Pedal That Turned Your Marshall From Meh To Schwing
Discussion in 'The Tone Zone' started by Buzzard, Jul 10, 2017.
  1. JohnH
    JohnH Well-Known Member
    May 31, 2008
    2,841
    741
    Wilton NSW
    My favourite stock od pedal is a Boss OD-3, run into a dirty-clean setting on my dsl401 or VM2266C. It has a thickness and depth which I much prefer to a stock SD-1. Its clearer than my Bad Monkey and more natural than my OD1x
  2. Trapland
    Trapland Well-Known Member
    Dec 5, 2013
    695
    377
    Minneapolis
    Straight in with a Marshall Powerbrake. Best sound ever.
    But then I usually prefer pre-master volume amps. Not disrespecting anyone's choices, but after buying about every "Marshall" sounding pedal on the market, I've decided it doesn't exist.
    I do use pedals a bit for playing covers but never for dirt. I get all the clean I need with the guitar volume control. For me the key was getting used to using LESS GAIN. Still more than enough drive from an amp turned up to 6, yet it cleans up with a flick of a guitar pot.
    matttornado, Jakeboy and SG~GUY like this.
  3. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    2,089
    1,141
    Montreal
    For me the Marvel Ramble FX( a Plexi pedal ) into the DSL40C is like WHOA WTF !!!
    Transformative it is.
    BP
  4. RickyLee
    May 22, 2010
    8,154
    2,094
    Riverside CA U.S.A.
    Not really hyping up or giving a meh to whoa experience, but just thought I would share something I experienced for the first time last night.
    :naughty:
    I just threw together another project amp last week. It is a lower wattage Marshall influenced in the preamp topology, but with a cathodyne phase inverter, and with my own little tweaks thrown in there basically on the fly experimenting for tonal options. The amp has very old filter caps that I was planning on replacing here after the amp was somewhat finished. I had to decide what caps and values I wanted anyway and needed to place an order for them basically anyway.
    So last night I was playing the amp at a low volume here at the house having fun and decided to run some Dirt pedals through the front end. I pulled out my old trusty Marshall Bluesbreaker MKI, my On Floor Audio (shameless plug for our own Mike and his great hand built pedals here) Tube Boost OD, the Fulltone OCD V1.7 that I just got a few months ago and still have not used much, Jeckyll and Hyde pedal and my Boss FZ-5 pedal.
    I ran the BB MKI, Tube Boost OD, OCD in that order first. They each had their own slightly different voicings. The Tube Boost OD actually sounded the best in my build as my amp has a somewhat 2204 voicing but with a much thicker texture. Think of a somewhat mixture of Marshall 2204 meets Mesa MKI type sound. Much more low end girth with more pronounced lower mids.
    So then I plugged in the Boss Fuzz pedal and was digging on the very phat singing sustain I was getting. Then I heard a POP, and then a hissing sizzling sound as my tone went to crap. I was tripping thinking I let the smoke out of something or worse and then as I was reaching to shut off the power switch I was also wondering why my fuse did not blow. to cut this short, I blew my filter cap to the first preamp B+ node. Never did plug in the Jeckyll and Hyde pedal.
    Anyone else here had any issues with Fuzz pedals causing issues on their amps? I thought I read something about Fuzz pedal issues here awhile back . . . .
    Trapland, SG~GUY and HOT TUBES 70 like this.
  5. Barfly
    Barfly Well-Known Member
    May 6, 2012
    989
    791
    NYC, NY
    I'm with JimiRules. My JCM 800 isn't meh on it's own but... I love my Soldano GTO into my JCM 800. What a brutal, rugged bastard.
    HOT TUBES 70 likes this.
  6. SG~GUY
    SG~GUY Well-Known Member
    Jan 27, 2010
    3,451
    1,813
    -hotter pup-
    -I like the clean boost you get from something never really intended to be a boost, like an analog delay, chorus or maybe the best effect to add a hotter signal with huge tone shaping, an EQ..
