Pedalboard noob questions
Discussion in 'The Tone Zone' started by Rickrevs, Mar 31, 2020.
  1. Rickrevs
    Rickrevs Active Member
    Aug 4, 2017
    117
    51
    South West...UK
    Hi all....just started building a pedal board with mostly EHX pedals....those rubber feet...do you cut them off ? or fix an upstand to the board so the velcro hits the base of the pedals not the feet..also i see plenty of cheap power supplies...but also some really expensive ones...any recomendations that dont cost more than the pedals themselves..
    SkyMonkey likes this.
  2. Bogmonster
    Bogmonster Active Member
    Nov 22, 2014
    135
    167
    Generally I would just take them off if they're very awkward or getting in the way. They're usually just stick on so should be easy to remove.
    There's loads of power supplies out there for all budgets. An isolated supply would be my recommendation as it will keep your rig silent. Depending on your budget, there's lots of options. But you won't go wrong with a Voodoo Labs Pedal Power 2 Plus. Built like a tank and not too expensive. Very versatile too. I used them for years with no issues. I recently upgraded to the Strymon units and they are absolutely fantastic too. Great for higher draw pedals and flexible as well.
    It depends on what you're after and how big your board is.
  3. SkyMonkey
    1,962
    2,407
    Indoors
    If you warm them up with a hairdryer they may just peel off. Then you could save them for if you want to re-sell.
    I have just built my first pedalboard and am still using one power supply (RockBoard Power Ace-1700mA) with an 8-way daisy chain.
    For my needs this is still a workable solution, very little hum that I can hear.
    For the future I have left room under the board for a Truetone 1-Spot CS6, that would still require 2 outlets to be split.
    But it's the only isolated PSU that will fit and supply 500mA to an output for my ZOOM MS-70CDR.
    Look at the reviews on something like Amazon to get a better picture of how reliable a PSU is.
    Rickrevs likes this.
  4. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    899
    818
    incarcerated
    For a PS that does not cost more than your pedals; just make sure that there are enough miliamps to run them efficiently. You also have to decide if you need sag or voltage doubling features.
  5. Wenander
    Wenander Active Member
    Aug 10, 2015
    227
    244
    Sweden
    Voodoo labs like he says... Awesome well spent money...
    lespaul339 and Rickrevs like this.
  6. Jason Fieldhouseespk
    Jason Fieldhouseespk Well-Known Member
    Apr 21, 2018
    326
    472
    Look at Thomann power supplys, :naughty:
    If you know, you know! ;-)
  7. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,881
    6,605
    Montreal
