Philips KT347 Radial "Mustard" Capacitors... Any good?
Discussion in 'The Workbench' started by 67Mopar, Jun 26, 2019.
  1. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,391
    I'm thinking about replacing the China made caps in my AC15 with these. Does anyone have any experience with these capacitors? Given the size of the stock axial signal caps, there's no way they can be foil/film. I figure these may be a worthy alternative. I considered using NOS axial Mullard mustards, but they're just too darn big.
  2. ampmadscientist
    14,811
    8,664
    Polyester Film Aluminum Foil, Crimped Radial Leads, metalized paper and polyester film dielectric, those capacitors have 10000 V/uS pulse rise time, values that are typical for high quality polystyrene and polypropylene capacitors. High values of pulse rise time provide excellent quality audio blah blah blah.
    I found some for $1 each if you want em.
    https://www.partsconnexion.com/mustard-vintage-film-capacitors.html
    67Mopar likes this.
  3. 67Mopar
    Jun 14, 2011
    1,917
    2,391
    Thanks! The ones I need are .1uf 400V and .022 400V. I found some .022 250V, but I can't use them in the tone stack. Has to be 400v. I found some Philips MKT .022 400V, but they are orange.
  4. 67Mopar
    Jun 14, 2011
    1,917
    2,391
    Ended up going with CDE 150 series polyester axial caps. Same as Mallory 150, I think?
  5. ampmadscientist
    14,811
    8,664
    The orange caps are still pretty good for audio.
    67Mopar likes this.
  6. ampmadscientist
    14,811
    8,664
    I think they are basically the same.
    67Mopar likes this.
  7. ampmadscientist
    14,811
    8,664
    I think the ones to get are Packtron.
    I have no idea why they sound so good, and what the difference is in construction and materials.
    Guitar-Rocker and 67Mopar like this.
  8. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    Indianapolis, Indiana
    I have used those Philips mustard radials ( I used 630volt rated) with great results, though like all mustards they are very smooth, but usually exhibit a darker tone.
    I've used the Philips MKT in a .1uF 400V, and they are very transparent. The orange MKT .1uF Phillips had a very low noise floor when checking outside foil ends.
    wakjob and 67Mopar like this.
  9. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    472
    242
    My favorite signal caps in amps are the ERO MKT1813
    Guitar-Rocker, 67Mopar and GIBSON67 like this.
  10. fifteenohms
    fifteenohms Well-Known Member
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    Forget "what do they sound like" - they have no sound at all.
    Capacitors do not "sound like" anything.
    Without an LCR meter its just a wind-piss trying to figure out how to calculate if a component will affect the circuit or not.
  11. fifteenohms
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    Why are these your favorite brand, and by how much in your calculations are they superior?
    Quanitify. Its a math-thing, not a feel-thing.
  12. 67Mopar
    Jun 14, 2011
    1,917
    2,391
    Sure they do. It is especially noticeable when using a MV circuit (preamp distortion), or pushing the power section into clipping. Per my experience, signal cap changes are mildly noticeable when playing clean. Filtering plays a roll as well. With power filtering, it's a feel thing... Attack, sustain, and release. i.e. Loose - snug - tight. :naughty:
    Guitar-Rocker and wakjob like this.
  13. 67Mopar
    Jun 14, 2011
    1,917
    2,391
    I discovered that I can't use radials, as they would sit too close to the preamp tubes. I don't know what VOX used for axial signal caps, but they are small. SOZO caps are too large to fit between the turrets. I don't want the caps suspended off the board, so I had to track-down some caps that don't exceed 20mm in length. The CDE polyesters fit the bill perfectly. I had to up the voltage on the .022 caps to 630V, as Mouser doesn't stock the 16mm .022 400v caps. Should be fine.
    Here's an AC15 Heritage that Psionic modified with SOZO caps... While they do good work, this type of refit just isn't acceptable. Not for me anyway.
  14. fifteenohms
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    Discrete components have no inherent tonal qualities,only their values ranging affects the circuit's equation.
  15. Guitar-Rocker
    Mar 5, 2012
    2,746
    2,335
    I've heard that argument before. My ears say that is just wrong. After building hundred of amps and fine tuning them to their best tonal qualities, I know there are distinct differences, within the exact same values. But to each their own belief.
    mAx___, neikeel, wakjob and 3 others like this.
  16. FourT6and2
    Dec 3, 2010
    472
    242
    Been there done that. Built plenty of amps and A/B'd different types of resistors, caps, transformers, etc. in every single position of an amp and swapped out parts in real-time to compare. I know what parts work for me in the amps I build to get the sound I like and I know why they sound different, but I'm not about to write a dissertation about it.
  17. 67Mopar
    Jun 14, 2011
    1,917
    2,391
    Using this logic, I asked my local supplier to price-match his NOS Mullard 12AX7's to the Mullard reissues... He refused! I then asked him to price-match his NOS "mustard" caps to equivalent value SOZO's, but again, he refused. WTF is wrong with this guy? Should I ask about his USA and Japan made J-FETs, or just write him off as an idiot?
    wakjob likes this.
  18. ampmadscientist
    14,811
    8,664
    Discrete capacitors and other components definitely (beyond any doubt) have their own sound.
    Which is probably why "mustard caps" are so sought after.
    And also why I will use Packtron capacitors (it made a huge change in the sound).
    Further, parts on the board radiate into each other depending on layout, which also radically affects the final tone.
    Which is also why I am using F&T filter caps, which noticeably affect the final sound quality, etc....
    Anybody who tells you otherwise - lacks the experience to know better.
  19. ampmadscientist
    14,811
    8,664
    I wouldn't buy "Sozo" capacitors, which have no specifications sheet and no stated ratings.
    I am very suspicious of undocumented parts, which are made by non-identified manufacturers in un-specified countries....
    67Mopar likes this.
  20. fifteenohms
    Sep 30, 2010
    1,071
    538
    Los Angeles, CA
    The both of you:
    How do you measure value drift?