    El Gringo likes this.
  7. Bonzo
    Bonzo New Member
    Jan 19, 2014
    MXR ZW-44 into my JCM 800 2203
  8. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    575
    329
    Shakedown Street
    Just like my old Electro Harmonix (Analog) Memory Man Delay used to do when I was using it a lifetime ago .
    matttornado and SG~GUY like this.
  9. MonstersOfTheMidway
    May 1, 2008
    4,192
    1,499
    Boss Parametric Equalizer PQ-4 (discontinued).
    For any amps (including Marshalls) that needed just a little fine tuning, this was my "go-to" pedal. The tiniest changes in parameters made a huge difference and the "level: control made for one of the best volume boost I've ever heard. Solid state amps sounded warmer and looser, 2X12 combos sounded thicker/fuller, heads with 4X12 cabs got a little more depth, especially for chords. Whether for clean or dirty/overdrive/distorted tones, this little pedal made a difference. Presently, it isn't necessary to use mine, but I keep it around because I know this is a banging little pedal.
    My other favorite parametric equalizer is the Empress ParaEq; it's still in production and a bit expensive, but very much a difference maker like the PQ-4.
    Marshall Stack, jimmyjames and SG~GUY like this.
  10. jimmyjames
    jimmyjames Well-Known Member
    Jun 15, 2014
    797
    644
    West Oz
    I just put my Maxon/Ibanez PQ9 back in the chain :yesway:
    MonstersOfTheMidway and SG~GUY like this.
  11. Ade2064
    Ade2064 Member
    Jun 5, 2015
    86
    22
    Suffolk, UK
    Sd1 for me, but I would like to try a SoloDallas
  12. Trapland
    Dec 5, 2013
    695
    377
    Minneapolis
    @RickyLee I'm almost certain I've read that the squared waveform of some fuzz pedals can overheat speaker voicecoils. Anecdotally, I just acquired a basketweave cabinet who's previous owner claimed he lost the original Greenbacks to a Big Muff.
    I've heard many people claim boosting the input stresses an amp. I'm not sure I buy that on a well designed amp, but I think the fuzz square wave thing could have some merit.
    RickyLee likes this.
  13. RickyLee
    May 22, 2010
    8,154
    2,094
    Riverside CA U.S.A.
    Yeah, that is good info you posted. And that does jog my memory now.
    I should update my situation on the blown filter cap. When I went in and changed that cap out, I noticed there was a very high B+ going to that node. I expected a slightly higher B+ already before that happened due to me not having all the tubes installed that this amp normally runs, the main two missing being two power tubes. But what I encountered was 500VDC going into a 350V rated Mallory cap from 1966 LOL. That cap held up for a good 2 to 3 hours of off and on previous abuse over a few days at that voltage until it finally threw in the towel when I hit the amp with that fuzz pedal.
    So I need to go in there and change a few B+ dropping resistors as well.
  14. Shae201
    Shae201 Active Member
    Dec 20, 2015
    306
    229
    My two favorite ODs right now for my jcm800 are the Walrus Voyager and Mayflower.
  15. axe4me
    axe4me Well-Known Member
    Feb 28, 2013
    1,676
    1,513
  16. SG~GUY
    Jan 27, 2010
    3,451
    1,813
    -I think that was jim-(SCUMBACK SPEAKER)-who said that a FUZZ was hard on speakers-
  17. BanditPanda
    Oct 19, 2015
    2,089
    1,141
    Montreal
    I guess that must be why there are disclaimers on some speaker sites which state that some speakers will catch fire !!
  18. TarNhaK
    TarNhaK Member
    Apr 1, 2017
    99
    57
    Fulltone OCD V1.7 best overdrive ever made
  19. ricksconnected
    Sep 29, 2015
    9,817
    3,679
    everywhere you wanna be.
    best piece of advise...... don't buy "meh" amps.
  20. ricksconnected
    Sep 29, 2015
    9,817
    3,679
    pic?
    R.Kandy likes this.
