceramic magnets tend to be stronger so you get a tighter sound and faster response - but I think it's a subtle difference. There are ceramic pickups in jazz or blues and alnico in extreme metal.
  10. mickeydg5
    23,705
    10,736
    I see A8 as impressive as ceramic. I also see lots of artist with lower output pickups. It all depends on the signal chain and amplification. I, myself, like AlNiCo.
  11. Adieu
    Jan 12, 2013
    1,365
    1,320
    This guy is seriously odd.
    Video about a magnet swap, yet doesn't even say which pickup he's swapping it into, or what it had before (2,3,4,5,8?)
  12. SkyMonkey
    1,613
    1,823
    England
    He is a bit "self professed" but I think well meaning.
    There is a vid on the building of the original guitar and the neck pickup he is testing is a Vintage Vibe P90, but again the pickup magnets are stated as 'AlNiCo' or 'Ceramic' (you get both with the pickup).
    Most of my guitars are ceramic (Dimarzio IBZ, X2N + D Activator X, EMG HZ passives) with only a JB + '59 set being AlNiCo 5s.
    The JB is actually the harshest sounding one of the Humbuckers to my ears, even when dropped fairly low in the body (5-6 mm from low E). The '59 is sweet and they both do coil splitting beautifully. The IBZ set are fairly bright and the X2N D Activator set are perfect all rounders for me (the D Activator X in the neck is sweet with parallel and split options too, both set low again).
    So I think it comes down a lot to taste and pickup height settings, plus all magnets are not equal (the EMGs are the lowest powered of all and ceramic).
  13. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,628
    2,549
    Really? i thought the 59 sounds twangy
    I had an american standard SSS and i wanted a humbucker in the bridge so i got a lil59 and it sounded kickass, in the bridge so i thought ide build a pickguard S/H and put the lil59 in th eneck and get a full size 59 when i got it and put it in they could not be anywhere near the same. The lil59 sounds full and a nice forward midrange. The full size 59 sounds darn near like a single coil stacked it lacks bottom end and its just overy trebely horrible pickup imo. In a mahogany body fender rosewood fretboard.
    Befor eyou say it, i thought it was wired wrong also so i tried it in different ways and nothing helped. SO i went on the duncan forum and they all say the lil59 and regular 59 are nothing alike.
    Its weird the lil59 is like 12Kohms and the regular is like 8ohms and they both are very mild outputs
  14. Lo-Tek
    Lo-Tek Well-Known Member
    Aug 25, 2013
    4,343
    3,275
    Traverse City, Mi.
    I only have experience with single coils. I like both but prefer my ceramic pickup guitars. Not only a bit hotter but they seem fuller with more harmonic content. Also more string feed back. Generally speaking I find them more versatile. I still like alnico p’ups but they seem a bit flat and one dimensional in comparison.
    Obviously there is tremendous variation amongst different pickups though.
  15. SkyMonkey
    1,613
    1,823
    England
    The '59 in my San Dimas is in the neck position. I've never hear it in the bridge. There is a bridge model, maybe that's the one you tried? The Little '59 has less of a scoop on the mids than the full sized ones.
  16. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    1,576
    1,460
    Shakedown Street
    I will tell you from my experience that A2 are very treble , A3 somewhat the same but to me seem weaker than the A2 , and A5 will have mucho plenty midrange growl which I love in my Les Paul's and my 2555X . To me that is the sweet spot for killer tone with my Marshall 2555X :headbanger:
    paul hancher and Micky like this.
